Go Back   HeliFreak > R/C Electronics Support > HobbyWing ESC's
HobbyWing ESC's HobbyWing ESC Support
Like Tree9Likes
Old 09-22-2021, 01:10 PM   #461 (permalink)
Mmmm... It turns out that teensy cortex is capable of half duplex uart, so no need for the resistor and it can be connected only to TX1 (teensy pin 1)
I've updated the code for half duplex on teensy cortex boards
Please flash latest code and update the circuit as follows:
- Remove 3.3k resistor and connect smartport to pin 1 (TX1)
- Connect ESC to pin 7(RX2)
DanielGA is offline        Reply With Quote Quick reply to this message
Old 09-22-2021, 01:14 PM   #462 (permalink)
config.h is correct
Keep CONFIG_LUA disabled for now. Also disable DEBUG_ESC and DEBUG_ESC_RX as they are no needed
Old 09-23-2021, 09:01 AM   #463 (permalink)
ok so i did all that, and nothing, but i think what happened is I managed to fry the teensy because I put BEC 8.0V at the beginning before I did the 5V reg.....i thought it was ok because I could flash it, but it must have roasted the 3.3V logic or something.....anyways
back to Arduino Pro Mini, was able to finally flash that, I can get sensor data now on the Tarannis but only using the debug sim, it appears am not getting anything out of the ESC feeding into the arduino
am confused by a couple things, my HW200A says on it v4.1, so should I be using PROTOCOL_HW_V4_HV instead of PROTOCOL_HW_V5_HV?
what is it that doesnt work with the ESC having the vbar firmware? could that be issue?
kiosk is offline        Reply With Quote Quick reply to this message
Old 09-23-2021, 09:14 AM   #464 (permalink)
Based on the last DEBUG output you posted, the Teensy should be fine. It was sending data through the serial. If you fryed it because of the 8V, it wouldn't work at all
Because you have the vbar firmware
v4.1 is the firmware version, but V4 and V5 in MSRC is the ESC model
V4 = HW Platinum V4
V5 = HW Flyfun V5
Same protocol but sensors for current and voltage are different depending on models. Though finally appears that V4 HV has same sensors that V5 HV and same for LV. So either V4 HV or V5 HV is fine, you'll get same reasult
Vbar version does not send telemetry every 20ms. I guess it must be requested. I've no info about that protocol
Old 09-23-2021, 09:54 AM   #465 (permalink)
ok cool, so it has to be the firmware then, ill flash that next on the ESC
the teensy was sending serial data to the "Serial" which i saw on serial console, but I never got it to send anything to smartport via "Serial1", i tried USB-TTL on "Serial1" and never got anything, whilst on "Serial" i was able to see it
Old 09-24-2021, 11:36 AM   #466 (permalink)
Flashed ESC and nothing, no data.... I know the data from arduino-> smartport--> taranis is working because of sim debug.... But how do I troubleshoot ESC to arduino?
Sent from my SHT-W09 using Tapatalk
Old 09-24-2021, 12:46 PM   #467 (permalink)
Does discover sensors in opentx find the arduino sensors? If so, are their values 0?
Does DEBUG show any output?
Please send a picture of the circuit
Old 09-24-2021, 12:49 PM   #468 (permalink)
Did you fashed the no vbar firmware to the ESC?
To debug the ESC, disable DEBUG and enable DEBUG_ESC_HW_V4
Old 09-24-2021, 12:58 PM   #469 (permalink)
Is the ESC arming?
If not, you can either power the arduino after the ESC is armed or enable ESC_INIT_DELAY in config.h
Old 09-25-2021, 04:33 PM   #470 (permalink)
i get nothing on debug unless i turn on SIM_RX, SIM_SENSORS. with this i get all the sensors show up on the Taranis radio when discovered...so I guess this means "Arduino-->Smartport--> Taranis" is all working OK
yup have had it on, but nothing shows on serial console
Is the ESC arming?
yes its arming ok, but will try this sequence and option....
what is this line I have commented out?
//#define ESC_SIGNATURE // HW V4 signature (only smartport).
and difference between these two
#define DEBUG_ESC
#define DEBUG_ESC_RX
Old 09-25-2021, 05:34 PM   #471 (permalink)
Not really. This means arduino is not receiving data from smartport
Check the circuit at pins 7 and 12. There must be an issue at pin 7. Check that smartport line is connected straight to pin 7, not 12
Comment SIM_RX and SIM_SENSORS
If it is arming keep commented ESC_INIT_DELAY
#define DEBUG_ESC
Not needed for this case. Comment them
Old 09-26-2021, 01:58 PM   #472 (permalink)
ok finally got it working, i dont even know what did it, but all the sensors are showing up fine now with the ESC hooked up, am just not getting any reading on voltage or RPM, just says 0
do i need pernanently disable all DEBUG?
ID:	933895   Click image for larger version
Old 10-18-2021, 01:27 PM   #473 (permalink)
Hello Daniel.
I noticed that you have made corrections to GPS support by Spektrum XBUS. So I decided to test your code again. GPS Set to 9600 1Hz and 19200 2Hz works very nicely, my receivers have no problem detecting it. You could still fix the sending of the time that is not working properly
Very good job
There is an error in the configuration file generator. The letter "S" is missing so arduino reports the problem later.
Regards.
Oki188 is offline        Reply With Quote Quick reply to this message
