Go Back   HeliFreak > R/C Helicopter Support > Gas Powered Thoughts
Gas Powered Thoughts Advice for Gas Helicopter Success from Carey Shurley
Like Tree6Likes
  • 3 Post By carey shurley
  • 1 Post By carey shurley
  • 2 Post By carey shurley
Old 06-25-2020, 01:15 PM   #1 (permalink)
Default Build Thread - JCD Protos Gas Conversion
Overview
With the introduction of the Protos Nitro helicopter, JCD can finally produce a gas conversion where there isn’t an issue with the direction of the rotor head rotation. Take a look at what you need and how to do the very straight forward conversion!
NOTE: There are more details found in the conversion guide document, this overview does not include every detail.
Introduction
It all starts with a helicopter, for this one you will need a Protos Nitro helicopter kit
Donor Kit Required
From that kit, you’re going to need to keep these parts and assemblies
Donor Parts Required
On the other hand, these parts will not be used. If you’re converting from a damaged model, no need to replace these parts if they are damaged
Donor Parts Not Needed
Here’s what comes with the conversion kit, as always JCD kits are very complete
Conversion Parts
You will need a Zenoah RC format engine, typically we recommend one that has been balanced and modified or additional power as well as a muffler.
Engine/muffler required
You will need the same electronics as would be used in the donor model although they will be installed slightly differently and the throttle setup will be different.
Electronics required
Conversion Manual
Click on cover to see manual
Next Step
Component Assembly
carey shurley is offline        Reply With Quote Quick reply to this message
Old 06-25-2020, 01:16 PM   #2 (permalink)
Default Build Thread - JCD Protos Gas Conversion - Prepare Components
Component Assembly
As I always do, there are a number of components that can be assembled or converted prior to the main assembly steps. This saves time and simplifies the actual conversion
Starting with the engine mount and bearing blocks
Engine mount/bearing blocks
The engine mount uses an insert that will self align the mount onto the engine crankcase
Engine mount assembled
The drive bearings install into the drive bearing blocks as shown
Drive bearing blocks assembled
These are the parts needed to prepare the engine
Engine preparation parts
The engine mount installs onto the nose of the engine, the insert will align onto the nose of the crankcase
Install engine mount
The engine will likely include a clutch and base, install the base onto the crankshaft as shown
Install clutch base
These are the parts needed to install the clutch, some are from the clutch kit and some are included in the conversion
Clutch parts
Here you can see the clutch installed
Clutch installed
The kit includes a deflector to better direct hot air out of the canopy. It installs as shown
Air deflector
The carburetor throttle arm will need to be oriented as shown, use the control ball from the donor kit
Throttle arm
Here you can see the completed engine ready for installation
Engine completed
These are the parts needed to assemble the main drive
Main drive parts
The clutch bell will insert through the lower bearing block as shown, followed by a spacer and then by the drive gear
Lower clutch stack
The drive gear will be affixed using a set screw which connects with the flat on the clutch bell shaft. The remaining spacer sits on top of the gear
Install gear/spacer
The upper clutch block installs as shown, note the orientation of the bearing. Tighten the M15 nut onto the top of the clutch bell shaft to secure the bearing blocks
Install upper clutch block
The start shaft installs through the clutch bell shaft using the included flange bearings
Install start shaft
Install the start adapter on the top of the start shaft, the set screw will align with a flat on the shaft
Main drive completed
You will reuse the fuel tank from the donor model and make some modifications
Fuel tank parts
You will need to add a fitting for the carburetor overflow line and for a fuel fill location. The exact location isn’t important as long as it is on the right outside of the tank
Overflow/fill location
The kit includes an o-ring to help seal the overflow fitting
Overflow/fill fitting
The overflow fitting will install using the included hardware
Overflow/fill installed
These are the parts used for the fuel feed line
Fuel feed parts
It will require a slightly different process for installation
Installing fuel feed
Once the fuel feed is installed, the tank is ready for installation
Completed tank
As a final component, select the new front frame support and install the front frame support cross member from the donor model. Note the orientation of the parts
Front frame support
Next Step
Chassis Conversion
Old 06-25-2020, 01:17 PM   #3 (permalink)
Default Build Thread - JCD Protos Gas Conversion - Chassis Conversion
Chassis Conversion
This is the main conversion step, it combines most of the original donor parts with the main conversion parts
Because of the size of the engine, a new set of frames are required, these are the additional parts needed for that
Conversion frame parts
The main drive will install in exactly the same way as the original motor drive mount on the front of the frame skeleton
Main drive installed
Assemble all of the frame components onto one of the side frames, the right side is recommended
Frame side – inner view
Here you can see all of the mount bolts for the frame side
Frame side – outer view
Combine the two frames which will capture the main drive
Combine frames
The previously prepared engine will install in this orientation
Engine orientation
Install the engine as shown using the provided M3 x 8mm bolts. See the conversion guide for proper alignment steps
Install engine
Once assembled the frame should look like this from the right side
Frame assembled – right view
And like this from the left side
Frame assembled – Left view
To complete the main chassis, you will need these parts from the conversion
Lower frame plate parts
Install the landing gear mount, the rear mount uses parts from the conversion
Install landing gear mounts
Install the original landing gear as shown
Install the lower engine plate, refer to the conversion guide for details
Engine plate installed
Slide the fuel tank into its original location
Install fuel tank
Using the included fuel vent spool, assemble it over the fuel tank retainer. Refer to the conversion guide for details
Configure fuel vent
When completed, the fuel tank vent/spool will look like this.
Fuel vent assembled
The tank retainer installs in the same as on the donor model. The tank vent spool will be towards the rear of the model
Fuel vent installed
Attach the short end of the fuel tank vent to the vent fitting on the tank
Tank vent attached
Next Step
Install Electronics
Old 06-25-2020, 01:18 PM   #4 (permalink)
Default Build Thread - JCD Protos Gas Conversion - Install Electronics
Install Electronics
For the most part, the electronics will be installed in the same way as originally done with a couple of exceptions. There are many ways to install electronics and route wiring, the following is just an example
Here you can see the electronics from a left side view
Electronics installed – left view
And also from a right side view
Electronics installed – right view
Now you can install the original front battery plate
Install battery plate
Use the provided Velcro to secure the battery
Prepare battery
And install the battery in its original position
Install battery
The T/R servo now installs in the back of the model. These are the parts needed to properly center it. The four spacers fit between the servo and the frame. Use the original plastic servo nuts to secure the servo into place
T/R servo parts
Looking inside the frame you can see the proper orientation for the servo
T/R servo installed – inner view
And from outside the frame you can see a suggested routing for the servo wiring
T/R servo installed – outer view
The conversion includes a switch mount, you can use this if you want. Depending on the size of your switch it can mount in the open throttle or t/r frame opening
Optional switch mount
Next Step
Complete the conversion
Old 06-25-2020, 01:18 PM   #5 (permalink)
Default Build Thread - JCD Protos Gas Conversion - Model Completion
There are a few steps left to complete the conversion which will be covered here
Plumb the fuel tank as shown, refer to the conversion guide for more details
Fuel tank plumbed
Secure the fuel lines so that they are moving around
Secure fuel lines
Install the main gear, autorotation pulley, main shaft and rotor head exactly as done in the original donor model.
Main gear/shaft/head installed
Use the original T/R pushrod to make up a throttle control rod. Also note the position of the ball on the throttle servo arm. Refer to the conversion guide for more details on this
Throttle Rod dimensions
Throttle control rod installed
Throttle rod installed
Make up the T/R pushrod. Its going to need to be shorter than the original due to the new t/r servo position. Refer to the conversion guide for more details
Build t/r pushrod
The kit includes a sleeve to fit over the t/r pushrod.
Included Teflon sleeve
This will install over the pushrod and be shrunk into place with a heat gun. It should fit at the same location as the t/r pushrod support and will dampen the vibration/noise that it produces
Sleeve installed
Finally install the T/R pushrod as shown
T/R pushrod installed
Your engine must have an air filter. If it hasn’t yet been installed, do it now
Install air filter
You will also need a muffler, you can install it now
Install muffler
The conversion includes optional decals that you can install
Optional decals
This is one possible location for the decals
Optional decal installation
This completes the conversion. You can configure your electronics as you normally would. Refer to the conversion guide for a suggested throttle curve
Next Step
Conversion Summary
Old 06-25-2020, 01:20 PM   #6 (permalink)
Default Build Thread - JCD Protos Gas Conversion - Summary
Summary
The model as shown here weighs 11lbs - 14oz
The servos, battery or blades are not optimized for the lightest available, they are the parts I normally use in builds.
Old 06-25-2020, 09:07 PM   #7 (permalink)
Love it! Can’t wait to try one, my Protos nitro is great, this will be a great addition.
Any provisions for a generator mount?
Eury is offline        Reply With Quote Quick reply to this message
Old 06-25-2020, 09:26 PM   #8 (permalink)
not currently, maybe later
Colin Broughton likes this.
Carey Shurley
Proprietor - Gas Powered Helicopters
Old 06-27-2020, 04:44 PM   #9 (permalink)
Hi Carey,
Can the Protos electric be used as a donor?
Thanks.
bbrc77 is offline        Reply With Quote Quick reply to this message
Old 06-27-2020, 05:51 PM   #10 (permalink)
not practical, there are too many differences
Carey Shurley
Old 06-28-2020, 02:05 PM   #11 (permalink)
Thanks for the response Carey.
Old 06-28-2020, 09:45 PM   #12 (permalink)
Looks great. When will the conversions be available?
Align: 550X, 700X
SAB: Nitro 700 sport, Jim Boss 570N, 580E Kraken
Brain2/Ikon2
Futaba 16sz
Stevecg is offline        Reply With Quote Quick reply to this message
Old 06-29-2020, 06:06 AM   #13 (permalink)
will have some during July
Eury and Colin Broughton like this.
Carey Shurley
Old 07-09-2020, 07:31 AM   #14 (permalink)
Default Protos conversion
Mr. Shurley, I will get one when it is available
phat2016 is offline        Reply With Quote Quick reply to this message
Old 07-20-2020, 08:56 PM   #15 (permalink)
I put a few in the store today
Carey Shurley
Old 08-30-2020, 11:18 AM   #16 (permalink)
Carey,
Any problems with the Gorilla Gear spreading out?
Thanks,
John
Team Synergy, Rail Blades, Lynx Heli
Citizen #396
jmiceli11 is offline        Reply With Quote Quick reply to this message
Old 08-30-2020, 12:21 PM   #17 (permalink)
Hey John, there hasn't been that I can see. On the prototype, they haven't really changed and it as a nice ground clearance
Carey Shurley
