Go Back   HeliFreak > R/C Electronics Support > Spektrum FBL System > Spektrum FC6250HX
Like Tree9Likes
Old 06-30-2020, 07:20 AM   #21 (permalink)
Please send me your contact information via pm here and I will have someone from PS contact you to setup the RMA or send out a replacement based on how they would like to proceed.
Best Regards,
Brian Bremer
Horizon Hobby, LLC
brianbremer is offline        Reply With Quote Quick reply to this message
Old 08-11-2020, 08:52 AM   #22 (permalink)
Default Returned FC6250HX unit
Brian,
I apologize I did not see your last reply. I sent the FC6250HX unit it several weeks ago and requested it be sent to you for your inspection. I hope it got to you. I have not heard anything as of yet but when you figure out what happened I am interested to know. I will PM you my contact information in the event you need it. Thanks again Brian
PWeart is offline        Reply With Quote Quick reply to this message
Old 10-29-2020, 08:54 AM   #23 (permalink)
Brian,
Final update....the second FC6250HX FBL unit works perfectly and is VERY user friendly...I did receive a replacement unit for the one I returned so I'm looking for another heli to put it in Thank you for your help along the way!!
Old 12-10-2020, 03:27 PM   #24 (permalink)
Can we make this thread a sticky? Brian's info in post #1 is super helpful.
When should one adjust the degrees per second in the tail rotor PID menu? And how does adjusting "agility" change the feel of the heli?
Tobbe Arnesson likes this.
Blade Fusion 270, Blade 360 cfx
HoverMe is offline        Reply With Quote Quick reply to this message
Old 12-11-2020, 06:06 PM   #25 (permalink)
HF Scale Support
If you are happy with the rate of response of the aileron, elevator, and rudder, then you most likely don't need to adjust the rate of rotation. If you want to slow it down, there are two ways to do it. One, is to adjust the rate to a slower or faster rate but this will be an across the board change. Two, is to make your rate of rotation as fast as you need it to be, then use your dual rate settings per Flight Mode, to reduce the rotational rate. You need to change the settings so you have a channel set for active Flight Mode changes.
An example. You have chosen 300d/s as the fastest rate so let's say you want that on flight mode 1. For Normal, you feel you need it to be half that rate so you make your Dual Rate for your Aileron at 50%. That will give you Normal at 150d/s and FM1 at 300d/s. You need to adjust each of the Aileron, Elevator, and Rudder channels for the rate you want. You need to see that you are now flying by wire in that you are not setting the movement of the channel but how fast the model rotates about each channel axis. The gyro is controlling how the model behaves according to your settings. Hope this helps.
Don
HoverMe likes this.
Old 12-19-2020, 05:32 AM   #26 (permalink)
Default Tail Gain adjustment
Hello
Im Matt and new here. I have 8 Helicopters all with the FC6250HX inside.
now I have the new t-rex 650x and need a bit more gain at the tail.
I have a dx7 g2 and have @ Satellite, 6250 and transmitter the actual firmwares. My problem is that I have no changes at the tail gain if I set it to 50% or set it to 100%.
Im sure I have set up in the dx7 and the 6250 all right.
If I change for a test in the 6250 the gyro channel to the flightmode channel and change in the transmitter gyro menu the values the flight modes are switching.
Have maybe anywhere a idea what is the issue.
Matt
T-rexr is offline        Reply With Quote Quick reply to this message
Old 12-21-2020, 04:48 PM   #27 (permalink)
Matt,
Follow the initial post and use the tx gyro gains listed, increase the fwdprog P and I tailrotor gains slowly and test fly per the recommendations in the initial post. Set d to 10% and only worry about the P and I for now.
Considering the 650x's 1 : 3.85 tail ratio you will need to bring the fwdprg base gains up quite a bit.
Once the fwdprog->tailrotor gains are set you can make small tweaks with the tx gyro gain function and you will see a variance in the performance.
Regards,
Horizon Hobby, LLC
My Projects: 150 S, 200 SRX, 200 S, 230 S v1/v2, 270 CFX, Fu270, Fu480: AR636/AR6335 Heli, FC6250HX, AR6250MHX
Old 01-05-2021, 06:07 AM   #28 (permalink)
Thank you Brian for the info, Im happy now with the tail.
I Have a few points in the fwdp menu with no ideas what i can change with this. Maybe you can short expain me for what canges/Settings it is.
Firmware is 5.05.00
Setup>Swashplate:
-E-Ring
-Phasing
-Decay
Setup>Tail Rotor>Advanced Setup:
-Phasing
Main Menu>Tail Rotor:
-Start
-Stop
Thank you so much.
Matthias
Old 03-04-2021, 12:56 AM   #29 (permalink)
Agreed!
Tobbe Arnesson is offline        Reply With Quote Quick reply to this message
Old 03-04-2021, 06:05 AM   #30 (permalink)
stuck
Keyrigger, Bluebell and HoverMe like this.
Helifreak, the place to be!
rdlohr is online now        Reply With Quote Quick reply to this message
