Like Tree1Likes
  • 1 Post By rcjames
Old 10-04-2020, 11:21 PM   #1 (permalink)
Default Have two muffler help me help me which one is better
Hello. Just got a flybar Raptor 50. I went over and lock tight what is needed and check engine and so forth. Now I'm stuck. I have a gigantic muffler that i have for 5 years or so came with a Chaos 600 nitro. The smaller one is what came with the raptor. I am using a OS 50 helicopter engine not the OS 50 Hyper. So Which one will be easier to tune? My bigger one is huge i would think better to use a os 55 hz or bigger engine. It is how ever for a 50 size engine. Please let me choose and tell me why. Ty
GREYEAGLE likes this.
Hi my name is Jim and I am a Heliholic. Darn Heli-Crack Addiction!! lol
The heli virus has infected me and i hope that there is NO CURE!
rcjames is offline        Reply With Quote Quick reply to this message
Old 10-05-2020, 03:47 PM   #2 (permalink)
Either one is going to be easy to tune - so that shouldn't be a factor.
The OS engines are easy to tune no matter what muffler is on there
The bigger one might be a tuned muffler while the smaller may simply be a muffler.
Have you checked to see if the bigger one fits the OS 50?
If they both fit, then fly each and see if you notice a difference.
"Those who can make you believe absurdities can make you commit atrocities." (Voltaire)
Watch out: There are a lot of absurdities being thrown around lately.
+ > RIP: John Lewis
Old 10-05-2020, 04:17 PM   #3 (permalink)
Default If the bolt center's match - Hands down the larger one
It has a longer manifold or stick out from the canopy, if you want to keep the back pressure off the motor and run cooler - Volume is every thing. The smaller one looks to be a stock OEM .
I tried em, but the motor I run, became exceptionally peeky and awful to find any kind of sweet spot. It also ran pretty darn hot { very } but it does like it at that temp.
One of the solutions was to locate a used, & install a original MP-5 which is one of the sweetest mufflers / pipe ever designed with lots of volume. I also run a large rubber ventury over that carb but its not a O.S. 50H.
The difference in volume helped alot ! You will like the lower noise.
It's not so peeky any more and I run low Nitro Econ fuel. The O.S. 50 are just the sweetest motor so cherish it. I have one on a part's bird I've never run - Their sweet hearts on low Nitro
Couple of tip's :
You may wish to make a couple of solid copper header gaskets in advance while its off so you don't struggle later. Their easy to make.
You also may wish to install a secondary fuel pressure tap all the way to the back nearest
the exit - then plug it with a short piece of tubing and a screw I use a FOX motor 440 pressure tap - their pretty tiny. The plug is only used for a oil drain when they sit. Something to think about.
GREYEAGLE is offline        Reply With Quote Quick reply to this message
Old 10-06-2020, 07:35 AM   #4 (permalink)
Yea it fit the larger one. I think the larger one is Century Tri-Flow Silent Power Tuned Muffler
ID:	884147   Click image for larger version
ID:	884149   Click image for larger version
Old 10-06-2020, 07:40 AM   #5 (permalink)
Couple of tip's :
What do u mean extra tap? And it does have extra hole on the bottom
Old 10-06-2020, 11:36 AM   #6 (permalink)
I think he is suggesting that it could be used as a drain-plug.
If you drill a hole near that back of the pipe's can, you can add a nipple and then plug it with a short piece of fuel tube and a screw. Then you could unplug it and drain the collected oil out of the pipe.
But, that would partially depend on the pipe's internal baffling and where the oil might collect.
The main concern might be if some excess amount of oil was collecting in the can, some might flow back into the engine during storage. In that case, you might get hydro-lock the next time you tried to start it.
Personally, I've never really had that problem unless the engine is running super rich, the pipe is too big or the engine not reaching full speed.
In my cases, I hang the heli tail-down on the wall and any of the residual oil drains out the pipe.
+ > RIP: John Lewis
