Like Tree1Likes
Old 11-06-2019, 12:34 AM   #1 (permalink)
Default Neu motor 22 pole motors
Hi. Neu has released more 24 slot 22 pole machines. I have received a 4632 raw stack. https://neumotors.com/neumotors-3800...00-watt-class/
ID:	824317   Click image for larger version
File Type: pdf 12XXlong version rev2.vc6 _ web drawing (1).pdf (256.3 KB, 33 views)
1BOHO is offline        Reply With Quote Quick reply to this message
Old 11-16-2019, 01:55 AM   #2 (permalink)
Oh my bad. For people crying online... I had forgot to show yall I had been wount the first layer (17awg) of the um 4632 Steve sent well anyway ...... Y'all like it? Yeah.... The 200 C wire is loose right now, relatively, but that assures me I can get the other layer in. That would be 8 turns and that,s good, but my aim is at least10, so imma need myspace. You feel me? If I do that I'll be > 60%. I want 12 turns but I just don't think it's gone happen. That would be near 70% . Ya mouths will be shut for sure then. Well maybe not If you think's it easy to lay it in here like this with this mono CRAP!!!! try it. There's not a nick on this stator. YET Imma keep it traditional because this great motor really needs no tricks. If I get some copper in there she gone fly regardless. I'm working on the pcb end plates for the wye - d's but I could still terminate or wind them the old style if I wanted to. The pcb's and no crossover wires would really rub it in. Wish me well.... I know it's hard but don't hate on ya boy...
"Diese Flugzeuge werden von Clowns entworfen, die von Affen beaufsichtigt warden....."
Old 11-19-2019, 02:51 PM   #3 (permalink)
According to LT it will easily fit but cad is easier than reality. This is approximately 60%. Please enjoy what you came here for
Old 12-05-2019, 05:03 AM   #4 (permalink)
Default Progressions from primitive winding schemes and topologies
Name:	cascaded full bridge for semi 12 phase.png
You can drop a phase and keep running efficiently with semi 12 phase asymmetrically arranged open ended coils with cascaded bridges. Vector math shows the very high winding factors. Also is the verified harmonic content.
Old 01-24-2020, 11:24 AM   #5 (permalink)
There is a bit of overcite on RC groups. A Neu outrunner wire is rated for 200C and the magnets are 180C if you are running anywhere near these temperatures you simply need to gear down or buy a larger motor. I keep hearing complaints about noise and vibration but trash iron filings or whatever could be get into the open frame motor designed for axial cooling. A sealed motor or one with strategically placed vents is better for this surface vehicle environment. Steve, a very competent pilots's, motors do what they say with a prop in front of them a free air flow to the coils. Since the motor is not in the right posture for optimal cooling on the bike as his is in a plane its designed for you have to implement some cooling trick to run at them at his rating for an extended period.
User error.
Old 01-24-2020, 12:09 PM   #6 (permalink)
I would not run a hybrid setup or big EV sinus drive with a trapezoidal distributively wound machine if max torque and top efficiency is a goal. Only a 1:1 scale model are these huge azz bricks suitable for. LOL
Old 01-24-2020, 01:03 PM   #7 (permalink)
If you are having balance issue, which I've never had with any Neu I owned,
solicit ChX he designed a kitchen lab rotor balance rig from McDonald's happy meal toy motor and small belt drive.
A member there has also designed an active balance and includes the BOM, code, and pcb template .If I can find it Ill post it.
Raptorapture likes this.
Old 01-27-2020, 07:32 PM   #8 (permalink)
A beautiful orthocyclic lay started dedicated to KOBE (#24). Since the coil span is two on the 24 slot machine we can parallel each coil pair and only end up with 3 conductor pairs for 6 teeth. I go for lower kv and higher voltage motor. With all the parallel connection I hope to fall well below 300 kv and have still a low resistance. The fill should be well above 60%.The smaller wire should also yield better inductance matching between the coils. That helps stabilize the deltas. The turns ratio is approximately w2=w1sqrt(3) We will let Kobe run with APD as he like high voltage performances. With the parallel coils I guess you could really call it a yyyy+dddd.
Old 01-28-2020, 02:45 PM   #9 (permalink)
Old 01-29-2020, 02:45 PM   #10 (permalink)
I like it too Raptor. I've asked Christian several times to explain to us how it works but he's on mars somewhere right now so we can only hope he returns to earth soon enuf. In the meantime ill find the digital balance I saw. My emails and his replies are always several days apart.
Old 02-05-2020, 01:01 PM   #11 (permalink)
......2 More teeth and the 4 deltas plant their flags on "mars"......
Name:	NEU KOBE 24.png
Old 02-05-2020, 03:28 PM   #12 (permalink)
Default DDDD
..................... ~INSIGHT~ THE DELTAS HAVE LANDED
ID:	840649   Click image for larger version
Old 03-06-2020, 05:58 AM   #13 (permalink)
Default Welche Nonsnese fördert VP mit seiner Requisitenauswahl im Abakus?
Hallo Ralph, ich würde den werkseitig gefüllten Motor an seine Grenzen bringen. Was macht Homeboy dort drüben mit dem Motor im Taschenrechner? Nach Meullers Taschenrechner. "Das zuverlässigste Online" Ich kann den 12x25 Mirov auf 10 s Lipo 2500 60 / 100c-Packs mit dem apd 200f3 und 4638 289 Kv bei 10.237 U / min drehen. Es hat einen Wirkungsgrad von> 88,9% und erzeugt 5 Gramm Schub pro Watt. Die Pitchgeschwindigkeit beträgt dort 390 km / h und der Stromverbrauch 81,28 Ampere. Waren nicht dort an den Grenzen. Also ist es so schrecklich von der Stange? Geben Sie einigen von Ihnen einige Ihrer Requisiten-ARs, und Sie können Gerd sagen, dass wir mehr mit dem Abacus spielen können.
Name:	4638 289Kv gm 12x25.png
ID:	846505   Click image for larger version
Name:	4638 ecalc.png
Last edited by 1BOHO; 03-10-2020 at 11:44 PM.. Reason: Numbers correction to 5 grams of thrust per watt
Old 03-06-2020, 01:46 PM   #14 (permalink)
Dies ist der Standardmotor. Der Müller-Bericht scheint darauf hinzudeuten, dass die Dosentemperatur verdächtig ist, dies ist jedoch nicht der Fall, da die Temperatur unter der Motornennleistung von 100 ° C liegt. Der Kupferverlust wird bei gutem Wind definitiv verbessert. Wir sehen auch, dass die Wettbewerbszone aufgrund einer enormen Reduzierung und des Verlusts der Uhr mit einer Kühlerdose recht einfach erweitert werden kann. Ein kryogen gekühlter Stator und Wicklungen können weitere 100 Gramm enthalten, daher muss ich sagen, dass die Hausaufgaben dort ziemlich gut sind.
Old 03-06-2020, 01:53 PM   #15 (permalink)
Default other cool options.....
Der Luftspalt muss nicht mit Ferrofuid gesättigt sein, um eine viel bessere Wärmeableitung zu erreichen. Wie wirken sich ein paar Tropfen eines Motors dieser Größe auf das Ziel von 10.000 U / min aus? Um es draußen zu halten, funktionieren GFK und 180-Grad-Epoxid gut. Wenn Sie mit TCC Pot machen wollten, macht es das einfach besser. Dies ist für die Leistung, nicht für Kinder.
Old 04-01-2020, 03:21 PM   #16 (permalink)
NEU/LEOMOTION 4635 mit Idealisierungs Tipps!!
What happened to the discussion MAX ? It fell of after a real performance graph? You should spend more time with the calculator esp if you plan to send out global performance reports about it. At least be accurate!
Good luck
Powercroco sponsored F3S pilot opinions about neumotors once again a long way from reality.
Old 04-07-2020, 11:41 AM   #17 (permalink)
Default Kitchen lab portable power supply.
Lers try 3 or 4 of these in series for a bench supply. They are cheap enuf. We only need short durations and the price is reasonable for the amperage delivery.
Old 04-19-2020, 10:07 AM   #18 (permalink)
Man muss nur lange genug warten - dann schickt einem jemand einen solchen 24N Neumotor mit 46mm Statordurchmesser zum umwickeln.
Das Ding ist sehr einfach zu zerlegen und bietet sich damit regelrecht zum Experimentieren an.
Die grüne Beschichtung des Statorpaketes ist gut 2/10mm dick - also dicker, als die dickere Sorte von Wickpapier und somit ziemliche Verschwendung des recht kleinen Wickeraumes.
Also habe ich sie entfernt und wie immer GFK Deckscheiben und Isolierpapier verwendet.
Da der Auftrageber für irgendein Experiment unbedingt einen 46mm 24N26P mit 26mm Statorhöhe haben wollte, wurde das Statorpaket entsprechend gekürzt und auch solche Glocke gebaut und bestückt.
Warum das ganze? Ich weis es nicht.
Irgendwie ging es ihm vor allem um die resultierenden 312 Rastschritte dieser geänderten Kombination. Evtl. will er das das Ding ja schrittweise schalten? Der resultierende Winkel /rastschritt ist ja sehr klein und solche Kombinationen sind in kleinen Größen ziemlich selten
Die gewünschte N spec lag bei 130/V.
Die konnte mit einer 6+5+6+5 Bewicklung in Sternverschaltung erreicht werden.
Jedenfalls hat das Basteln mit den Teilen von NeuMotors viel Spaß gemacht. Auch der Besitzer scheint zufrieden mit dem Ergebnis des Umbaus zu sein.
ID:	853629   Click image for larger version
ID:	853631   Click image for larger version
ID:	853633   Click image for larger version
ID:	853637   Click image for larger version
powercroco is offline        Reply With Quote Quick reply to this message
Old 04-19-2020, 11:48 PM   #19 (permalink)
We liftoff Houston.
Old 04-19-2020, 11:52 PM   #20 (permalink)
Default Paper thin.....
No wire size or fill reports? At least the nomex takes up space and helps it look EXCEPTIONALLY filled. Gfx end plates? Why u need those Ralph ? Bust the enamel croco style.....A better turns sides ratio is possible that virtually eliminates the 2 pole harmonic in the 22 pole machine.
Good luck.
Hubert
