Like Tree2Likes
  • 1 Post By Rabid121
  • 1 Post By GregCA
Old 11-10-2019, 11:23 AM   #1 (permalink)
Default Logo 690SX v2 and Scorpion 4525-520
I just picked up a Logo 690SX v2 almost complete except for the motor. I have a motor that came with my Logo 700. I know in the Mikado website the recommended kv for the motor is 370-380kv.
Just wondering if any of you guys have tried this motor with your 690.
Protos 380 NEO x2
Oxy 2
Goblin Fireball
norstaroption is online now        Reply With Quote Quick reply to this message
Old 11-10-2019, 02:02 PM   #2 (permalink)
No. You need a motor that can run on the 15t pinion, and it can't output much more than 6kW peak.
Johnny31297 is online now        Reply With Quote Quick reply to this message
Old 11-10-2019, 04:27 PM   #3 (permalink)
what about a 4035-500? or a 700mx-510 or 470?
tonys-heli is offline        Reply With Quote Quick reply to this message
Old 11-11-2019, 01:26 AM   #4 (permalink)
i have used a Pyro 750 410 (with 14 pinion) on mine for 2 years... really great combination... unbeatable for me. and there are new motors for the Logo 690 on the market... just look on the web sites of i.e. Egodrift and XNova but be aware of motors with kV much bigger than stock... i would not go with high power motors and pinion 13 or even smaller... this could lead to trouble
Ciao
Michael
Logo 400SE/555SEX CF/600SX CF/690SX v2, HeliBaby NT, Diabolo 700, Hobbywing ESCs, Kontronik Pyro & Egodrift Tengu motors, VBar/Neo, j-log S32, iX12
Rabid121 is offline        Reply With Quote Quick reply to this message
Old 11-12-2019, 12:33 PM   #5 (permalink)
Ok thanks
Protos 380 NEO x2
Oxy 2
Goblin Fireball
Old 11-22-2019, 12:33 PM   #6 (permalink)
will any of this motor work with the 690sx with a stock 15T?
Scorpion Hkiii-5035-410Kv
Scorpion Hkii-4525-450Kv Ultimate
Scorpion Hkiii-4035-330Kv
Protos 380 NEO x2
Oxy 2
Goblin Fireball
Old 11-23-2019, 01:32 AM   #7 (permalink)
if you use a pinion lower than 15 tooth some have had problems stripping main gears , the bigger the pinion the more teeth have contact with the main gear .
Dennis Everett is online now        Reply With Quote Quick reply to this message
Old 11-23-2019, 03:08 AM   #8 (permalink)
I am using 4035 530 on 7s.
Logo 800xx, Logo 700xx, Logo 700, Logo 690sx, Goblin Urukay Comp, Goblin 770 Sport, Goblin 700 Comp Triblade, Goblin Kaken, Agile 7.2, Shape S8, Specter and Gaui X7 Triblade
ah_liang is offline        Reply With Quote Quick reply to this message
Old 11-23-2019, 04:51 AM   #9 (permalink)
5035-410: Too much power output.
4525-450: Too much power output, Kv too high.
4035-330: Too little power output for proper 3D, Kv too low to maintain proper 3D headspeeds.
Why not, like, use a motor that's made for the heli?
Old 11-25-2019, 09:53 AM   #10 (permalink)
I use 4525-520 in my 600SE, on 6 cell though. 13 tooth.
Still run up to 1600 with low amps and lots of power, almost unboggable.
Machine all up is 3.8Kg on VTX697.
GimpyGolden is offline        Reply With Quote Quick reply to this message
Old 11-25-2019, 10:09 AM   #11 (permalink)
I'm running the HK4525-520 that came in my old logo 700 ultimate using Jive Pro120hv. Sure the gearing is lousy on 12s but it works. The torque of that big can motor holds my favorite head speed of 1500rpm locked in with no bogging.
Wayne
Logo 480 / Logo 600sx / Logo 690 / Logo 700 / Vbar Control
Mentalic is offline        Reply With Quote Quick reply to this message
Old 11-27-2019, 08:12 PM   #12 (permalink)
Good to know. I purchased a Scorpion 4525-450KV Ultimate since it’s on sale for $150.
Protos 380 NEO x2
Oxy 2
Goblin Fireball
Old 11-27-2019, 09:18 PM   #13 (permalink)
Where at for that price?
Chris
RappyTappy is offline        Reply With Quote Quick reply to this message
Old 11-27-2019, 11:19 PM   #14 (permalink)
Well,since the 15T is only 12mm height and main gear is 13mm it is not covering full point of contact.
However 11 and 12t have 14mm height and probably compensate that missing 1mm on 15T,but i might be wrong,it needs calculations.
Also,i never saw a stripped main gear on L690.It was always melted and then stripped with pinion that melted plastic.
There are a few reasons of melting.
Friction,wrong gear mesh,overheated motor,misalighned third motor bearing.
All of these factors creating heat,which at some point(certain temperature) melts main gear.
For first reason people recommend lubing gear with Dry fluid or any other fluid,including PTFE.
That methoid works for me.
I like to change setup time to time and for now i use Pyro 700 hand wound to 480Kv and 11T,headspeed 1900-2000.
Previous setup was Scorp 4035 500Kv with 12T(i had 11T also).
But i limited my collective to 12,5-12,8.
And of cource right now the weather is cold,which is another good factor for not melting main gear.
My logs show 6 to 6,5 of peak power output and it also shows that motors have to be limited to 6 kW of power.
racer-g is offline        Reply With Quote Quick reply to this message
Old 11-27-2019, 11:57 PM   #15 (permalink)
The XNova 4035 400 Motor works well.
Synergy 696 coming, Synergy E5SS HP, E5S, 2-soXos Strike 7s, soXos 600, VControl T, VBar Neo, Scorpion Tribunus ESC, MKS/Savox
Freeskiken is offline        Reply With Quote Quick reply to this message
Old 11-28-2019, 02:20 AM   #16 (permalink)
if i would have to build a new L690 today... i would take into account this motor: https://www.egodrift.com/tengu-4525h...0-edition.html
... seeing my experiences with other Egodrift motors => this would be most probably my choice. L690 is a light bird, not asking for excessive power but for a light and highly efficient motor (but power does not hurt anyway )
Ciao
Michael
Hicksy likes this.
Old 11-28-2019, 01:39 PM   #17 (permalink)
The 15T on mine is taller than the main gear by ~1 mm so there is full contact on the entire height of the main gear.
racer-g likes this.
Logo 480, 550 SX (YGE/Xnova), 690 SX (Tribunus/Scorpion), Savox/MKS, NEO, VBC
GregCA is online now        Reply With Quote Quick reply to this message
Old 11-29-2019, 02:32 AM   #18 (permalink)
Good to know.
I dont have 15T but 13 ans 14T are 12mm
