Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite)
Blade Helicopters (eFlite) Blade Helicopters (eFlite) CP, CX, mCX CX II, CX III. and others
Like Tree43Likes
Old 04-05-2020, 01:24 PM   #141 (permalink)
Originally Posted by navigator2011 View Post
I changed my battery connector to an XT30 and use Tattu 450mah 75C packs. Works great!
Are u using the stock canopy with the 75c packs. I am goin to stick with the jst connectors for now. I dont have the stuff to solder. I got some nano-tech 65c packs for 8bucks dont seem like a bad deal
Sent from my SM-G970U using Tapatalk
derrickfosgate is offline        Reply With Quote Quick reply to this message
Old 04-05-2020, 06:53 PM   #142 (permalink)
Yes, stock canopy. I just made the post holes a bit longer. Alternatively, the Fusion 180 canopy provides a lot of extra room on the 150s.
derrickfosgate likes this.
navigator2011
Fusion 180 / Blade 150S / OMP Hobby M2 & M1 / TBS Tango 2 / Radiomaster TX16S.
Navi's Channel / Navi's RCGroups Blog
navigator2011 is offline        Reply With Quote Quick reply to this message
Old 04-08-2020, 01:41 PM   #143 (permalink)
today i had a strange tail issue. I flew my 1st lipo and after 4min the tail/the heli suddenly startet to spin around like crazy!! It was super fast and i couldn‘t manage anything...after about 5 secounds the spinning stopped and the 150s was stable again.
Do you know what happend here? Anybody had the same issue? I use a blade 230s tailrotor and a „heavy“ 700mah turnigy lipo. could the tail been overloaded because of the heavy lipo and the bigger tail rotor?
nelsonprinz is offline        Reply With Quote Quick reply to this message
Old 04-09-2020, 08:12 PM   #144 (permalink)
Anybody put an IKON micro in this yet?
I have a 150S on the way and kind of want to put the IKON in it right off the batt...
navigator2011 likes this.
Goblin Raw 700,Kraken 700 Nitro,Kraken 580,Kraken 700,Kraken 580 Nitro,OMP M2
swash-addict is offline        Reply With Quote Quick reply to this message
Old 04-10-2020, 01:37 AM   #145 (permalink)
I heard there was another incident from RCgroup but root cause was not found. And he could not reproduce the issue after that. So reason remains unknown...
Maybe double check all connections first to see if there’s any plug came loose...?
HumanYeung is offline        Reply With Quote Quick reply to this message
Old 04-10-2020, 01:39 AM   #146 (permalink)
Yes, someone already tried to put a micro brain/ ikon on it (OP to be specific)
But the stock FBL is totally fine for its job.
Old 04-10-2020, 06:27 PM   #147 (permalink)
Thanks!
Was curious Because
I like to use My "spare/Sim " radio (DX8 GEN1) for micros. It just seems as if IKON set up may be easier and more consistent to adjust/use rather than making the new AR unit work on an older radio ??
Old 04-10-2020, 10:37 PM   #148 (permalink)
You’re totally fine with stock 150S FBL using DX8 gen1 as someone has already done so.
Have a look in the new 150S sub forum for more!
https://www.helifreak.com/forumdispl...35#/forums/535
Old 07-25-2020, 07:01 PM   #149 (permalink)
Hey guys I was planning on putting a micro spirit in the 150s this week and was curious since to my knowledge there's no governor or ESC telemetry available what throttle% you would recommend for low headspeed that would allow for light 3D. 75% is fine but feels a little too much at times, like managing collective
Archany is offline        Reply With Quote Quick reply to this message
Old 07-26-2020, 09:16 PM   #150 (permalink)
Perhaps the tail esc went into temperature or over current protection.
Amp
Ampdraw is offline        Reply With Quote Quick reply to this message
Old 07-28-2020, 03:10 PM   #151 (permalink)
Default Blade 150s
I put in a uSpirit and Jeti receiver in mine this past weekend (...just because ) and i'm about 3/4 of the way through the setup. If you get yours running i'd like to compare notes. I was able to get the main and tail ESCs to arm and respond, but I cant get the tail calibrated properly. Rudder endpoints go from barely moving to "holy crap its going so fast the motor will burn out" without much consistency as far as i can tell
tamupino is offline        Reply With Quote Quick reply to this message
Old 07-28-2020, 08:37 PM   #152 (permalink)
I think you have set the uSpirit up to use motorised tail (Rudder - Control type to Motor)right...?
And I remember if you use motorised tail, end point would be sth around 126 to 150...just some thoughts.
And there is a note on using Low RPM on motorised tail in manual...not seen before. Maybe new features after firmware update.
Old 02-01-2021, 07:07 PM   #153 (permalink)
Anyone have the setting for dx8 gen2 to quit the safe thing and put in a switch and Bail out in other more accessible????
Im old use of dx7 gen 1 and upgraded my radio but isnt so easy for me use the new one.
Im using the manual config but normal mode is like a rock to move and i like 2 IU modes .
Regards!
javier668 is offline        Reply With Quote Quick reply to this message
Old 02-02-2021, 06:52 PM   #154 (permalink)
Default Blade 150s
In manual the flight mode and gear channel are on the same switch. You can assign another switch to gear channel.
Channel value of +100 turn on SAFE, and any value equals or less than 0 turn that off.
You may also come to have a look in the 150S forum too.
Blade 150s
https://r.tapatalk.com/shareLink?sha...ink_source=app
