Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade Nano S2
Like Tree7Likes
Old 11-20-2019, 05:40 PM   #1 (permalink)
Question Aluminum swash?
Where can I get one? And is this the only upgrade I need?(have a bunch of spare motors from motor warehouse). Does the tail need to be upgraded?
I fight Gravity
300x,4503d converted to x
(2) Trex 550's stretched
Build in progress Tarot 450 Pro V2
franknsled is offline        Reply With Quote Quick reply to this message
Old 11-20-2019, 05:55 PM   #2 (permalink)
The metal swash is the one essential upgrade. The microheli one works great for me:
Precision CNC Aluminum Swashplate
I'll bet you can find one on eBay, as I recall it is NextRC that sells them on eBay.
franknsled likes this.
navigator2011
Oxy2 190 FE / Oxy2 190 Sport / Fusion 180 / Blade 150S / Trex 150X / Blade mCPX BL2 / Brushless Nano S2 / Spektrum DX9.
navigator2011 is offline        Reply With Quote Quick reply to this message
Old 11-23-2019, 05:41 PM   #3 (permalink)
x2
Nano CPS - 230s - Align 470LT - Goblin 570 - Goblin Black Thunder 700 - Rustler VXL - Hubsan H107D+ X4 FPV - LaTrax Alias
motoxxxman is offline        Reply With Quote Quick reply to this message
Old 11-24-2019, 04:34 PM   #4 (permalink)
metal swash on a nano = mandatory option part
Microheli has currently -30% on the entire website
franknsled and motoxxxman like this.
THE HANGAR
Nano CPX - Nano CPS (2) - Nano S2 (3) - Micro Apache - 180CFX (2) - 230S HUEY - 230S V2 - 250 CFX - 270 Fusion (2) - 270 CFX (2) - 360 CFX (2) - Align 450 PRO - Align 150X ** Spektrum DX8E *** Hangar out: MCPX BL - 130S - 230S V1 Trio
Psycho_dad is offline        Reply With Quote Quick reply to this message
Old 12-05-2019, 11:02 PM   #5 (permalink)
So got my MIcroheli swash and it was assembled. Do I need to take it apart and threadlock everything? and if yes HOW?
I fight Gravity
Old 12-06-2019, 01:20 AM   #6 (permalink)
I've had a few of those swashes, and I've never disassembled any of them. It seems like more damage could be done than any good by trying to take it apart.
navigator2011
Old 12-06-2019, 01:26 AM   #7 (permalink)
Kinda what I thought. Thanks for saving me from wrecking it(probably).
I fight Gravity
Old 12-06-2019, 01:28 AM   #8 (permalink)
My pleasure. I've never had one of those swashes fall apart. Just inspect it, install it, and go fly.
navigator2011
Old 12-06-2019, 05:42 AM   #9 (permalink)
do they send a level tool with it?
Spektrum DX8G2, AccuRC Simulator
Blade Scout CX, MSR S, Nano S2, 230s V2, 360CFX, NanoQX
Oxy 4 MAX
SAB Goblin 500 Sport
Old 12-06-2019, 10:29 AM   #10 (permalink)
No leveling tool, but eyeball works just fine on this tiny heli.
navigator2011
Old 12-06-2019, 10:44 AM   #11 (permalink)
Yea - thats what i use on the plastic swash.
Oxy 4 MAX
Old 12-06-2019, 11:48 AM   #12 (permalink)
Now You just need a set of (7) 001-size silicone O-Rings...
(3) for the servo links
(4) for the swash/grip balls
They will stiffen up the head quite a bit
franknsled and Mrowka like this.
nCPX(3)*mCPX(25)*130X(10)*130X-L(6)*180CFX(3)*300X/CFX(3)
450X(7)*470LP*GauiX3*nanoQX*180QX*DX9*HF180060*AMA 988253
Old 12-17-2019, 12:39 AM   #13 (permalink)
Got the Microheli swash installed but can't keep the anti rotation pin in it. Have crazy glued it twice and lost it twice. Found it by dragging a magnet over the living room floor. Glad its hardwood and not carpet!
I fight Gravity
Old 12-17-2019, 01:21 AM   #14 (permalink)
Ok, you can get a metal epoxy or maybe use green thread lock. Clean the hole and the pin, sand the mating surfaces and then glue them together. Or, get another swash.
I have two metal swashes, one lost the pin and the other is rock solid. Luck of the litter, I suppose.
navigator2011
Old 12-17-2019, 01:24 AM   #15 (permalink)
I think you are right. Just lost it again! Going to take it apart and follow your suggestion. Can't believe I found it 3 times! maybe need a lottery ticket?
I fight Gravity
Old 12-17-2019, 01:26 AM   #16 (permalink)
An epoxy designed for metal will work. If the pin fits tightly in the hole, then green thread lock (like we use for pinion gears) should work.
navigator2011
Old 12-17-2019, 09:37 AM   #17 (permalink)
How is micro heli nowadays? When nano cpx was new, they weren’t particularly good due to soft aluminium used...
Now when lynx is focussed on oxy, seems not much options...
rimaarts is offline        Reply With Quote Quick reply to this message
Old 12-17-2019, 10:12 AM   #18 (permalink)
I have experience with only the swash for the nanos. They are so light that the soft aluminum is likely strong enough. Anything bigger, I don't know.
navigator2011
Old 12-18-2019, 11:42 AM   #19 (permalink)
I had a MH swash on a CPX with no problems. I have a MH swash on my MCPX and all is good there. Rakon and Lynx on some mcpx BL's I had, no issues. Everything can break over time and hard surface crashes.
CrashyCrashy
CrashyCrashy is offline        Reply With Quote Quick reply to this message
Old 12-18-2019, 12:38 PM   #20 (permalink)
I almost have microheli parts on all my helis and
THE HANGAR
