Go Back   HeliFreak > R/C Electronics Support > Mikado V-BAR Control
Mikado V-BAR Control Mikado V-Stabi/V-BAR Control Flybarless System Software and Hardware Support
Like Tree1Likes
  • 1 Post By Dennis P
Old 05-28-2019, 10:00 PM   #1 (permalink)
TJ
Default Help V control touch and battery manager
I have a Vcontrol touch and I am trying to edit the batteries that are currently in my list. It seems only when I plug in my model can I add a new pack and edit its name and parameters of that particular pack. So how do I delete or rename or edit packs that are already there?
I have three options under applications when my pack is conntected to the model. They are.
Battery Manager
Battery Alarm
Edit Batter
the first option is not selectable kind of greyed out.
Thanks for the help
T.J.
KBDD Team Pilot
TJ is offline        Reply With Quote Quick reply to this message
Old 05-28-2019, 10:23 PM   #2 (permalink)
Edit Battery
From there you can change name and parameters.
TDRís / Diabolo 700 BE / Diabolo 800 BE / Diabolo SE / Diabolo UL / Goblin Kraken
VBC, VBCT, Kontronik, MKS, R2 buffer
Spencerkey is online now        Reply With Quote Quick reply to this message
Old 05-28-2019, 10:48 PM   #3 (permalink)
You can connect to the PC and in Explorer you can delete the unused batteries from the VBCt. If you have selected FIXED battery ID then certain functions of the battery manager will be disabled.
VControl
Old hand at Planks
Peter
Old 05-29-2019, 04:29 AM   #4 (permalink)
I seen somewhere where you can add a battery Iíd tag to your existing batteries if thatís what your trying to do. I donít know how to do though as I donít have any of sensors.
tshelby73 is offline        Reply With Quote Quick reply to this message
Old 06-12-2019, 09:31 AM   #5 (permalink)
Hi,
if you skip the battery selection (x) you can do more in the battery manager. It's just that once a battery is selected, a log file is created and so on, so it's better you can not mess too much.
If you have BatteryID, just connect the battery outside the model, so the sensor can not sense the tag. Then, you can even assign a new tag to an existing battery or vice-versa.
Kind regards
Eddi
Eddi E. aus G. is offline        Reply With Quote Quick reply to this message
Old 03-26-2020, 11:47 PM   #6 (permalink)
I am struggling with this also. I have a battery listed that I know longer have and cannot seem to eliminate it from the list. I can remove it's name ect but it still shows up without a name. Any ideas on how to completely delete a battery from the list?
Figured it out. Have to connect to the computer in USB mode with a cable. Select files and battery. Find which battery number you want to delete and select delete file.
Rotor-Tech Blades
Old 03-29-2020, 04:14 PM   #7 (permalink)
Oh my I just learnt with a little help from a friend that there is such an easier way to delete a battery. First off it tells you how to do it on the V touch if you select the ? on the battery select screen when you first power up and link to your heli. When you go to select the battery right after linking to the heli just hold down on the battery you would like to delete. A menu will pop up that allows you to delete the selected battery and all data associated with that battery or view logs. Really simple once you know where to look. I would have thought that battery manager may have been the spot for this
Rotor-Tech Blades
Old 03-29-2020, 10:56 PM   #8 (permalink)
Yes that is the VBCt way of doing it the original thread has been for the VBC.
VControl
Old hand at Planks
Peter
Old 03-30-2020, 05:17 PM   #9 (permalink)
Sorry Vinger, but re read the original post as the title and first sentence are I have a V Control touch. Take care
Vinger likes this.
Rotor-Tech Blades
Old 03-30-2020, 11:16 PM   #10 (permalink)
Sorry my bad for not reading well .
VControl
Old hand at Planks
Peter
Old 06-04-2021, 01:22 PM   #11 (permalink)
I'm trying to delete some old batteries with my vbct. When I do a long click on the battery selection menu nothing happens. What am I doing wrong?
lukem is offline        Reply With Quote Quick reply to this message
Old 06-04-2021, 01:44 PM   #12 (permalink)
I have a related but opposite question.
I have a new VBC Touch (no models bound to it yet but will have later today).
I downloaded the apps, but I don't see a way to bring up the battery manager to add my current batteries manually.
With my original VBC, I would manually add each battery and it's characteristics. Then, as soon as I plug in a pack to fly, I'd get a scrolling pick list to choose which battery I'm flying.
I don't use the Mikado battery tags, as I use Revolectrix PowerLab chargers/bump control battery tags and didn't want to deal with 2 different tags on each battery.
Maybe the pick list won't come up until I bind and then choose a model fo fly however, how do I manually add all my packs?
Thanks!
Old 06-05-2021, 05:36 AM   #13 (permalink)
you will add your packs as you plug them into the model. You can't really change anything (other than system settings) on the VBCT without a model connected as far as I know. All that said, you should consider battery ID. It is AWESOME! You could mount your battery id on the opposite side so it didn't interfere with your other tags. Keep in mind that it really only fits on 500+ models
Vcontrol Touch, AccuRC & Heli-X Simulators
Oxy 5 MEG, 4 MAX, 2 (215)
SAB Goblin 500 Sport
XL Power Specter 700
Old 06-05-2021, 07:09 AM   #14 (permalink)
Thanks fiddle.
I figured that might be the case and confirmed it yesterday when I flew with the touch for the first time. I think it was the same on my original VBC, but it’s been a long time since I’ve added a battery.
As far as the battery ID system, I’ve used Revolectrix Bump charging tags for several years now. They are very similar to Mikado’s system (and I didn’t want to deal with 2 RFID tags on every battery) so I went with the bump tags.
My primary use is to simplify charging (they do that extremely well). I just manually program all my packs in the VBC and choose one each time I fly.
If you have not seen this system, you should check it out: http://www.revolectrix.com/
Old 06-05-2021, 11:10 AM   #15 (permalink)
Originally Posted by 3D Dave View Post
If you have not seen this system, you should check it out: Home
I have seen it It does look nice also.
