Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > mCP X BL
mCP X BL Blade Micro mCP X Brushless
Like Tree58Likes
Old 08-01-2019, 02:52 PM   #1 (permalink)
Default New BL finally happening ?
https://www.facebook.com/watch/?v=484309525724154
t_austin likes this.
brokeheli is offline        Reply With Quote Quick reply to this message
Old 08-02-2019, 01:57 AM   #2 (permalink)
Credit card is itching to go!
nickthenorse is offline        Reply With Quote Quick reply to this message
Old 08-02-2019, 02:25 AM   #3 (permalink)
it's about time. hope this one is better!
Brandon Chew aka ~INDO~
Team Lynx / Oxy Heli
Oxy 2, 3, 4, 4Max, 5
plus many others 420 and under
Indokast is offline        Reply With Quote Quick reply to this message
Old 08-02-2019, 03:35 AM   #4 (permalink)
Hopefully they don't mess it up with SAFE
Team USED
Shape S8,G700,G500,Shuttle 550,Trex 500 E/EFL Pro,Oxy 3(2),B400(5),450X,360CFX,Fusion 270(2),230S (V1/V2),200S,120S,Nano (CPS/S2),K110/120/130
BrokeDad is online now        Reply With Quote Quick reply to this message
Old 08-02-2019, 03:55 AM   #5 (permalink)
i just hope the tail don't shake like some girl on the dance floor. and no glitchy esc/rx. one crash into branches of a tree on first or second flight and my only mcpx bl went twitchy on the esc/rx and i threw it in the trash. pretty much how that went. had potential but that sucked. 130x never did that nor xk k110 despite many bad wrecks.
had great power to weight ratio tho. if it lasted I can see why people loved it.
Old 08-02-2019, 12:25 PM   #6 (permalink)
My two MCPX-BLs have been pretty much trouble-free since I bought them.
I hope that they do not start reading this thread and getting ideas.
Indokast likes this.
130X parts wanted! The Precious! You has the Precious!
Mrowka is offline        Reply With Quote Quick reply to this message
Old 08-02-2019, 03:15 PM   #7 (permalink)
seems most people had a good run with them and want it brought back. It would be a good seller for sure. I just got unlucky. same thing happened to an xk k120 I had. I smashed the 130x hundreds of times and the esc/rx just took it all np. Once it fell about 50 feet out of the sky and landed in rock hard dirt over a field and i picked it up and flew it again lol.
Old 08-02-2019, 04:52 PM   #8 (permalink)
Can’t wait! I’ll be first in line to order one if they release a good successor to the original BL. Hopefully they do NOT cripple it with SAFE or SAFE-Z.
Chris1683 is offline        Reply With Quote Quick reply to this message
Old 08-02-2019, 09:11 PM   #9 (permalink)
Very cool! I’ve only heard good things about the original version. Never flown one though.
Question. Mentally I have always separated the SAFE features (Stability mode and rescue) from the usual 3-axis stabilization gyros that are on all modern FBLs. So that when I go into 3D mode and don’t hit rescue I’m not using any SAFE technology.
Is this correct?
I ask because I assumed that the less agile flying we saw in the CP S/S2 as compared to the CP X was due to the 3-axis stabilization software (probably some internal expo too) and not SAFE. If I am flying a newer Blade model with SAFE off, and it still doesn’t fly as good as a previous version that didn’t have the option, it seems like it’d be the regular FBL’s fault and not the SAFE features. Meaning Bremer or whoever programs these made additional changes unrelated to SAFE that made it fly less like the older model.
Or is it just the stability features you don’t want cluttering up the programming? Honest questions. Im curious.
Assuming I’m right, I don’t care one way or the other I’d it has SAFE, so long as it’s as good as you all say the original one was!!!I Oh, also crossing my fingers that they actually test their flight control software to make sure that throttle hold actually holds the throttle. Low bar!!
Thomas.Heiss likes this.
Brian ó Oxy 2, EOX 1911-3600kV, YGE 35LVT ó Oxy 4 Max, EGODRIFT 3220-900kV, YGE 65LVT ó XK K110 ó Spirit FBL ó Horus X10S, OpenTX 2.3.9 ó
Last edited by xoexoe; 08-02-2019 at 09:15 PM.. Reason: Jeez autocorrect, get smart. Do you think I meant “I’ve inky” or “I’ve only”.
xoexoe is online now        Reply With Quote Quick reply to this message
Old 08-02-2019, 10:19 PM   #10 (permalink)
I always found that the original models from Blade which did not have SAFE flew better and with more agility. Every model which got replaced with a SAFE version I feel like was a step down. Again, this is just my opinion base on the models I have flown over the years. I know Blade just wants more models to appeal to more buyers but SAFE should be reserved more for the beginner friendly models which the BL certainly was not.
Old 08-02-2019, 10:22 PM   #11 (permalink)
And if you watched each SAFE release...the model went from Advanced to Intermediate
nCPX(3)*mCPX(25)*130X(10)*130X-L(6)*180CFX(3)*300X/CFX(3)
450X(7)*470LP*GauiX3*nanoQX*180QX*DX9*HF180060*AMA 988253
Old 08-02-2019, 10:46 PM   #12 (permalink)
when i had a 230s you could put stability on a separate switch and have normal flight modes otherwise. it effectively turned safe off but you still had rescue. im ok w that.
Old 08-02-2019, 11:02 PM   #13 (permalink)
Iím with you there. I think Chrisís experience suggests that with the SAFE option, whether itís used or not, comes other changes to the FBL that affect flight performance in a negative way. So even if you set channel 5 to -100 (safe off) it still didnít fly the same as before.
Old 08-03-2019, 07:27 AM   #14 (permalink)
On such a small and light heli like the BL, I don’t think that rescue is as important as it would be in a heavier full-sized model. I’ve dumped my BL’s into the ground over and over and they just keep taking the punishment. Sure it’s always nice to have more features but it’s like anything else in life, the more stuff there is the more stuff that can go wrong.
Either way, I’m excited to see what comes!
xoexoe likes this.
Old 08-03-2019, 08:22 AM   #15 (permalink)
Even with stability and rescue off you are still in AS3X mode on the helis with that FBL so there is still some tiny bit of control it's doing. In the RF8 simulator you can select a manual mode over a AS3X mode but I don't think you can IRL. If I'm wrong I'm sure someone will point it out.
Team USED
Old 08-03-2019, 12:30 PM   #16 (permalink)
Anyone know the typical timing of HorizonHobby as far as teaser Ė> announcement Ė> release?
Old 08-03-2019, 01:22 PM   #17 (permalink)
On such a small and light heli like the BL, I donít think that rescue is as important as it would be in a heavier full-sized model. Iíve dumped my BLís into the ground over and over and they just keep taking the punishment. Sure itís always nice to have more features but itís like anything else in life, the more stuff there is the more stuff that can go wrong.
Either way, Iím excited to see what comes!
Lol they put it on the Nano. They will 100% put it on the new BL too.
Keith - MSH Brain2 Beta Test Team - KST Heli Division Team Pilot
Specter 700 | GAUI NX5 | Protos 380
FrSky Help Click Here
https://kc3dprint.com - 3D Printing on Demand and Printed RC Helicopter Upgrades
Number is offline        Reply With Quote Quick reply to this message
Old 08-05-2019, 12:21 AM   #18 (permalink)
Finally I can stop posting about a V2 lol �� Hopefully piro comp and no safe. Love my XK K110's and just picked up a K130 that may be decent. I still have a BL so hopefully there will parts compatibility.
I will purchase V2 for sure though!
EDIT... HH flew it at IRCHA. Did anyone see it and have info or pics?
CrashyCrashy
CrashyCrashy is offline        Reply With Quote Quick reply to this message
Old 08-05-2019, 10:29 AM   #19 (permalink)
https://www.3dextratime.eu/products/...nt=31457074441
mytdbm is offline        Reply With Quote Quick reply to this message
Old 08-05-2019, 10:51 AM   #20 (permalink)
That's definitely just a copy-pasted description from the V1. The only part that says V2 is the title. And the pictures are the same. I doubt that's a V2 page... It's too early.
CrashyCrashy and xoexoe like this.
