Go Back   HeliFreak > R/C Electronics Support > Scorpion ESC and Motor Support
Scorpion ESC and Motor Support Scorpion Power Systems ESC and Motor Factory Support Forum
Like Tree1Likes
  • 1 Post By mackie
Old 11-13-2019, 04:14 PM   #1 (permalink)
Default V2 120 with Vbar- Wont reboot on parameter changes
Not sure if my question should be in this or the Vbar forum, but hopefully someone can help.
I purchased a used V2 120 amp Tribunus and have fitted this to a logo 550 that was flying fine will a Kontronik, VBar NEO and VBar Control.
I installed the Tribunus and set up the Heli again, the Scorpion app is installed and I have the telemetry.
When I try and change any settings in the V Control related to the Tribunus and select Store, the esc shuts down but does not restart, as it does with other Tribunus I have.
If I then cycle power the settings in the esc have not changed.
I have rolled the firmware back to 59, same issue, re installed version 60, still the same.
I'm not sure if this is a Vbar issue or Scorpion related, but the Vbar is telling the scorpion to reboot, but it won't come back on again itself.
mackie is offline        Reply With Quote Quick reply to this message
Old 11-13-2019, 05:24 PM   #2 (permalink)
It may not help, but I would make sure that the apps on your VBC are all up to date.
Logo 480, 550 SX (YGE/Xnova), 690 SX (Tribunus/Scorpion), Savox/MKS, NEO, VBC
GregCA is offline        Reply With Quote Quick reply to this message
Old 11-15-2019, 07:05 AM   #3 (permalink)
Cheers Greg,
Checked the Vcontrol and Neo last night, all up to date.
Seems nobody has had experience of this issue based on the number of comments.
I'll drop a note to the guys at Scorpion
Old 11-15-2019, 07:56 AM   #4 (permalink)
I donít know if vbar is like the computer, but when I tried to connect my V2 using tribunus it would connect then wink, connect then wink., etc,etc,.
Once I realized I needed tribunus V2 and it all worked from there.
Steve
smittylube is offline        Reply With Quote Quick reply to this message
Old 11-15-2019, 09:07 PM   #5 (permalink)
Make sure you have the correct communication protocol selected in Sproto when connected to PC via VLink2 and diode cable. Needs to be set to VBar.
Gaui R5, Henseleit TDR, TDR2, TDF, TDS, TDSF
VControl
Old hand at Planks
Old 11-17-2019, 03:15 AM   #6 (permalink)
Just wanted to close this off by pointing out error I made. I had connected the slave from the Tribunus to a spare port on the neo. It should have been in the RPM port on the neo for me to use Vbar gov. Having done that, now when I change parameters on the vcontrol the scorpion reboots as it should, Morse code beeps etc! So not sure exactly why that makes a difference, but that’s all I’ve changed and it’s sorted. Schoolboy error! Thanks all for your comments though, cheers.
GregCA likes this.
Tags
reboot, tribunus, vbar
