Like Tree8Likes
Old 10-14-2019, 12:08 AM   #1 (permalink)
Default Neo and mAh Consumed Telemetry
Does the mAh data come from the ESC or is it calculated using current and voltage in the neo. The reason I ask I have current have HW ESCís and IKon2 units. Iíve thought about Vbar with the upcoming integration on HW escís but they do not sent mAh consumed. With my iKon2 it is calculated in the FBL unit and sent to my transmitter. I think on the Scorpion ESCís it is done in them. I donít want to upgrade and then loose this once the HW firmware is updated.
Specter 700, Oxy 5, Protos 380 EVO, Logo 200
Vbar Control Touch, Neo's, HW/Scorpion ESCs
micccain is offline        Reply With Quote Quick reply to this message
Old 10-14-2019, 12:34 AM   #2 (permalink)
All done and reported in the ESC or TelMe unit.
VControl
Old hand at Planks
Peter
Old 10-14-2019, 12:43 AM   #3 (permalink)
So unless HW makes mAh consumed reportable then I would not be able to get this unless I swapped to Scorpion ESCís?
Old 10-14-2019, 01:26 AM   #4 (permalink)
Which HW are you using? The 80a v4 and up all have mah consumption. Or maybe misunderstand what you want.
Oxy 2 215- RIP / Oxy 2 215 sport / Oxy 3 Tareq 2018 / Trioxy 3 (aka Qube) / Oxy 4 / Goblin fireball / G380 / P380 Evo / G570 / G-stay tuned / eXo 500 / Jeti DS-12
blarks is online now        Reply With Quote Quick reply to this message
Old 10-14-2019, 01:32 AM   #5 (permalink)
FWIW voltage is not required to calculate mAh consumed.. all that's needed is current (amps) and time...
But as for your question; you might want to make a comment against the Video Kyle Stacy made on the Hobbywing Technology FB page announcing the new Vcontrol telemetry support. He said 'full' integration but didn't go into much detail of what 'full' really means in this context. He didnt mention mAh consumed, or even Amps come to that. This doesnt necessarily mean it wont be available because it was just a brief announcement at the end of his video.
Gob Kraken |Gob 700 BT 'T' | Gob 770 Comp | SoXos Strike 7 | Henseleit TDR, TDSF & TDR2 | Kasama Dune | OMP M1&M2 | UK stockist for OMPHobby M1/M2 ScotiaRC.co.uk
Old 10-14-2019, 03:09 PM   #6 (permalink)
Oh really. On the Ikon2 this is calculated in the FBL controller so I assumed this was not capable. It lists the Scorpion as being able to send this data directly through the FBL unit.
Old 10-15-2019, 03:06 AM   #7 (permalink)
Fairly new to telemetry so I may be wrong and maybe it is done how you say. If you scroll to the bottom you will see a table of HW esc's and there telemetry functions. I use Spirit fbl so this is where the I got the link from
http://manual.spirit-system.com/inde...Wing_Telemetry
Old 10-15-2019, 12:12 PM   #8 (permalink)
HobbyWing Telemetry - Spirit System Manual
Each FBL/RX combo will have different requirements from the ESC for telemetry, for VBar use it is all done in the ESC and reported to the Neo to transmit the data to the VBC in real time.
As the OP asked about VBar that was the answer I gave in post #2
VControl
Old hand at Planks
Peter
Old 10-15-2019, 01:57 PM   #9 (permalink)
I only posted the table from the spirit page as it's the only one I could think of that has all the HW esc telem features listed. I didn't mean to suggest anything other than the telem options for hobbywing as i was under the impression that the op wasn't sure about mah output from HW esc's. Apologies if I made a mistake or said the wrong thing as that was certainly not my intention.
Old 10-15-2019, 02:02 PM   #10 (permalink)
Yes I initially asked and am concerned with the mAh. I know the other values. I guess what I donít understand is whether the spirit manual is saying the HW is sending mAh or if the Spirit unit is doing it
Old 10-15-2019, 11:51 PM   #11 (permalink)
Yep and this is what I am unsure of too. Sorry I couldn't be of more help, I never really thought about it until your thread.
Old 10-16-2019, 01:21 AM   #12 (permalink)
I guess what I don’t understand is whether the spirit manual is saying the HW is sending mAh or if the Spirit unit is doing it
The HW only sends instantaneous amps. mAh consumed is calculated by the Spirit based on current (Amps) and time. It says this on the table on the Spirit web site:
Name:	ScreenHunter_41 Oct. 16 06.19.jpg
Old 10-16-2019, 01:29 AM   #13 (permalink)
Thanks grumpy, I had seen that but again wasn't entirely sure if the spirit was doing the calculating.
Old 10-16-2019, 02:24 AM   #14 (permalink)
here's a good overview on j-log's homepage showing all supported ESCs and the information about mAh used is calculated in j-log(S32) or Esc itself: j-log.eu => supported Escs. it is a good overview of different ESCs capabilities...
it confirms what Grumpy wrote
Ciao
Michael
our hangar: minicopter & Logo helis, YGE/Egodrift/Spirit/Futaba BLS/Jeti
Rabid121 is offline        Reply With Quote Quick reply to this message
Old 10-17-2019, 10:39 AM   #15 (permalink)
Hey guys,
The HW integration is still VERY much in its infancy right now. I am currently on version 1 of the integration software and right now it's reporting mAH consumption, ESC temperature, capacitor temperature, RPM, throttle percentage, BEC voltage and a few other items like that. Setup right now is still done via the program card, but that could change in the future. Stay tuned as HW releases more information surrounding the software soon.
Also, there is no extra unit or sensor required for telemetry. All you need is a cable that goes from the "fan" port on the ESC to the satellite ports on the NEO. I made one myself quick, it was super easy. I didn't have any Mikado satellite cables at home when I did it, but it turns out Mikado uses the same satellite ports on their switches. So I took an old broken one and stole the plug from it ;-)
KS
Rabid121, Smoggie and bones7 like this.
Kyle Stacy is offline        Reply With Quote Quick reply to this message
Old 10-17-2019, 10:56 AM   #16 (permalink)
Originally Posted by Kyle Stacy View Post
Hey guys,
KS
Thanks Kyle!!!
I don't care as much about the "integration" as the telemetry. I've gotten spoiled on that....Is the testing going good? I'm curious as to how long it will be before they release it....lol
Old 10-17-2019, 09:13 PM   #17 (permalink)
Kyle, I have a 2016 Version 4 (not 4.1) HW Platinum Pro 200HV.
Do you know if this older hardware version will have the V-Control telemetry integration as well?
Old 10-18-2019, 01:22 AM   #18 (permalink)
I have no inside knowledge at all, but i'd be very surprised if the older V4 ESC didn't work just the same. It has identical telemetry output and takes the same firmware. Kyle did also say in his podcast that the integration would work on all V4 ESCs. Most of the HW range is still at V4.0, only the 200A has been updated to V4.1 . So if it only worked on V4.1 then it would only work on one model of ESC, not the full range as stated.
PS.. thanks to Kyle for dropping in and clearing up the uncertainties
Old 10-29-2019, 03:22 PM   #19 (permalink)
AFAIK, all V4/V4.1 ESCs will be supported, but that could change. I'll ask the higher ups now and report back once I know more!
KS
Old 10-29-2019, 09:56 PM   #20 (permalink)
Great, thanks!
KS
