Go Back   HeliFreak > R/C Electronics Support > HobbyWing ESC's
HobbyWing ESC's HobbyWing ESC Support
Like Tree23Likes
Old 04-25-2020, 02:30 AM   #61 (permalink)
Originally Posted by andypaddlerking View Post
hey guys
my esc was new about a month ago!
i emailed align and their engineer sent me a new link to the updated firmware using the asbox software. i suggest you do the same if you need it.
Hi Andy,
which email address you sent to get updated firmware? I'm going to do same
Kgnx is offline        Reply With Quote Quick reply to this message
Old 05-01-2020, 01:53 PM   #62 (permalink)
Do you know if there is an update yet for the Platinum HV 200 OPTO V4?
I just updated the time on my original V-Control (non-touch) and downloaded the HW app from V-Stabi, but have not powered up the ESC/heli since last fall.
Once the new HW software is available for the older v4 HV 200 ESC, Ill update it.
I do want to make sure there are no issues, as I thought Id recently read about an ESC going dead or catching on fire after a firmware update.
Thanks!
Originally Posted by reco_very View Post
Not available at this time.
it's written on HW FB
"Platinum HV 160A V4 & Platinum HV 200A OPTO V4 ESCs are not compatible with the current telemetry system yet, update will be available very soon"
Old 05-03-2020, 02:36 PM   #63 (permalink)
Default Need some help with HW/vbar
Hey all,,So ive loaded the HW 4. into 4.0.07 v-bar software into my 120A v4 esc..Ive also loaded the hw app into my v-control radio (non touch)..
I have the cable from the esc to the v-vink but..when powering up the setup,there is NO HW incon showing on the radio???
Am i missing something here?? ty for any help
hawkeye690 is offline        Reply With Quote Quick reply to this message
Old 05-03-2020, 04:23 PM   #64 (permalink)
New to HW integration... what changes can I make to the ESC via the integration? I'd like to change the Start Power.
(2) Protos Max Leggero/VBarNeo/Tribunus200/Xnova/VTX717;rEVO715, Logo 200, VBar Control Touch
Caeguy is offline        Reply With Quote Quick reply to this message
Old 05-03-2020, 04:51 PM   #65 (permalink)
I would try the latest FW (04.0.08). I think the .07 is only working for vbct and burning 130a V4's.
@caeguy
The HW integration is only oneway. So only telemetry - no changes to esc.
Netzferatu is offline        Reply With Quote Quick reply to this message
Old 05-04-2020, 01:53 AM   #66 (permalink)
Originally Posted by Netzferatu View Post
I would try the latest FW (04.0.08). I think the .07 is only working for vbct and burning 130a V4's...
... only valid for 130a V4 - w/ 120a V4 .07 is OK... every ESC has it's own 'latest' version number. can be easily checked here: revision history
Ciao
Michael
Netzferatu likes this.
our hangar: minicopter & Logo helis, YGE/Egodrift/Spirit/Futaba BLS/Jeti
Rabid121 is online now        Reply With Quote Quick reply to this message
Old 05-04-2020, 07:10 AM   #67 (permalink)
Well after going back and looking at at the firmware,I reloaded it and now its working...I think when doing it the first time,I forgot to click on (send to ESC).seems its all working now..I will keep a eye out for the 4.0.08 firmware and look for any changes.
Excited to get my new oxy 5 in the air for the first flite,,
Old 05-06-2020, 10:55 PM   #68 (permalink)
Just updated the 40A V4 esc with latest v-bar firmware. The only issue I had was it reset the esc to all the factory default settings. Other than that, the Hobbywing telemetry seems to work fine sofar on the Vcontrol touch. This is the first esc I added the vbar firmware to, thought i'd try it out on the cheapest one first lol.
Not sure if this commonly happens when doing a Hobbywing firmware upgrade? I've only updated firmwares, if available, when they are brand new out of the box, and before I set my values.
So my advise... Take the 2 minutes to write down all your values in the HW usb link program tabs, Before you do the upgrade!
snapon86x is offline        Reply With Quote Quick reply to this message
Old 05-06-2020, 11:46 PM   #69 (permalink)
motor pole count is in the fbl, not the esc.
all hobbywing esc's revert back to default settings when doing an update.
tonys-heli is offline        Reply With Quote Quick reply to this message
Old 05-07-2020, 01:29 AM   #70 (permalink)
So what are your settings in the esc for pole count and transmission? I had set them according to specs, but now have trouble with the values in the vbar.
Old 05-09-2020, 10:04 AM   #71 (permalink)
Anyone have the link for the software? All I could find on the HW website was 4.07 and it doesn’t give me the option for the Vbar software on my v4 40. I’ve downloaded 4 different versions from both of the Hobbywing websites with no luck.
Gscott is offline        Reply With Quote Quick reply to this message
Old 05-10-2020, 02:41 PM   #72 (permalink)
Finally figured it out. The database files in all the versions currently posted are out of date. If anyone else is having the same issue you will need to download the current database file using the link below. Extract the files and copy them to the Hobbywing program directory on your PC and replace all existing files.
https://www.hobbywing.com/Upload/sof...2020-03-25.zip
Old 05-11-2020, 09:38 AM   #73 (permalink)
Default hobbywing up load
gscott im very excited that you found a link
I've been working on the same thing as well
but the link is not working
where on the hobbywing web sight did you find it ?
thanks Joel
mtnxtreme1 is offline        Reply With Quote Quick reply to this message
Old 05-11-2020, 10:37 AM   #74 (permalink)
The Hobbywing site sucks. It’s so slow it took me all day to finally get the download. I copied the zip file to a shared drive. Try this link.
https://www.dropbox.com/sh/s2hbw77bn..._nNraSLKa?dl=0
Old 05-15-2020, 04:58 PM   #75 (permalink)
Does anybody have it running on a VbarControl Classic ?
Oxy 4max, Logo 600 SX, Goblin 570 Sport, Goblin Black Thunder Sport
hubmod is offline        Reply With Quote Quick reply to this message
Old 05-17-2020, 01:04 PM   #76 (permalink)
Default vbar classic
yes the vbar classic is working dident work last week
go to hobbywing us web sight email the tec department they will send you a link unzip the down load double click on the file it will open in the hobbywing
icon it will upload there are two files
I don't know what operating system your using
im using windows 10
you will need to make or by a telemetry wire for the neo to see the hobbywing will not see the hobbywing untill the telemetry wire is pluged in and turn the raido and then neo on
that been my experance with the integration
and yes this is what i've doing to lol then all smiles
hope this helps thanks Joel
Old 05-17-2020, 01:44 PM   #77 (permalink)
I forgot you will need to go to vstabi and upload to your raido the app
for hobbywing in the telemetry app
it will not show in esc selection it should show in apps if its there and select it in the raido turn the neo on with telemetry wire pluged into the hobbywing after the vbar firm wear is installed in the hobbywing
you should see the hobbywing then do the set up !!
hope this helps its been a tough road for me as well with lots of help from outhers
thanks Joel
Old 05-17-2020, 05:20 PM   #78 (permalink)
Thanks a lot, I got it working yesterday. Bumpy road for sure. Does anybody kow if the RPMs are also send via the telemetry cable ? Or do I need to connect the RPM Output of the ESC ?
Old 05-17-2020, 07:18 PM   #79 (permalink)
you always gotta connect the rpm out sig wire.
Old 05-18-2020, 04:56 AM   #80 (permalink)
Hi Tony,
it works actually without connecting the RPM cable, just tested it !
