Like Tree16Likes
Old 10-01-2020, 10:08 PM   #61 (permalink)
At 25% throttle, the motor should stop completely, but remain in range for about 30 seconds for quick bailout. In other words, be careful if you land with mid switch (25% throttle); make sure you turn the switch to complete motor off, as turning the switch to motor on within the 30 second period before flipping the switch to motor off will start the blades violently and lead to “chicken dance”.
14S Tron 7/Protos 700X Evo/Kraken; 7S Kraken 580/Logo 550SX V2; 6S Buddy 380 KSE
VBC Touch & Neo Vlinks, YGE "T" ESCs; AGM Deep Cycle Batteries
Sims on Mac: Heli-X, neXt, AccuRC, RF9, Phoenix, AeroFly RC7 Ultimate
Amain Field Representative
jhamel is offline        Reply With Quote Quick reply to this message
Old 10-01-2020, 10:20 PM   #62 (permalink)
good to hear its working for you.
gov store mode will set the same rpms each battery pack, regular gov mode will go off a % of the pack voltage. Also if you are doing gov store you want your packs to be 4v oer cell on the first flight to set the 'store'.
Rpm reading for Futaba is set with poles and gear ratios in the program. read the Vbar info to see if its 1-1 and ratios/poles are set in the radio. it could be either way.
I look at the telemetry of BEC temps and current used to verify things are healthy as in say I typically 6 amps and all of a sudden it went to 10 I would investigate.
Throttle percentage is shown and also PWM. if this reaches 98/100% you don't have enough 'headroom' I see low 90's so I think I'm good. If the Vbar used % throttle 80% is max to allow for HR.
Steve
Team MasterCard. Team Kontronik.
smittylube is offline        Reply With Quote Quick reply to this message
Old 10-02-2020, 10:25 AM   #63 (permalink)
Why?
Sent from my CLT-L09 using Tapatalk
AndyO is offline        Reply With Quote Quick reply to this message
Old 10-02-2020, 07:55 PM   #64 (permalink)
Originally Posted by Vinger View Post
IDLE value is set in the RPM Expert page for VBC, PRO firmware required. https://www.vstabi.info/en/node/1679
For VBCt it is under governor page.
The IDLE value must be set to 25% throttle value and it will be engaged by default if you have programmed mode 4.
https://www.kontronik.com/fileadmin/..._LV-I_HV-I.pdf
I have Pro/Rescue on the NEO, and it looks to me like my settings are correct.
I've attached 2 screenshots.
Name:	Diabolo Kolibri V-Control Screenshot 1.jpg
ID:	883541   Click image for larger version
Name:	Diabolo Kolibri V-Control Screenshot 2.jpg
Old 10-02-2020, 08:05 PM   #65 (permalink)
This is exactly the way it's operating.
If this is normal, that's totally fine.
I'm just used to the Mikado NEO's autorotation bailout. I would set it anywhere between 20-30%, and when I hit the switch, it would slow to about that amount (motor/blades would continue to rotate at a much reduced rate).
Spool up from that A/R bailout was about 3-4 seconds.
Testing the A/R bailout spool-up on the bench with the Kolibri (although the pinion is not engaged with the main gear), the motor seems to spool up in less than 1 second. I'm not sure if it will be a little more gradual when it's engaged, (with blades on).
If it's still that fast, I worry about stripping a gear and/or the blades folding in flight (although I keep them fairly tight).
Old 10-02-2020, 09:49 PM   #66 (permalink)
On the bench there will be no load on the motor. The bailout spool up time is normally a 1/4 of your normal spool up time. So depending on your set slow start time it can be between 2-6 seconds.
From the manual
4.10 Autorotation (Bail out)
Due to the autorotation quick-start function, motor
RPM returns to normal much faster. This provides
the opportunity to bail out of an unsuccessful or
interrupted Autorotation. In order to have the
quickest available spool up time without
mechanical overloading, the spool up time after bail
out is calculated on the programmed spool up time
and differs between 2 - 6 s.
In order to enable Autorotation Mode (Bail out), you
must set the throttle-hold value to 25% in your
transmitter (see 7.4). Switching to the AR (throttle
hold) position during an active flight, the motor is
switched off at once and the AR function (bail out)
is activated
VControl
Old hand at Planks
Peter
Old 10-03-2020, 02:13 PM   #67 (permalink)
Yes, I've read over that several times. I set mode 4 via the stick/beep programming method.
I'm assuming that no load on the motor is changing how fast it spools then.
My spool up time is set to 12 seconds, so that would/should make my bailout spool-up time about 3 seconds.
It's definitely much quicker than 3 seconds. It seems almost instant.
I posted my K-Konfig screen. To bad it doesn't verify that you have mode 4 set.
Name:	Kontronik K-Konfig Screenshot Kolibri 140 HV-I Settings.jpg
Old 10-04-2020, 09:11 PM   #68 (permalink)
Default 1st Bench Test Not Good
Ok, so first spool ups of the Diabolo on the bench showed a few issues.
Problem #1, The telemetry is not completely working. In the vibration measurement fields, I get "current" about 60-85 and "maximal" about 95 with no blades, but the 0Hz - 50 - 500 live bar graph on the right that normally shows some kind of measurements (or a few low level spikes) is not showing any reading.
I tried both Tele 2 (since that's supposed to be the one to use for the Kolibri) and Tele 1, but neither makes a difference.
After unplugging the flight pack, the V-Control "Flight Report" is not showing any of the parameters ie: "Max Current", Min Voltage, Used Capa" etc. Mine are all at 0 as if the telemetry is not working.
Problem #2, the motor (new Egodrift 4035HS/560kv 10P) is getting VERY hot (140F/60C) for just running on the bench for 20-30 seconds.
My previous motor (Xera 4035/2Y-600 8P) motor barely got warm in the same exact bench testing.
Can anyone tell me what's going on?
Old 10-04-2020, 11:39 PM   #69 (permalink)
Do not overthink this. Do a MODE 1 stick program, this will reset the ESC and teach endpoints. Now do a MODE 4 for governor programming. Done, DO NOT CHANGE anything with K-Config yet, run it without blades on the bench and it should perform perfectly.
Now make changes to ONLY BEC voltage and telemetry protocol with K-Config. All done.
Set percentages for throttle in your VBCt for the targeted rpm and go fly.
VControl
Old hand at Planks
Peter
Old 10-05-2020, 12:04 AM   #70 (permalink)
Well, I realized that I had to download the Kontronik app to my V-Control.
Now that I did that (and enabled it), I’m getting telemetry for RPM, and my battery voltage and current use.
I’m still not getting the waterfall graph showing where vibes are (in Hz) though.
The motor is still getting a bit hot too.
My V-Control is also now flashing me a message the the NEO needs to be updated for features that are not enabled
That said, I’m going to do as you suggest and just start over tomorrow. First redo the Kolibri, then update the NEO.
Thanks Peter.
Old 10-05-2020, 12:23 AM   #71 (permalink)
Vibration analyzer in graph view only available with pro firmware and you need to load the app in the VBCt.
VControl
Old hand at Planks
Peter
Old 10-05-2020, 09:13 AM   #72 (permalink)
I have had pro w/rescue firmware on this NEO since I bought it 2 years ago.
Also, just to be clear, I have the original VBC classic, not the VBCTouch.
The live vibe analyzer waterfall graph on the VBC was always active before switching ESC’s and motors..
Everything worked fine with the Scorpion Tribunus 130 ESC I had on the Diabolo before I switched to the Kolibri.
Old 10-05-2020, 12:48 PM   #73 (permalink)
Try switching to fixed timing @ 8degrees via Kprog and see if that helps your temps (are you measuring this with an IR temp gun?
Old 10-05-2020, 03:24 PM   #74 (permalink)
Thanks Andy. I will look at that once I get this basic programming working.
@Peter, I did the mode 1 reset then...
cycled the power, and then waited for 4 beeps (mode 4) and give full stick. I heard the confirmation beeps and brought the stick back down.
I'm not sure about the programming setting for how many cells you're using so I ignored it (or thought I did).
I have not connected the Kolibri to K-Konfig yet but wanted to test throttle output.
I now get a low RPM "autorotation bailout" like I have before, so that seems good.
Oddly now however, when I change my bank switch from 1 to 2 to 3, both 2 and 3 motor speeds sound identical (as if they don't change).
Bank 1 is set for 40%
Bank 2 is set for 50%
Bank 3 is set for 70%
What would be the cause of that?
Also, when I plug in the flight pack now, I get the 3 ascending tones, then 2 long tones and 3 short tones. Is this normal every time I plug a battery in?
If it's recognizing the battery cell count (I have a 12s pack), I wonder why it's not 2 long tones (for 10 cells) and 2 short (for 2 additional cells).
Old 10-05-2020, 03:57 PM   #75 (permalink)
Long is 4 cells, short is 1 cell. Are you plugging a full pack in?
Old 10-05-2020, 04:49 PM   #76 (permalink)
No, 6s pack #1 is 23.82 and #2 is 23.83 so 47.65v for the 12s flight pack configuration.
For this, I would think it would give me:
long tone (#1) = 5 cells
long tone (#2) = 5 cells
short tone (#1) = 1 cell
short tone (#2) = 1 cell
But it gave me 2 long and 3 short tones (which doesn't really make sense as it's less voltage than a fully charged 12s pack, not more.
Also, is it supposed to report the cell count with beeps every time you power up?
Old 10-05-2020, 06:25 PM   #77 (permalink)
Default Update - Almost there
So I think I've finally figured it all out.
I had to do a mode 1 reset and mode 4 a second time. Not that it mattered, but I also lowered bank 3 back to the Kontronik default of 60%.
Now I get my 3 banks of different headspeeds fine.
I DO NOT get a low HS autorotation bail out again (as I did earlier today), but I've accepted that as normal. It spools up (without blades) in less than 1 second.
I followed your advice to a T Peter... BUT, what about this info. in the pic?
Since you said "Now make changes to ONLY BEC voltage and telemetry protocol with K-Config. All done.", I did not change "Pole count" or enter my "Gear ratio". I also did not "Reverse rotation" as I didn't want to make any changes in that box. I'm assuming that info. is not sent to the Kolibri if I didn't make any changes?
If I just click the "Reverse rotation" box (and change nothing else), will that have any effect on ANY other settings?
Name:	Kolibri 140 HV-I Konfig screenshot 20201005.jpg
Old 10-05-2020, 06:29 PM   #78 (permalink)
I think you're getting an 11 cell count because you're packs aren't fully charged.....
Old 10-05-2020, 06:35 PM   #79 (permalink)
Thanks Andy. I charged my pack back to full before I re-did the programming. Now I'm not getting any battery voltage tones when I plug it in.
I'm assuming this is how it's supposed to be.
Old 10-05-2020, 09:59 PM   #80 (permalink)
Is the motor connected, stickway programmed, and throttle at zero? No tones when connecting the flight pack indicate something is amiss.
