Like Tree6Likes
  • 3 Post By acrow
  • 3 Post By john2kx
Old 02-18-2020, 07:09 PM   #1 (permalink)
Default Throttle drop when Mah alarm is hit
I have a specter 700, hw160esc, scorpion 4530 motor and the DS-14 radio. I have the esc voltage cutoff set to none. in Airplane mode, there is nothing on the brain settings I can see that would lower the throttle.
I've seen nothing in the Jeti menus that would lower the throttle either, but at the same time it hits the mah alarm, it seems to drop instantly to my lowest headspeed.
Any thoughts?
Specter 700, Protos 700 Gasser, XLPower 550, Protos 380 - Jeti DS14
Citizen - #202
Dowquest is offline        Reply With Quote Quick reply to this message
Old 02-18-2020, 07:15 PM   #2 (permalink)
Subbed
Goblin Kraken / Specter v2 / Protos Nitro / Logo 480(4) / XL 380 / Oxy 215
Jeti DS-12 Carbon / Brain2 / Hobbywing Factory Team Pilot
DIY Night Heli Tutorial
BuildFlyCrashRepeat is offline        Reply With Quote Quick reply to this message
Old 02-19-2020, 05:26 AM   #3 (permalink)
The callout of the mah alarm really shouldn't, like you say, change head speed. If I was wanting to do that, I would set up a logical switch to set my idle up to idle 1 given the mah alarm activating. You would know if you programmed that
You could try lowering your alarm threshold--say from 3000 mah to 2500 mah and see if it drops head speed at that value. This would tell you if you are running all the way to where the batteries cannot supply voltage and the rpm drop is battery voltage caused rather than alarm caused. If that's not it you might dig through the advanced menus and flight modes to see if something got set.
Dan
No-Team; Non-Rep, no-skill. Free advice worth every penny.
dogbreath is offline        Reply With Quote Quick reply to this message
Old 02-19-2020, 05:39 AM   #4 (permalink)
In your Brain setup, go to Advanced Menu -> Common -> Throt. & Gov -> Telem Input and check whether there is a value set in "mAh Useable". If there is, it will reduce the throttle value to 80% when this value is exceeded.
acrow is offline        Reply With Quote Quick reply to this message
Old 02-19-2020, 05:50 AM   #5 (permalink)
Timers/sensors>alarms: in alarms for capacity, you didn’t happen to check box “set throttle idle” near bottom of menu?
Gaui R5 Kosmik 200, Scorpion HK 4235-630
TDR (build in progress)
Raptor G4 720e xnova 4530-525 Kosmik 200
Gaui X5 Jive 100 Scorpion 910, Jeti DS-16
john2kx is offline        Reply With Quote Quick reply to this message
Old 02-19-2020, 08:50 AM   #6 (permalink)
+1 my thinking exactly.
Old 02-19-2020, 12:22 PM   #7 (permalink)
I've never paid attention to that "set throttle to idle" setting. I learned something! Good thing I didn't ever check it by accident.
Dan
Old 02-19-2020, 01:01 PM   #8 (permalink)
Dan
I must say that I have always wondered about the use for it.
The same for ESC that have the option to cut throttle when battery gets low.
Give me mAh and Voltage telemetry any day over these options.
Old 02-19-2020, 10:59 PM   #9 (permalink)
Nope
Citizen - #202
Old 02-19-2020, 11:08 PM   #10 (permalink)
Thumbs up
Winner winner...
I'll change this to 4500 and see what happens. Makes sense for what happens. My batts are coming back at 27% remaining, so I am certain they are not being overdrawn. Also, lowest cells are 3.77. Thanks for all the suggestions.
Name:	mah useable.jpg
Citizen - #202
