Go Back   HeliFreak > R/C Helicopters > Newbies: Tips and Information
Newbies: Tips and Information Section of HF, specifically for Passing along info to newcomers to the hobby. Setup, tweaking, orientation practice, etc.
Like Tree1Likes
Old 11-27-2005, 02:50 PM   #1 (permalink)
Default Some Great Tips for Newbies
Here is some links on Rick's R/C website that are great tips for newbies and veterans also.
Since this is the time of year that there will be an influx of newbies into the hobby. Thought it would be good time to post some of the tips.
Throttle setup
http://www.ronlund.com/throttle.htm
Tail Rotor Setup
http://www.ronlund.com/tr_setup.htm
PCM Failsafe
http://www.ronlund.com/fail_safe.htm
Antennas
http://www.ronlund.com/antennas.htm
Some great advice
http://www.ronlund.com/getting_help.htm
The above links are some great advice that Ron has posted. Use the information and it will help overcome some obstacles.
David
DavidH is offline        Reply With Quote Quick reply to this message
Old 09-14-2008, 03:42 PM   #2 (permalink)
Thanks,appreciate your help.
David Harris is offline        Reply With Quote Quick reply to this message
Old 09-21-2008, 05:43 PM   #3 (permalink)
are there any tips on how to tune a max 91SZ-H PS-HYPER, mine seems to be smoking and spitting out fuel quite a lot. it has only done 1 flight so far,
bullmastiff2447 is offline        Reply With Quote Quick reply to this message
Old 10-05-2008, 10:16 AM   #4 (permalink)
you are to rich still.
madmax22 is offline        Reply With Quote Quick reply to this message
Old 10-06-2008, 06:40 AM   #5 (permalink)
Some good advice there, thanks =) im a newbie, been learning & flying since april this year (2008).
Xige is offline        Reply With Quote Quick reply to this message
Old 10-19-2008, 11:20 PM   #6 (permalink)
Throttle setup
Tail Rotor Setup
PCM Failsafe
Antennas
Some great advice
David
Thats some great info, I will be setting up my servo's tomorrow. Man. how long does it take to master hovering on a simulator. I am building a trex 450sa and am practicing with one a RF simulator, that thing is all over the place! every day i get a tad better but still can't hold that thing still! Any tips?
sonnyhad is offline        Reply With Quote Quick reply to this message
Old 11-28-2008, 08:44 AM   #7 (permalink)
Guys Im very new to this stuff and Im confuse bout my gyro... Its a JR piezo G420T gyro. The switch on it says "tail lock" on & off? Now what is that? How do I set it on or off? Pls help. And 1 side is binding the other 1 is ok. If I adjust the ATV the movement of the servo slows down.
Dondenso is offline        Reply With Quote Quick reply to this message
Old 11-30-2008, 03:55 AM   #8 (permalink)
BEST tips for newbies:
https://www.helifreak.com/showthread.php?t=41692
Terry
AMA#47402, IRCHA # 3395
Pinecone is offline        Reply With Quote Quick reply to this message
Old 12-12-2008, 01:24 AM   #9 (permalink)
yup thanks mate..
RedDragonCopterx is offline        Reply With Quote Quick reply to this message
Old 12-23-2008, 11:31 AM   #10 (permalink)
Member
sonny, the 450SA is super sensitive on my FSOne and there's no way to adjust it as far as I could find. I just kept at it until I was able to do it. Figure it took at least 20 crashes before I could hover it, and it still wasn't pretty. Now I can hover steady, and do forward flight. Still doing tail in, nose in still gets me in trouble really fast.
You might give HeliSimRC a try. I have that as well and you can adjust lots of stuff and load different model set ups. For instance, there is a "gentle" model, a "sport" model and one other one I can't remember its name. I figure I have about 10 hours of sim time, and I'll probably get another 10 to 20 hours before my heli is built and set up. Biggest thing I've found with the sim is to maintain your patience and discipline. Keep at it, and don't just fly around doing sloppy manuevers. When I get on the sim, I plan for at least 30 minutes per session, and I try to improve each time.
The time you spend on the sim will pay off, just keep at it.
Old 01-06-2009, 01:16 PM   #11 (permalink)
Default thumbs or pinch method ???
which is a better method ,when using the transmitter ,with thumbs or the the two fingers
method.
thanks
ray
ray jr. is offline        Reply With Quote Quick reply to this message
Old 01-06-2009, 01:46 PM   #12 (permalink)
method.
thanks
ray
I've been told that even though it's easier to learn using just thumbs, movements are more accurate using the index finger/thumb pinch.
With that, I've been using RealFlight for a couple of weeks and I just think it's more comfortable using the index finger/thumb (especially with the sticks all the way out).
In the end though, either way is probably fine. I originally decided to only train by using my index finger/thumb because in all the videos/pictures of the "pros" I've seen that's how they do it.
--Chris ^_^
DarkStarPDX is offline        Reply With Quote Quick reply to this message
Old 01-06-2009, 01:54 PM   #13 (permalink)
Default thanks DarkStarPDX
i used the finger thumb method,but than i saw finless use his thumbs ???
both seem easy, ill keep using the finger thumb method
thanks
ray
Old 01-06-2009, 03:12 PM   #14 (permalink)
It all boils down to personal preference....whatever is more comfortable to you. There are pro's that fly with thumbs and pro's that pinch....
Skarn
Skarn is offline        Reply With Quote Quick reply to this message
Old 01-07-2009, 09:00 AM   #15 (permalink)
And that's why this question comes up about every two weeks.
Do a search and there are several LONG threads about it.
I do a combo fo both, thumb on top with finger in front.
Terry
Old 01-09-2009, 06:50 PM   #16 (permalink)
You mean using my forehead is not an acceptable way? Damn, been doing it all wrong this whole time - I guess that's why I crash so often....lol
schwarztrader is offline        Reply With Quote Quick reply to this message
Old 01-18-2009, 05:28 PM   #17 (permalink)
I use thumb on right and 2 fingers on left.
I have fast input on cyclic and precision on trottle. and rudder
Pitbro50 is offline        Reply With Quote Quick reply to this message
Old 02-19-2009, 07:15 AM   #18 (permalink)
Talking
i use no finger at all
(watching Szabo, Riva, Scott, Nigel Brown etc videos & imagine it as me as the pilot)
A bunch of broken, abused, beaten & doomed 450s....
The Mighty Flybarless Dust Kickin' Duo, T-Rex 550e & 600NSP
Adnan_Mokodompit is offline        Reply With Quote Quick reply to this message
Old 02-20-2009, 12:54 AM   #19 (permalink)
method.
thanks
ray
Correct me if I am wrong, but isn't the best method the one that works for you?
D W Gwinn
AMA #895632
Axe Ez, Axe CP, Blade MCX, HDX 450SEv3, HK-450, HC-500
dwgwinn is offline        Reply With Quote Quick reply to this message
Old 02-22-2009, 10:39 AM   #20 (permalink)
Default Beginners MUST!!!
I was so scared to set up my new helicopter (EXI 450) because i noticed that the gyro takes over after a certian adjustment value on my knob, this causes the servo to go way to the extreme and back track from there. SO, being a beginner I came up with this Idea!!
Please reply to [email protected] for instructions to build.
This will let you set up any helicopter, and even let you practice flying without crashing!!
Get the feel for it?
It Pivots and rotates on the spring to allow all movements from a helicopter, and it is fully adjustable on the spring tention by screwing the spring in or out..Just mount the helicopter to the plate and simulate Flying safely without crashing!!!!
ZAOAOAOZ is offline        Reply With Quote Quick reply to this message
