Old 11-25-2019, 12:14 PM   #1 (permalink)
Default Turn VBAR NEO Governor Off
I'm hunting a slow tail wag on my Logo 690SX while hovering. Tail is smooth. Is there a way to turn vbar gov off and just use end point? Or the only option I have is to choose external gov?
Protos 380 NEO x2
Oxy 2
Goblin Fireball
norstaroption is online now        Reply With Quote Quick reply to this message
Old 11-25-2019, 01:32 PM   #2 (permalink)
Set the governor gain to 0. It should just output the base throttle then.
Spectre 700 / T-Rex 700e / Oxy 4 Max ~ VBar Control Touch ~ MKMHC / LARCS / LMAC
richardv is offline        Reply With Quote Quick reply to this message
Old 11-25-2019, 09:40 PM   #3 (permalink)
As you have said, choose external governor option but then ESC must be set to govern.
Slow tail wag is normally mechanical or too low rpm.
Tweaking things https://www.vstabi.info/en/node/2043
Gaui R5, Henseleit TDR, TDR2, TDF, TDS, TDSF
VControl
Old hand at Planks
Old 12-23-2019, 06:41 PM   #4 (permalink)
Fixed: replaced the thrust bearings with Tarot
Protos 380 NEO x2
Oxy 2
Goblin Fireball
Old 12-24-2019, 04:25 AM   #5 (permalink)
This is not the first time the thrust bearings chosen by Mikado have been the cause of tail wag.
Andy from Sandy is offline        Reply With Quote Quick reply to this message
Old 01-09-2020, 05:53 PM   #6 (permalink)
I've been fighting a fast wag on my Logo 600SX for a month. How would you check for defective thrust bearings?
Thank you. Mike
mopezio is offline        Reply With Quote Quick reply to this message
Old 01-09-2020, 06:20 PM   #7 (permalink)
Hi,
Could you explain how the governor can cause tail wags and what to do to fix the wag?
Thanks, Mike
Old 01-09-2020, 06:27 PM   #8 (permalink)
A governor where gain is set too high can cause the tail to hunt.
I think that's more common to ESC govs than FBL, but regardless the gov is only one of several possible reasons that tails can misbehave. (although this isn't what you asked. )
AMA 373608
K2Freak is online now        Reply With Quote Quick reply to this message
Old 01-09-2020, 06:53 PM   #9 (permalink)
Thanks. So I'm using my vbar as the governor vs the Scorpion. I can eliminate the governor as a likely cause?
Old 01-13-2020, 12:06 PM   #10 (permalink)
On the bench with the rudder control rod removed the blades should self centre. Push the slider to move the blades off centre and they should return.
Clearly you have to be very careful on the bench with stuff rotating very fast. Also when you move the tail blades there is a lot of thrust so the model needs holding firm.
Else just change them.
