Go Back   HeliFreak > R/C Helicopter Support > 150 Class Electric Helicopters
150 Class Electric Helicopters 150 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Like Tree3Likes
Old 05-05-2014, 06:49 PM   #41 (permalink)
Great thread, thanks! it's perfect for a relative noob like me...
Align T-Rex 150 - Align T-rex 450L Dominator 6S - Futaba 14sg
Hobbico Extra 300S Supertigre G75 - AMA #636581
FliHi is offline        Reply With Quote Quick reply to this message
Old 08-06-2014, 12:31 PM   #42 (permalink)
Hi, anyone got some recommendation on the needed hex tools ? A eBay link would be awesome.
Avoid using included tools. They strip the heads,
Instead buy higher quality tools in the sizes below:
0.9mm, (2) 1.3mm, 1.5mm.
oleost is offline        Reply With Quote Quick reply to this message
Old 08-06-2014, 01:52 PM   #43 (permalink)
I would only use MIP Thorp drivers:
http://www.ebay.com/itm/MIP-9012-Tho...item58b333e2c2
http://www.ebay.com/itm/MIP-9013-Tho...item5b03641032
http://www.ebay.com/itm/MIP-9007-Tho...item5afe8a139c
Martin - DX8
180cfx-uBrain-HP20s | Trex150 DFC-HP08-BLHeli | Trex 250 DFC-306g-Belt-DS95i-iKon | Trex450 Sport V2 DFC-DS95i-iKon-Hyperion HS 2221 Kv 4400
mdecker79 is offline        Reply With Quote Quick reply to this message
Old 08-06-2014, 02:38 PM   #44 (permalink)
Didnt find any of them in my country, and listing on ebay it just knocked me above the 30$ limit that I have in my country before I have to pay 25% tax and a 10$ fee
How about this set?
Old 08-09-2014, 03:00 PM   #45 (permalink)
+1 on MIP drivers. x1000 better than anything else. Especially for the small stuff. Once you try them you will never go back.
blbills is offline        Reply With Quote Quick reply to this message
Old 08-10-2014, 03:37 PM   #46 (permalink)
How about this set?
i have that set and they work great for me
goblin 380 bk servos brain2 xnova
blade 230 S, DX7 GEN 2
junior10 is offline        Reply With Quote Quick reply to this message
Old 08-17-2014, 03:20 AM   #47 (permalink)
How about this set?
Just get them from Elefun.no
Nano CPX, 130x, Trex250,
SAB Goblin 380, 500 & 700
Oxy3
- Lynx Team Pilot -
felborn is offline        Reply With Quote Quick reply to this message
Old 09-24-2014, 07:04 PM   #48 (permalink)
Default Landing gear / battery lead
I just bought a 150 and have flown it a few times, the other day I crashed it, bent the main shaft, and that was about it. When it crashed the landing gear came off, (nothing broke) but I noticed how the battery connector is mounted to the gear, and the wire is soldered to the board.
Have any of you had a crash where it tears the wire out?
I was thinking about maybe putting a little deans connector inline as a break away point in the wiring. I would like some of your thoughts or suggestions on this, Thank you!
Where's my heli, where's my heli? Oh no!!!!
Fall2Fast is offline        Reply With Quote Quick reply to this message
Old 09-24-2014, 08:26 PM   #49 (permalink)
Its a pretty big wire with big solder points. I think I've "tested" that enough and I'd say its not going to tear off the MRS. The battery tends to eject if its a violent crash anyway.
Nano CPX Factory BL Lynx Stretched(x4) MCPX BL Lynx Stretched(x2) 130x(x3) 180 CFX(x2) 300 CFX(x2) HK250 (x2) Trex 450 Plus DFC BeastX Align Trex 450 Pro DFC BeastX(x2) Walkera V120D02s
ToddMcF2002 is offline        Reply With Quote Quick reply to this message
Old 09-25-2014, 06:08 AM   #50 (permalink)
Default Feathering shaft
After doing my crash repairs last night, I wanted to install the Lynx LX0932 Ultra dampeners and used an Xtreme feathering shaft. My only decision to use the extreme parts were based on price, you get 3 for a low price.Upon installing the feathering shaft I just barely tightened the screws and stripped one out, and I mean barely, luckily the parts came with 3, so I just snugged the next one down more carefully. Do any of you prefer any particular upgrade on the feathering shaft?
Old 10-27-2014, 03:16 PM   #51 (permalink)
Are there replacement tail fins for the metal tail motor mount? I've broken the carbon fin again and don't want to purchase a 3rd metal motor mount just for the carbon fin that comes with it.
http://www.aligntrexstore.com/150-Me...XX_p_2705.html
Edit. Should have known that Dylan would have them. Hopefully it fits the align branded motor mounts.
https://astroid-designs.myshopify.co...il-motor-mount
bain64 is offline        Reply With Quote Quick reply to this message
Old 11-12-2014, 04:09 PM   #52 (permalink)
Default TREX 150 FAQ + Mod List
Sorry wrong form
mattbeau is offline        Reply With Quote Quick reply to this message
Old 11-24-2014, 09:48 PM   #53 (permalink)
Sorry
Old 10-05-2015, 06:55 AM   #54 (permalink)
Default Replacing blades on T-REX 150 DFC
Sorry, probably wrong thread.
vmsda is offline        Reply With Quote Quick reply to this message
Old 08-25-2018, 08:52 AM   #55 (permalink)
Hello everyone.
I just purchased a T-Rex 150 dfc and having a problem I've never seen before.
When I throttle up with positive or negative pitch the servos will not return to neutral by themselves. Makes it almost impossible to hover.
Any help would be much appreciated.
Cadre1971 is offline        Reply With Quote Quick reply to this message
Old 08-25-2018, 11:42 AM   #56 (permalink)
One of my 150s has metal gears in the servos (are these still available?)
For the other I have bags of the plastic gears. In fact one of the 150s is on the workbench in need of a gear set replacement today.
Even with a 'servo saver' mod to the control arm, after a few crashes the plastic gears can still strip. And even with the metal gears, there is still one tiny plastic gear in the set and I stripped that once.
Micros: Hisky HCP80, ESKY 150x,K110, Trex-150X x 2 Mid: Oxy 3 T 2018 Version, Oxy 4 360 Big: Trex-500X, Oxy 5, Trex-550X, Trex-700X Scale: MD500 TOW Defender (Trex 500 size) Vintage: Trex 450 SE V2
ic-racer is offline        Reply With Quote Quick reply to this message
Old 09-04-2018, 06:16 AM   #57 (permalink)
Thanks for taking the time to put this together. It will be very useful for many, I am sure.
barrytindall3212 is offline        Reply With Quote Quick reply to this message
Tags
150, faq, mod, trex
