Like Tree5Likes
Old 06-30-2020, 12:06 AM   #1 (permalink)
Default R5L receiver with Brain2
I setup my R5L with my uBrain2 on my Oxy2 and the Brain integration did not pop up under Device Explorer.
Does this receiver support it? It is using EXBUS.
Inputs and everything shows up fine on the Brain software.
Any help?
Goblin Kraken / Protos Nitro / Logo 690 / Logo 480 / Logo 480 Nightship / Protos 380 / Oxy 215
Jeti DS-12 Carbon / Brain2 / Hobbywing v4
DIY Night Blade Tutorial
BuildFlyCrashRepeat is online now        Reply With Quote Quick reply to this message
Old 06-30-2020, 12:12 AM   #2 (permalink)
Check in the Jeti threads BFCR, there is a thread about the r4l working with integration.
Oxy 2 215- RIP / Oxy 2 215 sport / Oxy 3 Tareq 2018 / Trioxy 3 (aka Qube) / Oxy 4 / Goblin fireball / G380 / P380 Evo / G570 / G-stay tuned / eXo 500 / Jeti DS-12
blarks is offline        Reply With Quote Quick reply to this message
Old 06-30-2020, 01:05 AM   #3 (permalink)
Ok did some reading and it seems like it should be working.
Dunno what's going on.
Old 06-30-2020, 01:14 AM   #4 (permalink)
Do I need to do a firmware update on the receiver? The transmitter is prompting me.
Old 06-30-2020, 02:16 AM   #5 (permalink)
Possibly, I have never had this message before and have never updated any of my rx's. It may solve your issue as all my rx's are rex 3's and imagine the firmware is newer but cannot confirm that.
Old 06-30-2020, 07:44 AM   #6 (permalink)
It sounds like you do not have the .bin file for your Brain 2 in the Jeti transmitter.
This might be of help also to check your full set up with Jeti
https://www.helifreak.com/attachment...3&d=1473798457
TDSF, TDR-II, Triabolo, 2 X TDR, Logo 700,Protos evoluzione, T-Rex 700Dominator, Drake & Raw, SpiritRS, Jeti DC-24,HW,Kosmik,Jive Pro
Old 06-30-2020, 10:34 AM   #7 (permalink)
I have the integration working fine with my R3 receivers
Old 06-30-2020, 10:56 AM   #8 (permalink)
I did have a similar (sounds identical) issue with older firmware not working. If the TX is prompting you, go ahead and update it. What firmware do you have loaded?
Old 06-30-2020, 11:27 AM   #9 (permalink)
The Jeti already came with the integration file installed. I had already updated it to the latest one though
Old 06-30-2020, 11:28 AM   #10 (permalink)
It just says v3.20 recommended for the receiver
I’ll order the usb dongle
Old 06-30-2020, 04:31 PM   #11 (permalink)
That sounds exactly like my original issue
I’m working through setting up an Ikon2 with a DS-12. I’m trying to figure out how to get the RX to output EX bus.
From the Transmitter model menu:
Model > Device Explorer > R7 EX
I get a warning that minimum firmware 3.20 is recommended...
Under ‘Serial Link’ I set it to ‘EX Bus’
I’ve tried plugging the Ikon2 into all the different RX ports, including the EXT port but I can’t see any signal at the Ikon2. I’m plugged into CH-3 of the Ikon2
Is there another setting I need to apply? Or is the old firmware the problem?
Old 06-30-2020, 09:02 PM   #12 (permalink)
Any help?
Out of the box the receiver doesn’t output EXBus. Go into the receiver in Device Explorer and the very first option will say “Servo/Jetibox” or something similar. Click on it and change it to EXBus.
Voilà. Everything will be working properly.
Old 06-30-2020, 09:04 PM   #13 (permalink)
I did that
Old 07-01-2020, 07:22 AM   #14 (permalink)
My unsubstantiated theory is that the receivers have been in stock a loooong time. How to move them? Bundle them! But of course firmware is dated. I updated mine but I won't use it until I build this winter.
Dan
Synergy 696; Synergy 516; Synergy 516 stretched to 557/96; Jeti DS-16v1 / DS-12. Planks.
Old 07-01-2020, 10:55 AM   #15 (permalink)
I did that
After the firmware was updated, it just worked. For whatever reason, the old firmware doesn’t work....
Old 07-02-2020, 01:41 PM   #16 (permalink)
Just ran into the same issue - R5L would not work until I upgraded the firmware...
Goblin 500 Sport x2, Jeti DS-12, Spirit (RS, Pro, 2)
Spirit Videos: https://www.youtube.com/playlist?lis...Oewh6h2VNbHPOz
yufasa is online now        Reply With Quote Quick reply to this message
Old 07-02-2020, 01:52 PM   #17 (permalink)
Thank you for the feedback
Old 07-02-2020, 06:02 PM   #18 (permalink)
Don't forget to update the devices *.bin or you may not see the choice.
Dan
Old 07-02-2020, 10:40 PM   #19 (permalink)
Dan
This would explain it as well as why I am not getting an update message on my rex 3's
Old 07-03-2020, 11:02 AM   #20 (permalink)
Jeti Studio is kind of dumb, in that it will only update what's plugged into it, doesn't care if you don't update, and doesn't know what's been plugged in before.
I asked Jeti (and they said it was a good idea) that Studio have a database of a person's items, with the ability to annotate what plane/heli they're located in. Studio can update/check the database when anything is plugged in, and remember what firmware it's running. When new firm/software becomes available it could notify the user through the database --show red or something similar.
Right now you have to hear that there's new firmware through whatever source to know to update. I don't have a big fleet, but I have over a dozen Jeti doo-dads that can possibly be updated. The people with dozens of complicated aircraft and helis need help in this regard. I can't remember my own stuff so I built a spreadsheet of what's in each heli/plank and what firmware it's running.
Dan
