Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 230S
Blade 230S Blade 230S Helicopters Information and Help
Like Tree1Likes
  • 1 Post By Flyguytruckguy
Old 01-01-2020, 07:26 PM   #1 (permalink)
Default Fixed a bad tail wag!
Updated my radio finally so I could access "Forward Programming". Played with gain in the tail to try and eliminate a bad wag that showed up after a complete rebuild that included an aluminum head.Going to extreme settings in the PID's and back to stock setting did absolutely nothing. When I was putting it together I didn't like the fact that I could not leave the main blades less than snug in the grips. Read a few posts and loosened the blade bolts to the point they were slack. Put some shoe goo on the bolts and put them back in fairly loose. NO MORE WAG!!!!
motoxxxman likes this.
Oxy2,3,4
Flyguytruckguy is offline        Reply With Quote Quick reply to this message
Old 01-02-2020, 06:40 AM   #2 (permalink)
too short of bolts to use the usual nylon lock washer nut things?
Spektrum DX8G2, AccuRC Simulator
Blade Scout CX, MSR S, Nano S2, 230s V2, 360CFX, NanoQX
Oxy 4 MAX
SAB Goblin 500 Sport
Old 01-02-2020, 01:39 PM   #3 (permalink)
That battery is monstrous!
I highly advise cutting the jst connector off and upgrading to xt30. Pretty much guaranteed to see a very noticeable improvement in power, consistency, and even less wag
Nano CPS - 230s - Align 470LT - Goblin 570 - Goblin Black Thunder 700 - Rustler VXL - Hubsan H107D+ X4 FPV - LaTrax Alias
motoxxxman is online now        Reply With Quote Quick reply to this message
Old 01-03-2020, 11:59 AM   #4 (permalink)
Alltough i changed to XT30 Connectors, i never had issued with the stock Ones.
Sad to see that the Lynx Heli Blade Grips are not machined to the right Size. Same as Microheli Blade Grips. Mounting an "Upgrade" causing a tail wag sucks. I had better results with the Rakonheli Rotor Heads, they fit fine.
Did not expect the Lynx Heli Parts to cause such issues, as i have mounted different Parts from Lynx (not the Rotor Head) fitting quite well.
My Helis: https://www.helifreak.com/album.php?u=238607
The_Fox is offline        Reply With Quote Quick reply to this message
Old 01-08-2020, 09:16 AM   #5 (permalink)
What is the definition of upgrade? Most I've seen with the 230S improve appearance at the expense of performance (primarily by added weight, but also other issues as mentioned here).
I feel a meaningful difference in flight simply by the removal of the canopy weight. I can't imagine the sluggishness of moving that bat and additional metal. But we want different things from our models, so I'm not being critical of the OP or others, just that, if you want performance, few "upgrades" improve on the original.
RCFred is online now        Reply With Quote Quick reply to this message
Old 01-08-2020, 01:56 PM   #6 (permalink)
OP here! I agree. Adding bling to an airframe usually does not result in improved performance.I bought the head and swashplate a few years ago when I was first getting back into heli's. Figured I'd use it now before it's too late. The rebuild with the CF frame and AL head added 40 grams. I just do not like that plastic frame because if you ever get to the point where you can't put it back together with zip ties and goop, you have a complete rebuild on your hands. So now I have one stock V1 and one CF V2 and a spare frame for the V1. At one point, all the V2 electrics where in an Oxy2 frame with only a few grams difference and a perfect CG. Hey!, gotta waist time somehow.
Oxy2,3,4
Old 01-09-2020, 12:42 PM   #7 (permalink)
What is the definition of upgrade? Most I've seen with the 230S improve appearance at the expense of performance..
That`s right! I just improove the appearance. Look at my avatar picture on the left side - that`s one of my Blade 230S with scale fuselage, rakonheli fifeblade and NOTAR tail.
As You mentioned, we want different things...
Old 01-10-2020, 06:18 PM   #8 (permalink)
That's a bit of a re-purposing. It's now something it was not.
I like it.
Old 01-13-2020, 02:06 PM   #9 (permalink)
When fitting the blades they must be able to swing with their own weight. I have RKH metal blade grips and I prised them open a bit to get the blade to rotate freely. As suggested I use bolts and nyloc nuts to just take out the vertical slack in the blade but not impede the rotary motion.
I think metal blade grips are an upgrade in crash resilience because with the stock plastic ones I kept pulling the metal ball out of the grip. A couple of crashes and the grip was shot. Since going metal I've not had this issue and for sport flying I don't think the weight issue is of consequence.
Allan114 is offline        Reply With Quote Quick reply to this message
Old 01-15-2020, 04:54 AM   #10 (permalink)
I like it.
Thanks! Anyway, You ar right. Not the best example. But here`s another one: Fourblade head from Rakonheli. Fenestron tail ist stock Blade 230S tail motor with 50mm EDF.
ID:	836001 Click image for larger version
ID:	836003 Click image for larger version
ID:	836005 Click image for larger version
I would not say this is improoving the flight performance of the Blade 230S. But it`s improoving the appearance and the sound. As told before, we want different things. This is what i want, a modell helicopter looking and flying like a helicopter. No matter of size, i do similar to a 360 or else.
