Like Tree13Likes
Old 11-20-2020, 01:12 AM   #21 (permalink)
Originally Posted by foundryratjim View Post
How do you set up the transmitter? Do you set the model up as a plane or as a heli? And what settings do you use? Thanks. I am using a DS 12.
Setup is similar to most FBL helis. The only unusual thing is the channel that's normally used for tail gyro gain is on the M2 used to turn stability on and off.
Gob Kraken |Gob 700 BT 'T' | Gob 770 Comp | SoXos Strike 7 | Henseleit TDR, TDSF & TDR2 | Kasama Dune | OMP M1&M2 | UK stockist for OMPHobby M1/M2 ScotiaRC.co.uk
Old 11-20-2020, 08:19 AM   #22 (permalink)
I should have said that I have not set up a FBL Heli yet, just the spectrum bind and flys, I went through the setup for the heli and got lost when the servo assignments were not as described as is in this thread, Can you possibly steer me to a thread the explains setting up a heli on a jeti radio system? Thanks
foundryratjim is offline        Reply With Quote Quick reply to this message
Old 11-20-2020, 08:34 AM   #23 (permalink)
There’s a couple YTube videos. I’m pretty sure this is the one I started with
Helicopter Programming: Basic Setup (12 min 53 sec)
Smoggie likes this.
Jeti DS12 / Ikon2 / Oxy2/4/5 / SAB Mini Comet / Fireball / G380 / Gaui X5v2 / Kraken 580
Old 11-20-2020, 10:14 AM   #24 (permalink)
Originally Posted by JimJW View Post
Thereís a couple YTube videos. Iím pretty sure this is the one I started with
https://youtu.be/CZnsAubpkVg
I will check this out. Thank you.
Old 11-21-2020, 02:50 AM   #25 (permalink)
I also created a video for the brain flybarless setup which explains the mapping of physical controls to channels which may also help.
Have a look and let me know if it helps
Jeti - Brain - Setup Part 1 (10 min 9 sec)
Chippie13 is offline        Reply With Quote Quick reply to this message
Old 11-21-2020, 07:42 AM   #26 (permalink)
https://youtu.be/uTU0Ia2tiRc
This will help me! I have a Trex 470l kit assembled with a Brain 2 to program. I have got the mapping all set on the M2. I have to get my switches set for stability mode and throttle curves set yet. There is hope for this 63 year old yet! Thanks!
Old 02-08-2021, 11:55 AM   #27 (permalink)
Default OMP - Jeti - reciever
What a great thread... however, could someone clarify for me.
What is the preferred Jeti receiver to use?
Using a single bus wire.
Thanks for your help in advance.
Its all about having fun
ShaneJourdan is offline        Reply With Quote Quick reply to this message
Old 02-08-2021, 12:03 PM   #28 (permalink)
The smallest one you can get...
It needs Sbus output: (in order of size)
EX R7 nano
EX R4/5
REX3
I will have to defer on what it takes to get Sbus out on the EX RXs. I think they have to be loaded with an older firmware for Sbus...
Old 02-08-2021, 12:20 PM   #29 (permalink)
I am running the r7 nano as it is available in our country.
You just download the sbus firmware off the espritmodel website. Then you choose udi as output it works a charm. The firmware notes explains although you choose udi it then actually outputs sbus.
I used the sbus firmware back in the day when i flew the align 3gx as well.
Old 02-08-2021, 12:30 PM   #30 (permalink)
For comparison, here is a photo of a stock R4i, an R4i that has be depined, and an R7 nano. The servo cables are there only for testing. For the M2, you would use an OMP S-Bus cable.
Here is an R7 nano on a OMP M1.
KiwiBlair likes this.
Whiplash Turbine - Synergy N7 Gasser - Synergy E5SS - Goblin 500 - T-Rex 450L (x2) - Oxy 2 - Spirit FBL - Jeti DS-16
AccuRC to train my brain
FrankFuss is online now        Reply With Quote Quick reply to this message
Old 02-08-2021, 04:08 PM   #31 (permalink)
Thanks much, is range a problem with Nano, or because the Heli is so small be difficult to get out of range?
Old 02-08-2021, 04:12 PM   #32 (permalink)
I fly the R7 nano on my Oxy2 with no problems except visual limits...
ShaneJourdan likes this.
Old 02-08-2021, 06:59 PM   #33 (permalink)
Just bought myself a OMP M2.... cant believe I bought a micro heli, hope it works well enough and don't have to fight the tail
Old 02-08-2021, 07:17 PM   #34 (permalink)
Will this one work with the Jeti?
https://www.helidirect.com/products/...=4642211430477
Or do I need this one to connect my R4i?
https://www.helidirect.com/collectio...ceiver-adapter
luv2fly2 is offline        Reply With Quote Quick reply to this message
Old 02-08-2021, 11:31 PM   #35 (permalink)
Originally Posted by luv2fly2 View Post
I think this is a Futaba receiver for a Futaba transmitter.
Yes
Old 02-09-2021, 12:15 AM   #36 (permalink)
https://www.amazon.com/clouddrive/sh...tries*=0&mgh=1
Instructions on how to get it done
Henseleit TDR, TDF, TDSF, Diabolo 700BE, Diabolo 700UL, Goblin Raw, Touch, Neo.
Azimuth114 is online now        Reply With Quote Quick reply to this message
Old 02-09-2021, 02:24 AM   #37 (permalink)
i've been using it in a 1m DLG... the usual 100-150m have not been a real problem. should be enough for the tiny helis too... anyhow be sure to have a good antenna placement => much more shielding materials on a heli
some helis, YGE, Egodrift, Spirit 2/RS/GT/GTR, Jeti DS-12/Spirit Ed.
Rabid121 is offline        Reply With Quote Quick reply to this message
Old 02-09-2021, 05:04 AM   #38 (permalink)
Will a R3 work on the M2 Explore?
bclark is offline        Reply With Quote Quick reply to this message
Old 02-10-2021, 11:22 PM   #39 (permalink)
R4l, will this one also work? The non indoor one.
Simo71 is offline        Reply With Quote Quick reply to this message
Old 02-11-2021, 12:43 AM   #40 (permalink)
Yes, but for the EX series receivers you need the special SBus firmware from Esprit.
The new REX series have SBus support with the latest official firmware.
