Go Back   HeliFreak > R/C Electronics Support > Spirit FBL system
Spirit FBL system Spirit FBL System Discussion
Old 09-26-2020, 07:41 AM   #1 (permalink)
Default heli does not stay level during piro maneuvers when using stabilization
When i am flying with no stabilization, piros are all smooth in any direction or heading, however when I engage stabilization and give rudder commands, the heli begins to pitch up at a particular heading (regardless of the position of the heli).
The swash is perfectly level, and the Spirit is level with the heli, and mounted to provide good vibration isolation. The heli is also balanced out, with CoG right in the center at the main shaft. im not sure what would be causing this issue, but it makes stabilization unusable.
Any suggestions would be greatly appreciated.
SAB / Jeti / Spirit / Xnova / YGE / Pulse LiPo
wkderf is offline        Reply With Quote Quick reply to this message
Old 09-27-2020, 05:33 AM   #2 (permalink)
OK, I know this is a simple question but when you initialize the heli (power on) you have it on a level surface and donít touch it until the blades twitches the double sequence to let you know it is done, right?
You already mentioned that the swash is level (mechanically set I hope) and that the blade pitch is zero for both blade as measure over the boom after swash leveling?
Other than that you should be good to go.
If this is a new unit maybe something is defective and you should talk to Thomas.
I have done all kinds of testing on rescue and stabilization and have not seen this problem ....actually can you check at tell me what mode you are using?
Stabilization or Rescue
Normal or Acro
Goblin 500 Sport x2, Jeti DS-12, Spirit (RS, Pro, 2)
Spirit Videos: https://www.youtube.com/playlist?lis...Oewh6h2VNbHPOz
yufasa is offline        Reply With Quote Quick reply to this message
Old 09-27-2020, 10:51 AM   #3 (permalink)
I absolutely make sure the heli is level and untouched until startup is complete.
The swash has been perfectly zeroíd out using the specific swash leveling tool for my particular heli, and blades are both zeroíd out in tandem with the level swash.
The issue only occurs when stabilization is active, and I have tried this on Coaxial, normal, and scale stabilization.
The heli has flown fine with the previous non-spirit FBL I was using, so Iím doubtful the issue is mechanical.
The issue only arises when stabilization is activated. During traditional non-stabilized flight, the heli flies fine. Whatís most odd is that the direction of the pitch-up sticks to a particular heading. So if I start nose out and activate stabilization, the heli pitches nose up, but if I were then to yaw 180 degrees, the heli would pitch tail up. If the pitch up were in a fixed position on the heli (always pitches to the right regardless of heading), i would be more inclined to think its a setup or mechanical issue with a non-level swash, but the fact that the pitch follows a heading and not an orientation tells me its happening inside the FBL.
Iím picking up a Spirit RS in the hopes that the issue is isolated to the one Spirit 2 I was using.
Old 09-27-2020, 03:07 PM   #4 (permalink)
just curious: what's the results on vibration (spektrum) analyse on different axes? did you try calibration?
some helis, YGE, Egodrift, Spirit 2/RS/GT/GTR, Jeti DS-12/Spirit Ed.
Rabid121 is offline        Reply With Quote Quick reply to this message
Old 09-28-2020, 06:04 AM   #5 (permalink)
Imprecise Rescue - Spirit System Manual
Spirit System - www.spirit-system.com
ZeXx86 is offline        Reply With Quote Quick reply to this message
