Go Back   HeliFreak > R/C Electronics Support > Spektrum FBL System > Spektrum FC6250HX
Like Tree2Likes
  • 1 Post By Keyrigger
  • 1 Post By brianbremer
Old 06-18-2020, 11:54 AM   #1 (permalink)
Default 6250 and 4651t into fusion 360
Just got myself a fusion 360 fitted with the new 6250 flybarless unit Also brought the better rx spm4651t fitted it no problem bound it to my ix20 but the 6250 just flashes red and will not talk to the radio any one had any problems with this combination the std rx that came fitted binds and work fine
Barry
1275mini is offline        Reply With Quote Quick reply to this message
Old 06-18-2020, 12:27 PM   #2 (permalink)
HF Scale Support
Hi,
I just replied above but I will post it here. Brian will see this post and correct me if I am wrong. I could give an educated guess that your FC6250HX may need to be updated to the latest firmware in order to communicate with the 4651T. Make sure that you have an SPMA3065 cable on hand to do any updates to your system, if you don't have it already. It will also allow you to program port 6 for use in the future for another servo or a lighting system, as examples. Take care.
Don
Old 06-18-2020, 12:51 PM   #3 (permalink)
Keyrigger is correct, it needs to be updated.
M
Team Horizon
Team Amain
My YouTube Channel
MikelG is offline        Reply With Quote Quick reply to this message
Old 06-18-2020, 01:21 PM   #4 (permalink)
HF Scale Support
If I was to add one more thing, update your 4651T at the same time. When the 360 was released, the 4651T was not on the market and no internal firmware was there to recognize the new telemetry remote. Unless you update the FC6250HX, the firmware will not know how to communicate with the remote. Likewise, there was an update (seems mostly for the EU version but it can't hurt to keep it up to date) for the 4651T that I have updated mine with and get some of the most solid linking to the helicopter I have seen since I started to pay attention to the fades and frame losses. Take care.
Don
MikelG likes this.
Old 06-19-2020, 05:35 PM   #5 (permalink)
BNF/RTF firmware only supports the 4649t and dsmx remotes.
Open stock requires a SRXL2 telemetry remote and also supports non-telemetry dsmx remotes (not the 4649t).
The situation was unavoidable simply because the 4649t cannot be detected over any other dsmx remote so it is impossible to know if one is connected.
If you are happy with the way the model performs there is no benefit to going to the open stock firmware and the 4651t remote, the bnf/rtf firmware and 4649t provides the exact same functionality including smart esc telemetry if you have installed a smart esc.
The 4649t is a great remote, I personally use it on several models and find rf performance is very good, I won't be replacing the ones I am using now.
Thanks and Best Regards,
Brian Bremer
Horizon Hobby, LLC
Nytro97 likes this.
brianbremer is offline        Reply With Quote Quick reply to this message
Old 06-19-2020, 08:02 PM   #6 (permalink)
Already been down this road...bought a 4651T just wanted to the newest receiver. Just kept the 4649T because the BNF software works so well.
Tom
Blade 150s. mCPs, 480 Fusion, MA Whiplash Nitro,
Kraken 580, Concept 30,60, Caliber 30 and iX12
Nytro97 is offline        Reply With Quote Quick reply to this message
Old 06-19-2020, 08:03 PM   #7 (permalink)
HF Scale Support
Barry, like Brian, I have four 4649T telemetry receivers (either a second or third remote) and they will stay where they are as they are all doing the job they were bought for. In future, I will be using the 4651T for telemetry and the carbon remote, 9746 as secondary remotes. Take care.
Don
Old 07-06-2020, 09:16 AM   #8 (permalink)
Here’s a strange think any one help me all bound up as std fusion bnf running a ix20 radio flybar unit flashing green rx bound and solid light soon as I select forward planning flybar unit starts flashing blue and a few of the options are missing from forward planning soon as I come out of forward planning unit turns back to green
Barry
Old 07-06-2020, 10:31 AM   #9 (permalink)
Light blue led flash just means forward programming is active.
What fwdprg options are missing?
Best Regards,
Brian Bremer
Horizon Hobby, LLC
Old 07-06-2020, 11:47 AM   #10 (permalink)
Brian
At work at moment I have the top two
And bottom two very strange
Barry
Barry
Old 07-06-2020, 01:46 PM   #11 (permalink)
When I click on swashplate setting I do not get to be able to change servo rate
Or thottle or any thing else
Barry
Old 07-07-2020, 05:47 AM   #12 (permalink)
Pictures of my display when I go to fwd planning
ID:	867939   Click image for larger version
ID:	867941   Click image for larger version
Barry
Old 07-07-2020, 08:06 AM   #13 (permalink)
Open stock firmware allows adjustment of additional parameters but the bnf/rtf firmware has default settings for the specific helicopter and the specific electronics so those options are not needed in that case.
Open stock firmware covers all helicopters and with that comes the additional work to setup every single parameter, bnf/rtf firmware allows you to reset to defaults, subtrim servos and it is ready to fly.
Best Regards,
Brian Bremer
Horizon Hobby, LLC
Old 07-07-2020, 08:23 AM   #14 (permalink)
I see thanks for the update Brian all clear now thank you very much
Barry
