#1 (permalink) |
![]() Can the safe mode be put on a separate switch instead of the FM switch?
#2 (permalink) |
![]() It can be assigned to any switch you want.
Roban 800 size Super Scale AIRWOLF Align Trex 550X, BLADE 360 CFX 3S, BLADE mCP X BL2, BLADE NANO S2, SPEKTRUM iX20, SPEKTRUM iX12 |
#4 (permalink) |
![]() Technically this could be done but not recommended because many non safe settings are are also tied to the same FMode channel.
Currently I run no Stability modes enabled and when I do want Stability mode I just press and hold the panic button. You can assign the panic mix to whatever switch you like, panic and stability are very similar. I am adding Panic->Envelope and Panic->Yaw Rate settings in the next release so panic can be adjusted to suit your preferences. Regards,
Horizon Hobby, LLC My Projects: 150 S, 200 SRX, 200 S, 230 S v1/v2, 270 CFX, Fu270, Fu480: AR636/AR6335 Heli, FC6250HX, AR6250MHX |
