Go Back   HeliFreak > R/C Electronics Support > OpenTX Radios
OpenTX Radios OpenTX Radios Discussion and Support Forum
Like Tree1Likes
  • 1 Post By Ivan
Old 11-27-2019, 09:46 AM   #1 (permalink)
Default Since there is no FrSky specific forum...Neuron ESCs
Has anyone tried the FrSky Neuron ESCs? What are your thoughts? Seems the native telemetry would be nice and reduce some of the wiring on a heli...and would be a great option for craft without a flight controller to translate the telemetry signal.
NEAGRON likes this.
Ivan is offline        Reply With Quote Quick reply to this message
Old 11-27-2019, 08:20 PM   #2 (permalink)
I put a 40A in an airplane. It works great and the telemetry works well also. The only thing about the Neurons is the size. It is a pretty big package so it is not doable in the smaller helis. They have a 7A BEC in them which is nice also. Be aware that the 40, 60 and 80A versions are all the same size and weight so it seems sensless not to buy the 80A version. I totally missed that when first looking at them.They are coming out with the NeuronS in 40 and 60A size that are going to be smaller and lighter but they will only have a 5A BEC.
Two other caveats are that you need a BLheli USB linker to program them and there is quite a discussion on some safety concerns with the s-port circuit over in RCGroups which you would want to look at before using one.
All that being said I like the one I have and am planning on picking up a few more.
Old Man 3D.......Low and Slow!!!!!
Cromer is offline        Reply With Quote Quick reply to this message
Old 11-29-2019, 11:31 AM   #3 (permalink)
there's a new smaller 40a neuron
https://www.horusrc.com/en/frsky-neuron-40s.html
i'm using the older original 80a in an edf, it's huge. I had to cut away a lot of foam to fit it.
XLPower 520 - Spirit
XK K110 - BLheli
TX: Fr-Sky X9 Lite
P.I.Engineer is online now        Reply With Quote Quick reply to this message
Old 12-11-2019, 06:53 AM   #4 (permalink)
I'm thinking about the new 60s for a Protos 480. It is smaller than the hobbywing v4 60a and I get telemetry. Anyone know if the 5a SBEC will be an issue vs the 7A from hobbywing?
Oxy 2, X3, Protos 380, G420, Logo 480, Trex 500X, Logo 550 SX
Krea is offline        Reply With Quote Quick reply to this message
Old 12-11-2019, 12:22 PM   #5 (permalink)
Just reading about these esc's myself. they look interesting. Do you need to be a Frsky user to take advantage of the telemetry features?
The non S series have 7A, EDIT, ahh I see, the "s" is a smaller version or a lite version.
SBEC supports [email protected]~8.4V
https://www.frsky-rc.com/product/neuron-60/
Oxy 2 215- RIP / Oxy 2 215 sport / Oxy 3 Tareq 2018 / Trioxy 3 (aka Qube) / Goblin fireball / G380 / P380 Evo / G570 / G-stay tuned / Jeti DS-12
blarks is online now        Reply With Quote Quick reply to this message
Old 12-11-2019, 12:34 PM   #6 (permalink)
I thought about it.
One concern I had is when using the governor of the flight controller. Will the flight controller actually read the Neuron's RPM telemetry data?
This would vary by flight controller vendor but I would be inclined to find out if it works properly before buying a Neuron.
Ferrite is offline        Reply With Quote Quick reply to this message
Old 12-11-2019, 01:32 PM   #7 (permalink)
I didn’t account for the governor issue. That is a valid point. I don’t think the ESC will have a good heli gov and I don’t know about FBL integration with these ESCs. Sounds like too many unknowns and I’ll have to stay with hobbywing and limited telemetry on mah used.
Old 12-11-2019, 01:42 PM   #8 (permalink)
I didnít account for the governor issue. That is a valid point. I donít think the ESC will have a good heli gov and I donít know about FBL integration with these ESCs. Sounds like too many unknowns and Iíll have to stay with hobbywing and limited telemetry on mah used.
Yes this is what I am thinking as well. Would be interesting to hear from others that have this esc setup and running what their setup is and how well/not well it works.
Old 12-11-2019, 11:29 PM   #9 (permalink)
RPM via telemetry wouldn't be fast enough for the ESC to govern. If you want it, just get a cheap hobby wing RPM sensor and hook it into the FBL RPM input port.
P Max v2, G570, N556, S516, P380, XK K110, Open-TX
JWeber is online now        Reply With Quote Quick reply to this message
Old 12-12-2019, 08:54 AM   #10 (permalink)
I already get ESC temp, rpm, pack voltage, and current from my hobbywing 60 thru my ikon and I don't need a separate rpm sensor. Why would I use this in a helicopter with a flight controller that reads that ESC data and sends the telemetry to my transmitter? Maybe it makes sense where there is no flight controller but not on my helicopters.
Sent from my Pixel 2 using Tapatalk
kuroguy is online now        Reply With Quote Quick reply to this message
Old 12-12-2019, 01:26 PM   #11 (permalink)
The HW 60 gives current? Is there a new version out that I missed?
Old 12-12-2019, 01:33 PM   #12 (permalink)
Lol, I was just reading this and thought the same thing.
Old 12-12-2019, 02:30 PM   #13 (permalink)
did i get that wrong? crap. i thought it did, but regardless, there are other manufacturers (yge down to the 35 amp esc, for one) with 60 amp ESCs that do give all that telemetry and include an rpm out that when paired with ikon provide all that telemetry.
Old 12-12-2019, 02:30 PM   #14 (permalink)
Yeah. I was planning on buying one for a fixed wing. Asking something technical in the fixed wing community is like asking a kindergartner to solve systems of differential equations.
So I asked here.
Old 12-12-2019, 02:41 PM   #15 (permalink)
if i flew electric fixed wing, i'd certainly try one of the neuron ESCs out. i'd probably be sure to go with the 's versions since all of the original ones weigh the same. sometimes (who am i kidding) it takes a revision or two for frsky to get their products in a polished state.
