Go Back   HeliFreak > R/C Electronics Support > OpenTX Radios
OpenTX Radios OpenTX Radios Discussion and Support Forum
Like Tree3Likes
  • 3 Post By Number
Old 10-12-2019, 09:02 PM   #1 (permalink)
Default FrSky Tutorials
This thread is made as a resource for those new to FrSky containing my personal FrSky video and written tutorials. For your own or others' tutorials please make another thread. Discussion is welcome but please keep it on topic.
NEAGRON, bjames and xoexoe like this.
Keith - MSH Brain2 Beta Test Team - KST Heli Division Team Pilot
Specter 700 | GAUI NX5 | Protos 380
FrSky Help Click Here
https://kc3dprint.com - 3D Printing on Demand and Printed RC Helicopter Upgrades
Number is offline        Reply With Quote Quick reply to this message
Old 10-12-2019, 09:02 PM   #2 (permalink)
My Repository on GitHub for resources, model images, example models, and more.
https://github.com/BladeScraper-Desi...us-X10S-OpenTX
Old 10-12-2019, 09:03 PM   #3 (permalink)
Default Idle adjustment knob for nitro helis (Text Tutorial)
Originally Posted by Number View Post
On nitro helis it's common to have to adjust your idle speed slightly, usually to make it easier to start. You could just use the trim buttons on the throttle stick, but I prefer an easier way of doing it, as well as an easy way to know when I'm at my neutral (default) idle position, rather than having to look at the trim indicator on the screen.
What I did on my Synergy N556 was use the right potentiometer on the front of the radio to adjust my idle.
First make sure your engine can idle at your current throttle hold setting.
That means that, once this is set up, it will idle with the potentiometer in the neutral detented position. That means you can know for sure that the engine will idle in that neutral position once it's running and/or warmed up a bit.
Create a second mix for your throttle channel, which in most cases, is channel 3. Make sure multiplex is set to "add". Set the input to S2 (pot with detent) and set the weight to 5-15%. The more the weight is set to, the more you can adjust your idle. In most cases, 5% adjustment will be plenty, but I like to rev up my engine a little bit when it's cold (e.g. first start of the day) to warm it up, so I set mine to 15%. Just make sure you don't go higher than around 10-15% weight, so that if you accidentally leave the pot set all the way high, you don't have a hot start. Also, having the weight this low gives you a finer resolution of adjustment.
That's all you need to do. You can go into your channel monitor and with hold on, you can see the idle throttle output change as you move the knob.
https://www.helifreak.com/showthread.php?t=842537
Old 10-12-2019, 09:03 PM   #4 (permalink)
Default OpenTX Tutorial | Synchronizing Between Radio and Companion (Video Tutorial)
OpenTX Tutorial | Synchronizing Between Radio and Companion (12 min 44 sec)
Old 10-12-2019, 09:04 PM   #5 (permalink)
Default FrSky X10S Tutorial | Potentiometer Rudder Trim for Piro Practice (Video Tutorial)
FrSky X10S Tutorial | Potentiometer Rudder Trim for Piro Practice (4 min 52 sec)
