06-05-2020, 08:00 AM | #1 (permalink) |
11T Pinion
Can anyone recommend me an 11T motor pinion that is compatible with the standard legacy 700 112t main gear? If you have a part number it'd be hugely appreciated.
My motor is 530kV so the geared head speed is higher than I need/want, especially coming back to the hobby after a long break. I'd rather drop the speed and gain 30s flight time. Thanks!
Harry Thunder Tiger Raptor E720 CGY750 | Mikado Logo 700 CGY760R |SAB Kraken 580 CGY760R| Powered by Futaba 18SZ |
06-05-2020, 11:05 PM | #2 (permalink) |
Nano CPX || 130X || 230S II 450 3D converted to 450X || 360CFX || 480 Fusion II 550X || Oxy 5 MEG || ALeeS Rush 700 Evolution || Goblin 770 Sport 'My flight style, determines my crash style" |
06-22-2020, 08:58 AM | #3 (permalink) |
Pretty sure the CNC Align main gear is a swap out for the Alees so source a Align Pinion.
06-22-2020, 09:17 AM | #4 (permalink) |
Got one one order so hoping it might arrive today, though it's 15:15 here now so not likely.
10-28-2020, 02:08 AM | #5 (permalink) |
I found that the pinion would sit too high and I had to add a countersink to the bottom. Depends on the design of the collar / snap ring on the motor though. The stock Aleese pinion already has this countersink. You don't need a drill press for this a hand power drill a 6mm bore countersink and an old 6mm shaft of some sort will do the job. Just drill a hole in a block of wood and tap the pinion in there to hold it in place. the stick the shaft and countersink in there and carefully bore out a countersunk. Make sure it stops a short of the setscrew hole.
