100 Class Electric Helicopters 100 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
#1 (permalink) |
![]() Does anyone know an easy way to install the little spur gear onto the motor shaft on the xk k110? Seems like a very tight fit. Somehow the stock one got loose and started sliding from the main gear. Didn't think that was possible
#2 (permalink) |
![]() They are sort of the safety valve on the K110. Use a knife to gently pry the old one off. Notice the notch in the hole and shaft, line them up, be careful not to push on the blade grips.
#4 (permalink) |
![]() Clean the shaft and gear with some meths then use a toothpick to put the smallest dab of loctite retainer on the tip of the shaft and slide the pinion into place with a twist. I've just had the same problem myself but with a bigger motor and it's holding up ok.
#5 (permalink) |
![]() Oops, I re-read your post and it looks like you might have lost the old one so you have a different problem. It's a very thin shaft and it's going to bend if you use any force incorrectly. You need to support the motor so it's secure, I would use a wood bit to make a hole in an off cut and drop the motor into that, use some tape around it if it's a bit loose, then heat the pinion up. I would use the oven or a pencil torch, then when it's up to temp quickly drop it onto the motor shaft using something light weight like a pair of tweezers so you don't soak the heat out. If it freezes before it's right home you will need carefully press it the last bit with a vice. If it does go right home first time quench the the assembly with a damp cloth to stop the heat going into the bearing. Just my ten cents.
