Go Back   HeliFreak > R/C Helicopter Support > 100 Class Electric Helicopters
100 Class Electric Helicopters 100 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Like Tree5Likes
  • 2 Post By RustyChain
  • 1 Post By PassinThru
  • 2 Post By torpicaltrail
Old 05-18-2020, 11:15 AM   #1 (permalink)
Default Best out of box BULLET PROOF heli?
Title says it all. What's the best out of box heli that is bullet proof?
Black mamba 2011 is offline        Reply With Quote Quick reply to this message
Old 05-18-2020, 11:30 AM   #2 (permalink)
Indoors or outdoors?
If Indoors: Living room or triple gym?
Walkera Devo 10/DeviationTX (12CH DSMx & telemetry)...Ex-DX8...Blade 4503D...Walkera V120D02s...XK K110...Blade 200QX quad...Ex-NanoCPX...Ex-120SR...StrykerQ (LEDs, M2 tuning)...Ex-MPX EGP...PPZ P51-D...PZ Wildcat (searching fuselage-firewall)
Thomas.Heiss is offline        Reply With Quote Quick reply to this message
Old 05-18-2020, 11:39 AM   #3 (permalink)
For a more crashbomb proof outdoor heli it IMHO makes sense:
- to go 1s
- less weight as possible: ~45-60g (max)
- there are some micro (CP) helis which only weight: ~32g
If you go higher in the 120-150/160 class (2s) (either motor driven tail or torque-driven tail (TT)) and you have a weight in the 100-150g range (130X, V120d02s, Trex 150X), then more will be damaged if you hit hard or with the wrong angle.
But it might still work out if you accept some repairs and you are not a beginner.
The newest (announced) 2s heli will be the Eachine E160.
If you go into the 240g (Blade Fusion 180, 4s) or 339g (Blade 230s V2, 3s) weight range you will have to replace more things when you crash, especially if you are not fast enough activating the rescue or hitting the hold switch (=motor OFF).
...or maybe I have misinterpretated your question as I'm not an English native speaker.
What heli are you searching for?
Old 05-18-2020, 11:43 AM   #4 (permalink)
Default M2 from Omphobby
The Best the heli so far. It is easy to fix if you crashed . Very minimal parts.
minh88888 is offline        Reply With Quote Quick reply to this message
Old 05-18-2020, 11:59 AM   #5 (permalink)
I am curious: How good is the OMP M2 alu material? Especially once you have crashed? Does it withstand the crash a bit?
What are the most broken parts? (yeah, I know, every crash is different depending on the angle and how fast you activate the hold switch or rescue)
So far I have no problems with the Blade 4503D alu head block and alu flybar seesaw holder and I had three crashes (1st and 3rd were extreme).
How do you know if something is slightly bent and what is the reason for bad vibrations (e.g. head block, blade holders, alu washout control arms,...) when it does not completely break?
Old 05-18-2020, 12:05 PM   #6 (permalink)
K110.
Its really actually breaks, more like the parts just wear out real fast. Fly over grass and the main gear will be probably the only thing to fix. It pops off, then you pop it back on. You can usually do that 8-10 times before the hole enlarges and you need a new one.
Haven't crashed the M2, but I get you're gonna need a handful of parts. Looks easy to fix though.
RustyChain is online now        Reply With Quote Quick reply to this message
Old 05-18-2020, 10:21 PM   #7 (permalink)
- to go 1s
No you're good, you got the idea. And yeah I definitely think I need to stay smaller than a 230s. I have a 230s and let's just say I could have built it from scratch at least a half dozen or more times.
I have a CPS and put a brushless inrunner on it, but I feel like I'm still going to just go through the entire heli a bunch of times and spend just as much as I would on something hardier in the long run.
Old 05-18-2020, 10:23 PM   #8 (permalink)
Originally Posted by minh88888 View Post
The Best the heli so far[IMG class=inlineimg]https://www.helifreak.com/images/smilies/BaconDance.gif[/IMG]. It is easy to fix if you crashed . Very minimal parts.
Yeah that thing looks strong and simple! I just wish it wasn't 2-3× the price of similar sized helis. I'll have to take a better look at it and see what the spare parts cost, the initial buy in is quite excessive lol.
Do you know if I can use a Spektrum tx on it?
Old 12-10-2020, 05:02 AM   #9 (permalink)
Originally Posted by RustyChain View Post
K110.
I followed a suggestion I saw online to use a small nut to make it grip again. It was quite a pain to get it on, but the gear was a snug fit on the shaft afterwards. Still pops down in a crash as well (that's a feature I've tested very thoroughly). Saved me having to throw away an otherwise perfect gear.
krowbar is offline        Reply With Quote Quick reply to this message
Old 12-31-2020, 09:09 PM   #10 (permalink)
The most bullet proof heli out of the box is a good fright stimulator.
NotAProfessional likes this.
Logo 600 (VBar Neo), Gaui X5 FES (BD3SX), Warp 360 (MiniVbar), Trex 450 Pro FBL (Spirit Pro), OXY 3 stretch (Spirit), OMP M2 Explore, two 180CFX (one uSpirit), 130X, XK110, Nano CPX
PassinThru is offline        Reply With Quote Quick reply to this message
Old 12-31-2020, 09:15 PM   #11 (permalink)
Since this is in the "100 Class Electric Helicopters" forum, and since the OP said "bulletproof..."
No contest, XK K110.
torpicaltrail is offline        Reply With Quote Quick reply to this message
Old 01-05-2021, 12:37 AM   #12 (permalink)
#1. M2 is not a 100 class heli (where this post is)
#2. M2 is nowhere near bullet proof. With it's high speed speed and weight, something will break in a crash.
Palm_Pilot is offline        Reply With Quote Quick reply to this message
Old 01-05-2021, 12:39 AM   #13 (permalink)
You would need to add a Spektrum satellite receiver to use a Spektrum Tx.
