Old 01-04-2020, 09:51 AM   #1 (permalink)
Default RPM signal hobby wing platinum pro
I canít seem to get a RPM to show up on my Vcontrol. Iím using neo with pro and hobby wing platinum pro 100A. I have gov. Off in the ESC programing and the Signal wire in neo sensor spot and itís in the right way. I have the power and ground plugged into ch 4 of neo that goes back to ESC. Should I put the signal wire and the power and ground in the sensor spot on the neo?
joecass2 is offline        Reply With Quote Quick reply to this message
Old 01-04-2020, 10:54 AM   #2 (permalink)
can you post a pic of your neo?
does it spool up? do you have the gearing info correctly in the gov setup menu?
is the rpm app installed in the tx?
tonys-heli is online now        Reply With Quote Quick reply to this message
Old 01-04-2020, 11:51 AM   #3 (permalink)
I didn’t have the telemetry app loaded so I did that but still not showing. It’s raining out so I can’t see if the head speed changes. I loaded a picture .
It does spool up and all info is correct in gov menu
It’s half of the pole count of the motor correct?
Old 01-04-2020, 12:30 PM   #4 (permalink)
that's wrong.. rpm/signal wire goes in the rpm port.. the sensor port is for an external gyro sensor.
yes, half the pole count.
Old 01-04-2020, 12:49 PM   #5 (permalink)
You don't appear to have a telemetry lead plugged in from the ESC to the NEO. It will plug in at the side of the NEO.
Andy from Sandy is offline        Reply With Quote Quick reply to this message
Old 01-04-2020, 12:53 PM   #6 (permalink)
the hw 100A v3 doesn't have telemetry unless he has the ui sensor.
but without the rpm wire in the correct port, there will be no rpm's or fbl gov
Old 01-04-2020, 01:23 PM   #7 (permalink)
It works now what a dummy I am. Thank you
Old 01-04-2020, 01:38 PM   #8 (permalink)
