Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > 360CFX
360CFX Blade 360 CFX Helicopters Information and Help
Like Tree14Likes
Old 09-30-2019, 06:37 AM   #21 (permalink)
Of course it allows to set gear mesh. The motor support can be mooved foward and backwards, when you loose the bolts on the left and the right side where the motor support is fixed in the Frame.
The_Fox is offline        Reply With Quote Quick reply to this message
Old 09-30-2019, 07:01 AM   #22 (permalink)
Attachment 818415
Oh nice - well - I will check the gear mesh, but as far as I can tell its ok. I would think if that was the problem, then it would act strange when spooled up without blades on yes?
Spektrum DX8G2, AccuRC Simulator
Blade Scout CX, MSR S, Nano S2, 230s V2, 360CFX, NanoQX
Oxy 4 MAX, 2 (215)
SAB Goblin 500 Sport
Old 09-30-2019, 09:26 AM   #23 (permalink)
About the blade tightness.. I still recommend playing around with it. Mark one of the grips so you can tell them apart, and then loosen one side maybe 1/16th of a turn and try spooling up again. If it gets better continue loosening that side. If it gets worse do the other side.
xoexoe is online now        Reply With Quote Quick reply to this message
Old 09-30-2019, 10:05 AM   #24 (permalink)
I agree that it must be some problem with the blades at this point. Perhaps I had them too loose (I do recall thinking that they were looser than usual).
Oxy 4 MAX, 2 (215)
Old 10-02-2019, 07:02 PM   #25 (permalink)
Just loosen the two motor screws on each side of the fuselage and adjust. There is a slight slot in the fuselage screw hole that allows for gear mesh adjustment.
PHXScorpion is offline        Reply With Quote Quick reply to this message
Old 10-03-2019, 11:04 PM   #26 (permalink)
Two things i want to tell: all stock main gears are unround. I changed to Lynx Heli main gear. It's milled on CNC mill, perfectly round. 136 T, really. The "136T" Blade Main Gear has 135T.
I had vibrations caused of wornout main bearings. Changed them, and thought why don't change spindle aswell. Vibrations keept persisting. Startet to interchange everything from my second 360 and It turned out: the brandnew spindle was bent. Changed it, there are allways two in a pack - no more vibrations. So be aware: brandnew parts can be faulty aswell.
I just received my Lynx gear and it is even more out of round than the blade one was. Very noticeable when spinning and one side of gear mesh is tight and other side loose. Very disappointed. I'm going to pull it out and caliper it to see how far off it is. I got two gears from them so will check the other one too. Not what I usually get from them.
Old 10-04-2019, 11:36 AM   #27 (permalink)
Wowee, that's disapointing! I was just going to order some of their drive gears today.
I've also thought about chucking up the stock gear in my lathe, and truing it up. Of course that would only change the OD of the teeth, leaving some longer than others. Maybe worth trying, though.
Trex 700X, Trex 250, Blade 230v2, Blade 360CFX 3s, Blade 450 3d, JR Vigor 700, Mavic Air
Low_Cal is offline        Reply With Quote Quick reply to this message
Old 10-04-2019, 11:58 AM   #28 (permalink)
I don't think the gears are terribly out of round. I've only ever chewed up teeth when I crashed. Every crash. 360cfx seems to eat main gears in a crash. But thats ok .. they are only like $5 a piece (two in a bag for $10 I believe).
Now - surface wise - Traxxas - I've had WAAY more problems with main gears... especially on high torque models such as the e-Revo.
Feathering wrench is at my house according to USPS. I'll be able to reassemble tonight - YAY ... hope to get out to the field tomorrow to test.
Oxy 4 MAX, 2 (215)
Old 10-04-2019, 04:16 PM   #29 (permalink)
The Lynx gear is milled on CNC machine - in this case nearly impossible to be unround. Your center hub might be unround, or the mounting holes might be excentrical.
I have two Blade Trio 360cfx, and in both running the Lynx gear. Both run round...
My Helis: https://www.helifreak.com/album.php?u=238607
Old 10-04-2019, 06:42 PM   #30 (permalink)
Well i put a caliper on it and it is out of round for sure, cnc or not! The other one i got from them looks right on, so i will put that one in and see if the gears mesh correctly.
Old 10-04-2019, 07:36 PM   #31 (permalink)
Yup, other lynx gear is perfect. Got great gear mesh, doesn't visibly wobble side to side when running, and my tail wag is almost completely gone. Vibrations good level too.
So now I will contact lynx and see about exchanging this turd for a good one.
Old 10-05-2019, 04:39 AM   #32 (permalink)
ok - its back together! Hopefully I can make it out to the field today for testing!
xoexoe likes this.
Oxy 4 MAX, 2 (215)
Old 10-05-2019, 05:23 PM   #33 (permalink)
Well .. it flew OK. The vibration has settled down some. Its still there tho during spool up. I am going to put some tape on the blade tips and make sure the blade tracking is correct .... also mess with the blade tightness.
THat is... after I fix it. I made a crappy landing and managed to break off one of the tail rotor pitch arms (and take a chunk out of one of the tail blades) ... stupid ... made me angry
Oxy 4 MAX, 2 (215)
Old 10-05-2019, 05:34 PM   #34 (permalink)
I've never had any issue with mine. I still have two 3 blade conversion kits, AL tail case, and dual bearing AL swash never used. I always land in a spot that is free from even much grass (it's mostly moss). The 270 is particularly sensitive to landing as the big 450 sized tail blades have little clearance the vertical fin affords them.
My two 360 belts are now in Oklahoma. It's weird HH still lists them as backordered. It was also strange they shipped out of CA instead of IL like normal. Maybe this week they will update their web pages as it's used on the Fusion 360 also. I just wanted them as spares.
Team USED
Shape S8,G700,G500,Shuttle 550,Trex 500 E/EFL Pro,Oxy 3(2),B400(5),450X,360CFX,Fusion 270(2),230S (V1/V2),200S,120S,Nano (CPS/S2),K110/120/130
BrokeDad is offline        Reply With Quote Quick reply to this message
Old 10-05-2019, 05:38 PM   #35 (permalink)
Heh - The only issues I've ever had are self inflicted I'm pretty sure. I don't think any of them are the fault of the helicopter. Today's bad landing was definitely my fault.
Oxy 4 MAX, 2 (215)
Old 10-07-2019, 12:12 PM   #36 (permalink)
The landing gear is pretty whimpy. I put different gear/skids on mine, from a much larger combusiton powered heli (Hirobo Concept 30). The gear is wider and stronger. At least until I work out the problems with the heli. Guessing that has saved me from a broken frame several times now. The oversized gear doesn't stop it from looping or flipping - plenty of power.
I broke the plastic tailcase on my 360CFX last week, in a forced auto rotation landing. I've got an aluminum tailcase, pitch slider, and control arm on order from Microheli.
Old 10-07-2019, 12:18 PM   #37 (permalink)
Better landing gear wouldn't have saved me ... I have a wooden platform I take off from. I land on it usually too ... however, its slippery so if you don't set down right, it will slide off ... its tall enough that if done right you can contact the tail. I think, going forward, I'll just take off from it and land in the grass.
Oxy 4 MAX, 2 (215)
Old 10-07-2019, 12:24 PM   #38 (permalink)
Interested in that but what about the extra weight throwing off the cg? Seems tail heavy like most of my blade helis and adding weight at the end of the tail would have a negative effect I would guess??
Old 10-08-2019, 04:55 PM   #39 (permalink)
Not the tail skid, just the main landinger gear legs and tube "skids" that attach to them on the bigger helis. I busted this landing gear in the last "incident", and no more Hirobo Shuttle parts available. So thinking of putting Trex 700 gear on it this time.
My Blade 360 3s balances perfectly, with a 3300mAh 3x pack.
Old 10-08-2019, 05:01 PM   #40 (permalink)
You can still get Hirobo Shuttle parts from Japan just FYI although I'm guessing it's not worth it if you can source something else.
Team USED
