Like Tree803Likes
Old 02-07-2020, 08:01 PM   #41 (permalink)
Today I installed some new servos in my GAUI NX5
And installed a return spring
rdlohr and mqowen like this.
Keith - XLPower | KST | Egodrift
Protos 800X Evoluzione | Protos Nitro | Specter V2 | Protos 380 Evoluzione V2 | OMP M1
KC3D - 3D Printed Heli Upgrades, Charge Cases and More, RC Electronics Repair Services
Number is online now        Reply With Quote Quick reply to this message
Old 02-07-2020, 10:34 PM   #42 (permalink)
Just pulled some castle logs from the Trex500. And doing some FBL tuning on that model. Slightly lowering Headspeed and going a click or two north on the blade pitch. my 700 needs a bit of tail tuning. I went out last week and flew it 6s, just need to dial the tail and setup a bank for LOW headspeed stuff on tail gyro settings.
-M
rdlohr likes this.
*LINKS*
* G700c BRAIN2 * T-rex 500 *308DUO *450x #429
Relisys190 is offline        Reply With Quote Quick reply to this message
Old 02-08-2020, 09:03 AM   #43 (permalink)
This was exactly what I had in mind. Hope you guys are enjoying it as much as I am. Great responses!
Rick
Relisys190, mqowen and Number like this.
Helifreak, the place to be!
rdlohr is offline        Reply With Quote Quick reply to this message
Old 02-08-2020, 09:40 AM   #44 (permalink)
Going to swap out the main / tail shaft bearings and the tail belt on my goblin 380. Thrust bearings will be getting some fresh boto lube also.
Oxy2 215 sport / Oxy4 325 pro stretched to 360
Goblin fireball / 380 / 500 sport / kraken 580
Kds Chase 360 / 470l / 550x / 650x Dominator / xlpower 550 / 700
beastx / Helithunder( https://www.youtube.com/channel/UC1X...s3ZRqyqpkMA11Q )
Helithunder is online now        Reply With Quote Quick reply to this message
Old 02-08-2020, 10:42 AM   #45 (permalink)
Rick
This and the what's out for delivery today thread go hand in hand... what did you get, then what did you do
Old 02-08-2020, 09:57 PM   #46 (permalink)
Great idea for a thread!
I got to work on my Logo 600s tail assembly a little bit. I found that the end of the boom had gotten pinched somehow, and was out of round. I put it in the tail clamps, tightened up the screws, and squeezed it back into shape.
Relisys190 likes this.
*Spartan Vortex VX1e*
Old 02-08-2020, 10:25 PM   #47 (permalink)
Installed the 19T pinion upgrade in my GAUI NX5... gonna see if this 55 can push 2700rpm
Deadpony likes this.
Old 02-08-2020, 10:51 PM   #48 (permalink)
Installed an Aerospire Multigov in a Trex 600n. Flew 1 tank today and it is already better than the fbl governor I was using.
Hydros27 is online now        Reply With Quote Quick reply to this message
Old 02-09-2020, 07:35 AM   #49 (permalink)
Originally Posted by JimJW View Post
I’m waiting for some spacers for mounting servos to my Gaui X5.
In the meantime I checked my Oxy 2 over to see why it started so hard last time I flew it. Quick check that the motor wires were all there, pulled the blades off, spun up just fine, put blades back on. Scratch head...
Checked my order tracking.
Spacers came in, it’s snowing outside, I’m mounting servos on my Gaui today... Then setting up the swash & tail links. Maybe even wiring, man am I bad at wiring... (can I just use the rats-nest method?!)
Jeti DS12 / Ikon2 / Oxy2/4/5 / SAB Mini Comet / Fireball / G380 / Gaui X5v2 / Kraken 580
Old 02-09-2020, 06:33 PM   #50 (permalink)
I worked on remembering how to fly. I hadn't touched the sticks since the season ended here in cold country. I set down with the simulator and worked out my thumbs for 20 minutes. Its never like the real thing but it was fun to fly again. Hopefully I can be faithful and get in regular flights between now and Spring.
Rick
ArmchairNinja likes this.
Old 02-09-2020, 07:05 PM   #51 (permalink)
Been spending half this afternoon installing Steam/Accurc
Maybe I will get to fly it in a week or so...…….
bikneli is offline        Reply With Quote Quick reply to this message
Old 02-09-2020, 07:20 PM   #52 (permalink)
dze
i got a few things going on for winter and go back and forth .. still working on my vintage hbk2 got a spartan working i bought from a guy here like 7 years ago, i had farted with it once and thought it was probably bad but nope, i just didnt realize it needed a decent dam servo to work haha .. works beautiful .. thanks man whoever you were ... aaand im working on trying to get 3 old rs4 mt's i was given in boxes restored ...
ID:	841507   Click image for larger version
dze is offline        Reply With Quote Quick reply to this message
Old 02-10-2020, 12:04 AM   #53 (permalink)
Tonight I spent a little time redesigning my electric fuel pump battery mount to incorporate a 3 position momentary switch (MOM-OFF-MOM). Just leave the switch on the pump itself set to on and the momentary switch actually controls it. Much easier to top off a fuel tank with this because as soon as you release the pump turns off, rather than having to flip the switch off before fuel starts squirting everywhere.
Works pretty well
20200209 220305 (0 min 10 sec)
Old 02-10-2020, 08:28 AM   #54 (permalink)
I will be installing a carbon folding tail rotor on a 230. Have one on my other one and love it. Also working on the setup on a Bavarian Demon Axon. Flying inside too!
JohnCl is offline        Reply With Quote Quick reply to this message
Old 02-10-2020, 11:40 AM   #55 (permalink)
Finally got started on my "Winter Build".
rdlohr, CrazyComi, jrman83 and 3 others like this.
Current Fleet: Goblin Raw 700, Black Thunder 700, Protos 380 Evo, Oxy 3, Oxy 5, OMP M2
Member of: AMA, IRCHA, Fort Wayne Flying Circuits, Summit City Aerospace Modelers
ArmchairNinja is offline        Reply With Quote Quick reply to this message
Old 02-10-2020, 12:27 PM   #56 (permalink)
Terrible weather at the moment and going into next week - constant gusting winds of 45-60 mph and day temps of 3 to 5 C So a good opportunity for some deep maintenance and general all over checking of airframes, connectors & wiring - plus one or two small mods that I have been meaning to do for a while.
Cyclone7 is offline        Reply With Quote Quick reply to this message
Old 02-10-2020, 12:48 PM   #57 (permalink)
Originally Posted by blarks View Post
Not entirely heli related, but as per Rick's rules, I am posting here on helifreak, so, kinda doing heli related stuff right?
Going to make some chips, not sure what I'm going to do yet and I'm still teaching myself, so Fusion 360 open and hopefully a light bulb turns on above my head.
sweet machine dude!
XL Power Protos 380 Evo 0xy4 Max Goblin Kraken 580 Goblin Kraken 700 Ix20 Ikon2
Ravmano7 is offline        Reply With Quote Quick reply to this message
Old 02-10-2020, 02:31 PM   #58 (permalink)
Been working on my Oxy 5 today and finished everything up. Offcourse the very last step in the setup proces blocks the joy of it's first spoolup. Vcontrol doesn't initialize the Scorpion ESC wizard (app), where it did before I installed everything in the frame.
Tomorrow I'll unplug and start troubleshooting. Also gonna remove the microbrain from my Oxy2 and install a Neo on there that I bought today from a fellow HF member. I'm sticking with one Tx.
Goblin 700 Competition (sold) | Logo 480 xxtreme (sold)
Lynx Oxy 5 Neo I Lynx Oxy 2 Neo
Vbar Control I AccuRC
TimZ is offline        Reply With Quote Quick reply to this message
Old 02-10-2020, 02:52 PM   #59 (permalink)
@ArmchairNinja what's in the small Lynx/Oxy bag on the left? Is that the motor support thing I keep hearing about?
XLP Specter V1, XLP 550, Oxy 4 Max, Oxy 2, OMP M1
Spirit GT Egodrift & XNova, YGE & Scorpion, FrSky Horus OpenTX
WTB XLP Wraith for cheap
xoexoe is online now        Reply With Quote Quick reply to this message
Old 02-10-2020, 03:05 PM   #60 (permalink)
I’m ordering more bolts for my Gaui X5. It seems that none were included to mount the balls to the servo arms. Made an order from boltdepot.com with about 5x bolts of each size from M2 to M3. Arggggg..... (It’s the 3rd small parts order since I started the build)
If only I could source M2 bolts locally.
