Like Tree2Likes
  • 1 Post By curmudgeon
Old 11-23-2019, 01:52 PM   #1 (permalink)
Default miniVBar: how to connect to PC?
I have a miniVBar unit I purchased a while back here in the HF classifieds. I am not sure if it works. I installed the software V5.3, but the software does not recognize the miniVBar. I have the miniVBar powered with a 2S Lipo via the CH2 port, and I am using a standard USB-miniUSB cable to connect to the computer.
The miniVBar came with a note stating that it has the firmware 6.0 express installed.
If it helps, I have a spare VBar Control RX-Sat I can use to connect to the VBar Control radio. I tried binding it to the radio, but I was not successful.
Protos 700X Evo, Goblin Kraken/700 Havok/570 Sport/380 KSE, Logo 700/550SX V2; Neo VLink;VBC Touch & DX8 G2
Simulators (on MacBook Pro): AccuRC, Heli-X, neXt, AeroFly RC7 Ultimate, RealFlight, Phoenix Citizen 259
curmudgeon is online now        Reply With Quote Quick reply to this message
Old 11-23-2019, 02:31 PM   #2 (permalink)
If it really does have version 6 then it will not connect through the USB port.
With version 6 it has to be hooked up with a v-link satellite and connected to VBC in order to program it.
Do you get any indication at the satellite that it has gone into bind mode?
Andy from Sandy is offline        Reply With Quote Quick reply to this message
Old 11-23-2019, 02:38 PM   #3 (permalink)
I really cannot tell from the hand written note whether it has 5.0 Express or 6.0 Express firmware. The sat LEDs do not light up at all.
Old 11-23-2019, 02:39 PM   #4 (permalink)
I have no use for it. I want to resell it, but I don't want to sell it if it is not working.
Old 11-23-2019, 03:24 PM   #5 (permalink)
Regardless of firmware on its own without the satellite does the V light up when you power it up? I can't remember if it lights up even when it is not getting any data.
Connections are upside down compared to NEO.
Old 11-23-2019, 03:26 PM   #6 (permalink)
Yes. The miniVBar lights up when I connect a 2S LiPo to it.
Old 11-23-2019, 04:30 PM   #7 (permalink)
There is a little arrow on one pin on the mini v-bar CP port. That is VCC (positive).
The black marker wire goes to that pin from the v-link sat. I am guessing this as when you see the wires when going to a NEO the black wire goes to middle pin which is positive.
Old 11-23-2019, 04:40 PM   #8 (permalink)
Please confirm this is the correct RX sat wiring.
Old 11-23-2019, 04:43 PM   #9 (permalink)
Sometimes you need to install the separate PC drivers to get them to communicate. But like mentioned if 6.0 it won't talk on the USB. If you can register it on the vstabi site it will tell you what it has installed currently.
I should sell mine too. I have three of them doing nothing. Two have 5.3.4 Pro and one Express. I have all of them registered so I can transfer them to the buyers.
Team USED
Shape S8,G700,G500,Shuttle 550,Trex 500 E/EFL Pro,Oxy 3(2),B400(5),450X,360CFX,Fusion 270(2),230S (V1/V2),200S,120S,Nano (CPS/S2),K110/120/130
BrokeDad is online now        Reply With Quote Quick reply to this message
Old 11-23-2019, 11:22 PM   #10 (permalink)
Wiring a mini https://www.vstabi.info/en/node/442
With V6 it will not connect to USB as it has been disabled. What you can do is to load recovery firmware via the USB as this gets written blindly.
Videos https://uroehr.de/vtube/cat/old-v5-vbars-archive-
Then register it and load V5.3 and it will now connect to PC. You can then load V6 for use with VBC. All explained in the videos linked above.
Gaui R5, Henseleit TDR, TDR2, TDF, TDS, TDSF
VControl
Old hand at Planks
Old 11-24-2019, 06:13 AM   #11 (permalink)
I've made progress. Driver is installed and the PC software recognizes that the miniVBar is connected via the USB port.
Then I go to File >> Online update
And get to this screen telling me the serial number and firmware version currently installed.
Then I click on "Version 5.3 PL 4 Express (Mini Blueline)" >> Load
And I get this error message
Where do I go from here?
Name:	Screen Shot 2019-11-24 at 05.59.44.jpg
ID:	827681   Click image for larger version
Name:	File upload.jpg
ID:	827683   Click image for larger version
Name:	Screen Shot 2019-11-24 at 06.03.05.jpg
ID:	827685   Click image for larger version
Name:	Screen Shot 2019-11-24 at 06.09.24.jpg
ID:	827687   Click image for larger version
Name:	Screen Shot 2019-11-24 at 06.09.39.jpg
Old 11-24-2019, 06:23 AM   #12 (permalink)
Success. I loaded a "recovery firmware", and now the miniVBar is updated to the latest version 5.3.4. Thanks for all your help.
Name:	Screen Shot 2019-11-24 at 06.19.57.jpg
BrokeDad likes this.
Old 11-24-2019, 06:32 AM   #13 (permalink)
Glad you got it all working. It was a bit difficult for me the first time too.
Team USED
Old 11-24-2019, 06:34 AM   #14 (permalink)
I am going to sell it as I have no use for it. I just wanted to make sure it worked before putting it in the classifieds.
GregCA likes this.
