Go Back   HeliFreak > R/C Electronics Support > OpenTX Radios
OpenTX Radios OpenTX Radios Discussion and Support Forum
Old 02-01-2020, 04:42 AM   #1 (permalink)
Default Nitro Soft Start
I want to try a Aerospire Multigov in my 600n using a Qx7 and I don't want to use a normal mode. Opentx should be able to handle a soft start, but I am having trouble figuring it out.
Even though the RPM value is set in the Multigov, Aerospire wants a V-curve so it knows when you are adding pitch. Coming up off of idle the governor takes over at 70% of the target RPM.
In flight mode 1 I tried using fade in to slow the throttle as it rises from -95 after coming out of throttle hold. The actual result is it jumps to zero then slowly rises to the value in the V-curve.
Does anybody know of a way to make the throttle slowly rise from -95 until it gets to the value dictated by the V-curve? Any help is appreciated. Please see attached file.
Note, you will need to change the file from .pdf to .otx to open it. Helifreak won't accept .otx files.
File Type: pdf Soft Start Test.pdf (595 Bytes, 5 views)
Hydros27 is online now        Reply With Quote Quick reply to this message
Old 02-01-2020, 04:56 AM   #2 (permalink)
I just figured it out. I made another flight mode with the -95 value instead of using override in special functions. Works fine now.
