Like Tree5Likes
Old 07-03-2020, 01:44 PM   #1 (permalink)
Default Jeti Receivers For FBL
I'm in the middle of converting my fleet to Jeti. So I'm new, not too familiar with Jeti and I have a bunch of receivers to install!
If there is anyone in the future that ends up looking for how the different RXs compare, hopefully this will help. I'm in the US so receivers are limited to what is available... (I wish I had a EX R3 REX and a EX R7 Nano to show)
So on hand I have:
1) R3/RSW
2) EX R5 light (Bundled with my DS-12)
3) EX R4 light (2)
I'm still working on putting things in, so no 'real world' type of review here but I wanted to try to summarize the differences between the receivers. If I get it wrong I'm sure another Freak will set me straight.
Thoughts:
  • They are all about the same size / weight
  • The R4 and R5 lights have shorter antenna
  • The R3/RSW has longer antenna
  • The EX Bus port on the R5 is at the opposite end, next to the antenna
  • R3/RSW has a 'Hardcase', others are shrink wrapped
  • Range should be reasonably similar provided antenna are in the clear (harder with short antenna )
  • All will work with Jeti EX Bus and in my case integrate with an IKON2 FBL
  • The R4 should integrate and provide full IKON2 telemetry even though Jeti states that it has limited telemetry. The telemetry that Jeti is referring to in that statement is the A1 / A2, the individual antenna info from the RX. Q the overall signal strength is still there and IKON telemetry and integration work.
Hope this helps
I'm coming from Spektrum so for comparison, here's a shot with the new SPM4651T and a Lemon Satellite.
ID:	867291   Click image for larger version
Old 07-03-2020, 02:32 PM   #2 (permalink)
..maybe you should not only compare size/weight to i.e. 4651T, but functionality too... ? quality / range? there is much more of a difference between them....
helis: Logo 444SEXX/555SEX/600SX, HeliBaby NT, Diabolo 700, YGE LVT/HVT, Egodrift, Spirit 2/RS, Jeti DS-12/Spirit Ed.
Rabid121 is online now        Reply With Quote Quick reply to this message
Old 07-03-2020, 02:54 PM   #3 (permalink)
This is simply a showcase of the receiver sizes and not a Spektrum comparison
Goblin Kraken / Protos Nitro / Logo 690 / Logo 480 / Logo 480 Nightship / Protos 380 / Oxy 215
Jeti DS-12 Carbon / Brain2 / Hobbywing v4
DIY Night Blade Tutorial
BuildFlyCrashRepeat is online now        Reply With Quote Quick reply to this message
Old 07-03-2020, 03:40 PM   #4 (permalink)
sorry if i've been wrong
Old 07-03-2020, 03:50 PM   #5 (permalink)
Not trying to bash Spektrum... 😉
Stuff like weight is pretty easy to get. It’s not a fair comparison. With Spektrum, the RX might be lighter but you gotta have 2 or more for anything but the smallest helis, mount them and so on... The Jeti might weigh more but you only have one RX usually.
Maybe if I get bored, I’ll strap my old RXs side by side with the Jetis and do a range check or something.
I’m wondering if anyone else has other RXs to add to this thread?
Rabid121 likes this.
Jeti DS12 / Ikon2 / Oxy2/4/5 / SAB Mini Comet / Fireball / G380 / Gaui X5v2
Old 07-03-2020, 04:12 PM   #6 (permalink)
The most popular seem to be:
REX3
REX7
R3
And then the lightweight ones like the R5L and R4L
Old 07-03-2020, 04:41 PM   #7 (permalink)
If you can't bind your R4, be advised that some labels were installed on their opposite sides.
Dan
Synergy 696; Synergy 516; Stretched 516 (to 557/96); Jeti DS-16/12. Planks.
No-Team; Non-Rep, no-skill. Free advice worth every penny.
dogbreath is online now        Reply With Quote Quick reply to this message
Old 07-03-2020, 07:16 PM   #8 (permalink)
REX3
REX7
R3
Is the REX3 available in the USA?
Old 07-03-2020, 09:11 PM   #9 (permalink)
No, but the REX7 is not that much bigger.
Whiplash Turbine - Synergy N7 Gasser - Synergy E5SS - Goblin 500 - T-Rex 450L (x2) - Oxy 2 - Spirit FBL - Jeti DS-16
AccuRC to train my brain
FrankFuss is offline        Reply With Quote Quick reply to this message
Old 07-03-2020, 10:16 PM   #10 (permalink)
Nope.
Have to order from the UK
Old 07-03-2020, 10:57 PM   #11 (permalink)
That’s kinda why I put the pictures of the RXs I had. For visual comparison.
— REX7: 42mm x 28mm x 11mm / 13 gm (12,963 mm^3)
— REX3: 40mm x 22mm x 7mm / 6 gm (6,160 mm^3)
The REX7 is about 2x as big and more than 2x as heavy. I don’t really need a REX so no big deal for now... 🙂
Old 07-04-2020, 07:19 AM   #12 (permalink)
Being outside the USA I only use the RSat2 and REX3 with all of my helis. Well the one exception is the new Spirit RS with its inbuilt Jeti Rx.
//Dennis.
soXos Strike7 : soXos 600 : soXos 550 : soXos F3C 800
Protos 380 : soXos DB7 nightflyer : Jeti DS-16 & DS-12 : Mini Protos FBL Stretch : Logo 600
I am www.soxosaustralia.com.au | VTX blades | 1st-RC Products | EGODRIFT motors
Thunder Fighter is offline        Reply With Quote Quick reply to this message
Old 07-04-2020, 07:47 AM   #13 (permalink)
Aren' there different iterations of the REX3, with 100mm, 200mm, and balun antennas? One has to get the version that works for their applications. Short antennas may be harder to get clear of carbon.
Dan
Old 07-04-2020, 08:22 AM   #14 (permalink)
I think the R3 has a good antenna length. You have to be careful with the REX3 because they have different lengths. 200mm is just way too long.
Old 07-04-2020, 09:34 AM   #15 (permalink)
yes, there are 2 (3) versions... Rex3 and Rex3 A20 (plus Rex3 A40). the 20/40cm comes with the damper pots (dont know if this is the correct techn. term in English). i am using the 20cm antennas i.e. on the HeliBaby NT of my wife... no chance with the short antennas there. or on the Diabolo 700... canopy is long and very slim and half around tail boom all the 'normal' helis are perfect with the std. antennas... and there is no difference in range or other specs.
Ciao
Michael
Old 07-05-2020, 03:26 AM   #16 (permalink)
Hi the versions of the REX3 that I have physically seen are
REX3 - 10cm antennae without balun
REX3 - 20cm antennae without balun
REX3 A20 - 20cm antennae with balun
REX3 A40 - 10cm antennae with balun
I own the first 2 without balun's and ordered them from different vendors as a REX3 as I was not aware what the antennae lengths were. The first one to arrive was the REX3 - 20cm without balun.
The next time I ordered from a different vendor I received the REX3 - 10cm without balun. Their is no difference between the receivers that distinguishes them. The only difference I could find was the white sticker on the front showed JDEX-RR3 and JDEX-RR3-US. The US version was ordered from www.espritmodel.com and the normal one from a local shop in our country. The US version has 20cm antennae.
I would now always contact the seller first and ask them to measure the antennae and buy the one I want for the specific heli and the mounting.
Personally the baluns cause problems for me and using antennae tubes so I always buy the ones without baluns.
Chippie13 is offline        Reply With Quote Quick reply to this message
Old 07-05-2020, 08:08 AM   #17 (permalink)
And Esprit will only sell their REX3's out of the USA due to lack of FCC sticker. Dan
Old 07-05-2020, 08:30 AM   #18 (permalink)
... here in Europe no more 20cm normal (= NO balun/damper pot) antenna on Rex3... not available anymore. i called Jeti support as i really would have needed it for the HeliBaby NT (there's a 2mm hole on the CF backplate where the antenna must go through). the little less range is just not important on the heli, but no chance
Old 07-06-2020, 01:01 AM   #19 (permalink)
Originally Posted by Rabid121 View Post
... here in Europe no more 20cm normal antenna on Rex3... not available anymore. i called Jeti support as i really would have needed it for the HeliBaby NT (there's a 2mm hole on the CF backplate where the antenna must go through). the little less range is just not important on the heli, but no chance
I found they were only carrying the short antenna model out here in Australia, but they told me they could order the A20 version of the REX3. So Jeti in CZ has told you they are no longer making the A20 version? That will be an issue for me as for the majority of my setups I need the 200mm version, the 100mm doesn't really let me get the antenna away from the carbon on my larger models.
//Dennis.
Old 07-06-2020, 01:26 AM   #20 (permalink)
Can someone consolidate an updated list of the antenna variants of the REX3?
