100 Class Electric Helicopters 100 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
#1 (permalink) | ||
![]() Check out this video and tell me am I crazy? My K130 (with reflective tape, looks like Liberace designed the canopy and tail) never stays put when I start any kind of piro maneuver. It falls back and to the right and I have to keep a real quick eye on it to keep it from flying into the ground.
The weird thing is, when it's inverted, I can piro all day long and it won't fall over. What's going on? I verified the gyro chip is connected to the FBL correctly with double stick tape under the red plastic cover.
#2 (permalink) |
![]() You are clearly not a beginner, however, I would have liked to see you try to piro in one position, maintaining roughly the same altitude. Practice trying that for a while and see if control improves.
Logo 600 (VBar Neo), Gaui X5 FES (BD3SX), Warp 360 (MiniVbar), Trex 450 Pro FBL (Spirit Pro), OXY 3 stretch (Spirit), OMP M2 Explore, two 180CFX (one uSpirit), 130X, XK110, Nano CPX |
#3 (permalink) |
![]() Hi all,
I have just got one of these mini-beasts. When it pirouettes it drifts a significant amount and definitely does not stay flat. Hover is stable. I am not sure if I should calibrate the gyro or not. I haven't checked under the red thingy on the controller yet...It seems to have HUGE amount of pitch and I don't have a pitch gauge small enough to measure it. Any help appreciated. Mike |
#4 (permalink) |
![]() So checked the gyro chip under the red cover and it is nicely mounted on double-sided foam tape - so not that. The swash is 100% level - elevator side is low, so adjusted that.
Will have to wait until it is less windy before I retry but not liking the XK K130 as much as the 110. |
