Old 01-14-2020, 12:13 PM   #1 (permalink)
Default Collective "dead zone"
Setting up an SK720 that I picked up the other day and have a "dead zone" in the center of the collective stick movement. It gets to 0 degree and stays there for a good bit before moving on to positive or negative pitch.
Anyone know of a way to adjust the size of that dead zone? I didn't see it in the app or mentioned in the manuals. Just aileron and elevator.
sloan377 is offline        Reply With Quote Quick reply to this message
Old 01-15-2020, 10:02 AM   #2 (permalink)
HF Scale Support
That's normal during setup. The only way I know of to make a larger "dead zone" is to create one with the pitch curve. There is no adjustment setting to enlarge or reduce the current factory dead zone. Take care.
Don
Keyrigger is online now        Reply With Quote Quick reply to this message
Old 01-15-2020, 10:09 AM   #3 (permalink)
yeah I was looking to reduce it. Just seems excessive compared to my other setups. Its not exactly causing me any headache, more of an OCD thing I guess....lol. Thanks for the info Don!
Old 01-20-2020, 12:27 PM   #4 (permalink)
Yeah, there is a way. It is in there to compensate for stick wear. I had to do it often when running Spektrum Tx's. I haven't had to mess with it since I went Jeti, yes, I am a Knight now. Lol.
Lemme check and I will get back to you since I haven't done it in like three years. It was or is called stick dead band and Alvin Chai did a good writeup on how it was done.
Old 01-28-2020, 02:07 AM   #5 (permalink)
As Keyrigger mentioned, this should only apply during setup, i.e. when the USB is connected to a PC. Does this dead band also occur when the USB is disconnected?
Nelson JR DSX9 II; Stretched Atom 500 in Bell 222 body , Stretched TRex550 in 600 size AS350 - . Trex 450 S and 550E for sport . practice.SK720 all round..
npomeroy is offline        Reply With Quote Quick reply to this message
Old 01-28-2020, 03:31 PM   #6 (permalink)
HF Scale Support
Actually, right on the main page, there is a Dead Band adjustment box. It is default set to 2% of stick travel around the center. With that in mind, the only stick that will actually have it active at the center is the rudder because you will be above (or below) center stick when you are actually flying. If you have a twitchy hold on the stick, increasing the dead band will help smooth out the servo movements. I am not sure if the dead band is a constantly moving setting that follows the position of the stick or not. It could very well be exactly what happens.
I am not sure that disconnecting the USB will automatically put the gyro into flight mode. I think the standard method of operation is to make the changes to the gyro then power down everything and start up normally. I do not recall that I ever left the power on to the gyro while I disconnected it from the computer. I am not sure what, if any, issues might come up. The pitch dead band (or slowdown) is there when the USB is connected and once the gyro is shut down and restarted with radio link only, that very noticeable dead band is removed and normal programming takes over. Hope this might help.
Don
Old 01-28-2020, 03:35 PM   #7 (permalink)
The OP is talking about collective.
The dead band adjustments are cyclic and rudder - as far as I can see..
Edit - Don I stand corrected w.r.t. disconnecting the USB - I thought the point, already made, was that the collective dead band was merely a feature of the programming mode.
Old 01-28-2020, 06:52 PM   #8 (permalink)
HF Scale Support
I was doing a bit of research about what the 2% Dead Band is really referring to. It is 2% of the resolution of the travel, not the stick motion per se. If we have a total travel resolution of 1000ms, then 2% of that would be 20ms. However, if you set your stick Dead band to less than 2%, you may have constant buzzing from the servos when the sticks are at rest. The stick Dead band and the Setup dead band have nothing in common so there is nothing to worry about when you see the dead band while connected to the computer. Some of this is a bit off topic, though. Take care.
Don
Old 01-29-2020, 03:43 PM   #9 (permalink)
Nothing I've tried or adjusted has impacted the collective that I was initially asking about. I understand what the dead band is with regard to the right stick but nothing changes collective.
Let me know if you guys come across anything
Old 01-29-2020, 11:11 PM   #10 (permalink)
HF Scale Support
If you are asking if the dead band, while connected to the computer, is adjustable, then no, it is not. It is a fixed setting that is used to set the collective so you have a dead area right at "0" to level the swash. This does not work during normal operations. I thought that was answered. If this is still not the case, please make a more detailed description of what you are doing and when. Product support has long gone away so this is the best that can be found. Note: I am about to take out the last of my Skookum gyros after nearly 10 years of service. Take care.
Don
Old 01-29-2020, 11:44 PM   #11 (permalink)
To be clear Sloan, when you are not in setup mode, i.e. powered up and ready to fly, do experience a dead zone on collective?
Old 01-30-2020, 01:58 AM   #12 (permalink)
It when it is not hooked up to a PC or in setup mode. It is when powered up, ready to fly...that is the situation I'm asking about.
Old 01-31-2020, 05:07 PM   #13 (permalink)
That, is done with your Tx. The other dead band is to take account for stick slop or wear during setup. Most my Spek Tx's I could watch the numbers move on left stick without touching the sticks during setup so I widened the zones around zero.
Old 10-13-2020, 07:11 PM   #14 (permalink)
You think?
Idaho Spud is offline        Reply With Quote Quick reply to this message
