Go Back   HeliFreak > R/C Electronics Support > Spektrum FBL System
Like Tree1Likes
  • 1 Post By Keyrigger
Old 08-28-2020, 08:35 AM   #1 (permalink)
Default Ar7210bx blade pitch
I’ve recently got back and these fbl units are new to me. I got a goblin mini comet (and tomorrow a fireball competition)Both with ar7210bx. Bk’s on mini and Torq for the fireball.
Here’s my plan to build
1- bind rx/tx
2-setup the fbl as per the manual
3-setup hobbywing esc
Here’s where I’m not 100% sure
4-Setup the blade pitch (on tx) for normal so midstick is 4 degrees and keep modes 1&2 with -12 to+12
5- rebind tx/rx and double check everything
6- say a prayer
7- go for first test flight
I heard you don’t change the pitch curves in normal mode with fbl.
Is this correct?
I’m coming from flybar and normal was usually about 4 degrees at mid stick
Blion is offline        Reply With Quote Quick reply to this message
Old 08-28-2020, 02:21 PM   #2 (permalink)
HF Scale Support
Not having a ton of time right now, if you set your hover so that at mid stick it holds height, if you don't have your Idle 1 and 2 set the same, you will drop like a rock as you switch modes from Normal to 1 or Normal to 2. Conversely, if you change from Idle 1 or 2 to Normal, you will pop like a cork. Either set them all the same, in your transmitter, so that they all hover at 4 degrees or set them so that they are all zero pitch at mid stick. Hope this is a start.
Don
howars01 likes this.
Old 09-15-2020, 12:00 PM   #3 (permalink)
Setup must be done with 0 degrees pitch at center stick and symmetrical +/- 12'ish values on the ends. After that you can adjust the pitch curve in the transmitter as you like.
Its been a few years but I learned as a +5 center stick but have to admit the transition to 0 at center was easy and made finding 0 on vertical lines much easier. I would recommend just making the transition now and you can decrease the normal negative pitch for hovering type stuff.
Regards,
Horizon Hobby, LLC
My Projects: 150 S, 200 SRX, 200 S, 230 S v1/v2, 270 CFX, Fu270, Fu480: AR636/AR6335 Heli, FC6250HX, AR6250MHX
brianbremer is offline        Reply With Quote Quick reply to this message
Old 09-15-2020, 01:08 PM   #4 (permalink)
Fully agree. I have AR7210BX in all my scale birds, 360 to 600 size. Zero degrees pitch at center stick and +12/-12 degrees end to end in setup and in flight, no need to change this.
Since i fly only scale style, pitchcurves are 30,40,50,75,100. All modells perform very calm and reliable, i love this unit.
The_Fox is offline        Reply With Quote Quick reply to this message
Old 09-16-2020, 07:33 AM   #5 (permalink)
Ok great thank you very much for all your advice. I got so busy with life and work that I wasn’t able to do anything until now.
I’m planning on trying this weekend. Yes 0 at midstick is right. I found some of my old 450 setup sheets also.
Not sure why I thought 4 would b good and yes that jump from switching would’ve been a cheek clenching moment lol
This is my setup
Normal -2.5(low) 0 (mid) 12 (high)
Throttle linear 0 / 50(mid) /100
Idle up1 and idle up 2......-12 / 0 / 12
Throttle (1)100/75/100 and 100/85/100 (2)
My pitch across the board is actually a touch higher about .125 it’s as close as I could get, but travel is up/down is accurate, equal and straight/level.
I got 2 packs ready to go. And I’m gonna start off with the align blades for setup and a few flights.
Thank you once again 👍
Old 09-16-2020, 10:52 AM   #6 (permalink)
No Governor for throttle? If Your ESC is not equipped with governor mode, You could use the governor in AR7210BX aswell.
Old 09-16-2020, 12:13 PM   #7 (permalink)
Governor... No my esc doesn’t have one that I know of I’m flying a trex 500 pro w dfc head. Rce-bl70g esc, ds 510m’s & 520m servos, and rcm-bl500mx. I probably won’t be doing anything that requires a governor right now as I just need to get all my orientations familiar again.
Old 09-16-2020, 12:15 PM   #8 (permalink)
Whoops 😬 wrong heli
My bad. Pls disregard Above
These 3am morning starts are getting to me
Old 09-16-2020, 12:25 PM   #9 (permalink)
I’m using the gov store mode on the hobbywing that comes with the mini comet. Sab esc60A And Switch blades, not align.... that’s for my trex500pro
Not sure if I can disable the Sab governor and use the AR7210’s.
I think it would b better to disable the Sab gov and use the ar gov.
Not sure.
Old 09-16-2020, 12:39 PM   #10 (permalink)
No, if the ESC offers governor mode, i would recommend to use it. If there is no governor mode in ESC options i would suggest to use the governor in FBL.
I use YGE ESC for all my modells with AR7210BX, and ESC governor is enabled. FBL governor is disabled.
Old 09-16-2020, 03:32 PM   #11 (permalink)
So the throttle curves I had for idle up 1/2 are ok? Or should I change them?
Old 09-20-2020, 08:02 AM   #12 (permalink)
I ended up using those pitch curves ( not throttle) for both the trex and the mini comet. I got the trex all finished up and have flown it a couple times now. The blades seem to be slightly out of track.
I plan on finishing up the mini comet today and trying it out tomorrow after work
Thanks for the help everyone
Old 09-20-2020, 08:05 AM   #13 (permalink)
Here’s a pic of my trex 500 pro that U guys helped out with.... next will b the mini comet. 👍👍
