Like Tree1Likes
Old 08-30-2019, 03:39 PM   #1 (permalink)
Default Quick transatlantic spruce-up
I recently bought some bits on HF from FNFAL, and have just got around to giving my M-P a quick make-over.
New Lynx head from Steve, changed FBL and installed FRSky Rx to move the heli onto my QX7 from my DX7, it's only taken about 5 flights to tweak the different FBL and she's now flying beautifully after the update
Thanks Steve
Name:	MP Lynx head.jpg
ID:	812209   Click image for larger version
Name:	MP Lynx head 2.jpg
Old 09-03-2019, 01:08 PM   #2 (permalink)
Next thing sorted - for a while my M-P has had a tail "shimmy", not as bad as a wag, but just a gentle wave side to side about once per second about 3/4" (20mm).
On investigation I remembered that there was a fair amount of slop in the mechanism (it's pretty old now and has had lots of abuse) at some stage I had replaced the tail slider lever with a Lynx version and what has happened is that the 2 little bolts that go through the lever and fit into the ring had worn - they are 1.84mm thick on one dimension, but only 1.4mm on the worn side. What happens is that the ring is on the tail slider and turns with the slider acting as a grinding wheel on the pins (even though it is mounted via a bearing).
I had a spare lever from Lynx's sale, but thought that I would try something as a long-shot - I removed both bolts and fitted them in the other hole - they were both at 90 degrees to their previous orientation and back to minimal slack
I've also put a dollop of Araldite (it's epoxy - like JB Weld) so that now the ring will stay stationary but the shaft will turn on the bearing inside the ring. Anyway - the shimmy has now gone - the tail always held fine but now the shimmy has gone also.
Next step - some telemetry...
Old 09-03-2019, 08:55 PM   #3 (permalink)
Not sure where you put the epoxy but good job!
Please don't confuse my experience with pessimism!
Protos 500, HCP100S, Raptor 50, many more!
babyuh1 is offline        Reply With Quote Quick reply to this message
Old 09-04-2019, 02:24 AM   #4 (permalink)
Thanks - here you go - the shiny bit that I have highlighted, in the ring. Now the epoxy press against the pins stops the ring from rotating.
Name:	Tail slider M-P.jpg
Old 09-04-2019, 09:09 PM   #5 (permalink)
Interesting! I have one of these that I'm going to resurrect this winter.
Thanks!
Old 09-05-2019, 01:47 AM   #6 (permalink)
Thanks!
Excellent - I look forward to hearing about it
Old 09-08-2019, 12:49 PM   #7 (permalink)
Telemetry a go-go
I have been using a FrSky Taranis QX7 for about 6 months or so - one of the reasons that I moved some of my models on to the QX7 is that as well as low-cost receivers and sensors it is very easy to add external sensors as well.
I have been using Arduino boards with some software developed by DAnielGA https://www.helifreak.com/showthread.php?t=835243 it started just using data output from the HobbyWing ESCs, but Daniel has also added PWM inputs so it can be used with any ESC even without an RPM output.
The Arduino Nano costs about $2 each, plus some resistors (about 20c each) and if you need the Phase Sensor another $4, the Nano + Phase Sensor + reisistors and wiring weighed in at 9 grams. Basically the Arduino reads the voltage from cables connected to the battery leads, and the phase sensor connects onto 2 of the motor leads.
I now have readings for battery volatge and headspeed on my Tx screen, plus I have a telemetry rule that speaks the battery voltage level every 6 seconds once it is below a set level for 4 seconds.
It's not my tidiest wiring, but I'll tidy it up shortly (probably )
ID:	813897   Click image for larger version
ID:	813899   Click image for larger version
Name:	Arduino installed.jpg
Old 09-09-2019, 10:34 AM   #8 (permalink)
Hi M,
That Lynx topper looks good. The DFC flies more crisp IMHO, but is less forgiving. Best for more developed pilots like yourself. Also, I did notice somewhere along the timeline, MSH must have changed the inside swash balls. P/N is the same but post profile is different. In fact, at certain accumulative (cyc+col) the new left ball allows the rod-end more freedom...especially with the DFC.
Rotormantic - Goblin 770(14S), Trex 550E(8S), Mini Protos Stretch(6S)
FNFAL is offline        Reply With Quote Quick reply to this message
Old 09-09-2019, 01:38 PM   #9 (permalink)
Originally Posted by FNFAL View Post
Hi M,
Yeah - I like how the DFC flies, my other stretched M-P already has the Lynx head and I have loads of spares for it from the Lynx sell-off .
I had forgotten about the change - that photos shows the difference, I was just lazy and kept my old swash on there so I'll have a look at my balls
Old 09-28-2019, 12:59 PM   #10 (permalink)
Next installment ...
I've put about 20-odd flights on the M-P recently and noticed on Friday that the motor was very rough - after stripping it down it turns out that the top bearing has disintegrated
I tried putting in a new bearing, but it seems that the bearing holder is a little distorted after installing a new bearing the motor is still very rough and it appears that the magnets are hitting the poles.
The closest suitable motor that I have is a 6S 1700 SK3 motor that was in my Tarot 450Pro, I have fitted the long motor shaft from the 6S MSH motor (fortunately both the same shaft diameter), and fitted my Lynx solid pinion. Only flown it in the garden so far to reset the Gov Store - but it seems to be fine ...
Name:	new motor.jpg
Old 09-28-2019, 08:59 PM   #11 (permalink)
Although the stock 6S motor can "get by", for whatever reason, motor temperatures IMHO are too high for the long term...no matter settings or loads. I've noticed that with some Scorpions motors, they just don't run as efficient at they like to boast - converting precious power into heaters. These higher temps then are cooking the bearings and shortening life.
I will be posting soon the move to the Xnova 2618 motor that can still be found with the "B" Protos shaft at some vendors. I will also avoid the 2520 from Scorpion due to some finicky behavior with some common escs.
Old 09-30-2019, 12:50 PM   #12 (permalink)
So had a quick trip to the field, and I'm very happy with the new motor - running at 71% / 75% / 79% I get 2900 / 3000 / 3100 headspeeds, spot on for what I want...
Old 09-30-2019, 01:14 PM   #13 (permalink)
Always glad to see working solutions to keep these things flying. Amazing the shaft switched-over with ease - lucky. Also impressive the 1700kv motor is allowing to hit your targets.
Old 09-30-2019, 02:57 PM   #14 (permalink)
Thanks Steve - really pleased. Gonna have a good look to see if anyone still has the Lynx pinions for sale, might grab a spare ...
Old 11-17-2019, 01:27 PM   #15 (permalink)
I was out flying yesterday and my tail got caught against a tuft of grass and snapped the tail fin and broke the tail slider. I had been thinking that it was about time that the tail got a bit of attention anyway, so instead of just replacing the broken bits I have installed some of the Lynx upgraded parts that I got in their sale (see above).
So I now have the aluminium tail case, upgraded slider, upgraded tail rotor arms and the aluminium lever - I would have preferred black rotor grips but these were all that they had when I got to the sales . Oh and the tail case came with an different fin, so that is on to replace the broken one.
I'll probably stick some flouro tape onto the fin - but here we are so far....
Name:	Tail side 2.jpg
ID:	826505   Click image for larger version
ID:	826507   Click image for larger version
Old 11-18-2019, 01:34 PM   #16 (permalink)
Nice tail - and I mean that in the most hetero way possible. I think the two-tone looks fine. Hell, I even did a three-tone once (silver, black, red). Keep an eye on the axial spacers if you had to use any. They are soft and do get squished. Give the tail shaft an axial wiggle from time to time to see if there is any axial play. Some of my play actually was from some cross-pin clearance.
So I like to use the metal MSH pulley and put some green Locktite to tie-together the whole tailshaft assembly with the shaft, pulley, cross-pin and sleeve.
Old 11-18-2019, 01:41 PM   #17 (permalink)
I checked the side-play and put in 3 shims, I'll keep an eye on it. I realised half-way through that the old tail had / has the aluminium tail pulley - I might have to swap it back in at some stage...
Old 11-19-2019, 10:57 AM   #18 (permalink)
After flying the stock tail for so long, do you notice any differences with the Lynx one?
Old 11-19-2019, 11:11 AM   #19 (permalink)
Yeah - it's wagging a lot more now
Just need to check whether there tail is binding slightly or if the servo is struggling after it's fight with the ground
Old 11-19-2019, 11:31 AM   #20 (permalink)
Just a hunch, try turning down the gain first.
