Old 01-18-2020, 12:35 PM   #1 (permalink)
Default Mikado yge esc with vbar 5.3 gov
I’ve been flying this combo for years in more than one heli, but only recently setup rpm telemetry.
Upon initial spool up say I have IU1 with 1800 rpms set, it will initially overshoot my target rpms as much as 150-200 higher, then will settle and it seems to fly fine by me. It takes maybe 5-8 seconds to settle down. I’ve always just lived with it.
I just did a new setup with a vbar I had in my parts bin, but I didn’t start from scratch.
I noticed my gov gain was pretty low like 15 or 18.
Would this main gov gain sort this out? Like 30 maybe? If I recall that is the default. I believe I have had them set lower from watching Mr Mels videos from back in the day.
Steve
smittylube is offline        Reply With Quote Quick reply to this message
Old 01-18-2020, 02:25 PM   #2 (permalink)
I've had the yge act funny sometimes too. I recommend going through the full throttle calibration and then throttle hold percentage setting over again. That usually makes it better for me. Fwiw...
AMA 373608
K2Freak is offline        Reply With Quote Quick reply to this message
Old 01-18-2020, 06:10 PM   #3 (permalink)
So I flew it a few today. and initial spool-up is about 2010 rpm and settles back to 1840.
What is the best way to calibrate the endpoint if I am going through the Vbar..
Set 0-100 throttle curve in radio,
Verify +/- 100% on the transmitter tab.
Turn off gov
Full throttle power up deet deet
0 throttle deet deet
unplug power.
Reenable gov and set endpoints in the gov tab?
But should I raise the gov gain?
Steve
Old 01-18-2020, 07:15 PM   #4 (permalink)
Default Fix post
I went through the gov endpoints, tried it on the bench no blades it would overshoot exactly like when I was flying.
Tried the gain from 16 up to 25 still same.
I had raised the spool-up speed (expert panel) from 3 to 6 to get to the speed faster so I tried back to 3 and it just runs up and settles. I guess I'm not an expert.
Steve
Old 01-18-2020, 08:20 PM   #5 (permalink)
You did exactly what I was talking about. When you go in and out of throttle hold does it overshoot during the fast spoolup?
AMA 373608
Old 01-18-2020, 08:53 PM   #6 (permalink)
I forgot to try that.
Initial spool up is good. Will try it flying next time.
Steve
Old 01-18-2020, 09:07 PM   #7 (permalink)
I run the Vbar gov gain above 50 on my birds, but I realize that that has absolutely no bearing on your set up.
AMA 373608
Old 01-18-2020, 10:58 PM   #8 (permalink)
Steve does this help? https://www.vstabi.info/en/node/2031
Check out the section titled "Vbar neo electric governor - integral and min limit"
They mention the overshoot you are chasing. Looks like your basic throttle might be set too high. I forget if you have a neo or silver line. But the concept should translate over to both.
P@reez is online now        Reply With Quote Quick reply to this message
Old 01-18-2020, 11:47 PM   #9 (permalink)
I've never seen this issue with neo. I've only had 5.3 demonstrate the RPM mayhem. If I read the op question right that's what he's running.
/E It seems weird but I have had the throttle hold percentage affect the spool up with vbar. I have a lot less hours expended with the Neo but I've had none of the problems that I had with 5.34. ymmv
AMA 373608
Old 01-19-2020, 11:03 AM   #10 (permalink)
Yes 5.3 old school this heli is mini blue vbar.
Thanks guys.
Iíve never really spent any time tweaking the gov. After flying the tribunus it has made me think about adjusting the vbar yge combo.
Steve
Old 01-19-2020, 11:54 AM   #11 (permalink)
If the TC is set up too high (too much basic throttle) the rpm overshoots first and will be taken back by the integral afterwards.
Interesting. Good find.
AMA 373608
Old 01-19-2020, 12:47 PM   #12 (permalink)
I did have tc at 106, reset to 100 but it still did it till I went back to spool up default 3
Steve
Old 01-20-2020, 04:56 PM   #13 (permalink)
Startup slow spool to set rpm worked perfect, bailout overshot similar to startup when I had it faster.
25 gain seemed fine. it was cold so I'm not sure if I should go higher on the gains.
The link about tuning made me really think about the collective add and such in the expert menu. I think I might try some things.
I also noticed how if I overspeed with the load removed the ESC did overspeed and measured telemetry RPMs followed somewhat. The Tribunus keeps the RPMs at the set speed period. It's not all bad with the rotor spooled up because you can have some fun with it.
Steve
