Go Back   HeliFreak > R/C Electronics Support > FrSky
FrSky FrSky product discussion.
Old 10-13-2020, 04:24 PM   #1 (permalink)
Default Companion won't recognize my Horus
I've got the latest OTX firmware version 2.3.10 and sdcard contents in my X12S without using OpenTX Companion. I cannot get Companion to read and write files from and to my Horus. This is not catastrophic, but it would be convenient if I could use Companion. The messages I get are:
"Your radio does not seem connected to USB or the driver is not initialized!!!'
and
on the "Write Firmware to Radio" window it says:
"Could not check firmware from radio"
"No DFU capable USB device found"
See attached photo.
Logo 600 (VBar Neo), Gaui X5 FES (BD3SX), Warp 360 (MiniVbar), Trex 450 Pro FBL (Spirit Pro), OXY 3 stretch (Spirit), OMP M2 Explore, two 180CFX (one uSpirit), 130X, XK110, Nano CPX
PassinThru is offline        Reply With Quote Quick reply to this message
Old 10-13-2020, 08:37 PM   #2 (permalink)
You haybe to hold the rudder and aileron trim tabs both toward center and power up. This gives the option to connect as a usb drive. Select that, then it will work.
Ivan is offline        Reply With Quote Quick reply to this message
Old 10-13-2020, 09:18 PM   #3 (permalink)
I understand that you describe putting the Horus into bootloader mode and that is when the scenario I describe above occurs.
Old 10-13-2020, 10:07 PM   #4 (permalink)
To flash firmware with companion, the radio should be off. That's how I've always done it, and it's never failed.
Keith - XLPower | KST | Egodrift | KC3D
Protos 800X Evoluzione | Protos Nitro | Specter V2 | Protos 380 Evoluzione V2
Number is offline        Reply With Quote Quick reply to this message
Old 10-16-2020, 05:26 PM   #5 (permalink)
Interesting, because that doesn't work for me. It doesn't seem to matter whether I try to flash firmware to the Horus or the Radiomaster TX16S, on or off. I get the same result.
Old 10-16-2020, 06:50 PM   #6 (permalink)
Probably missing a driver then.
Unless you've used it before, you probably don't have the driver for DFU mode installed. And if you do, the one that Windows sometimes automatically installs will likely not work. You will need to install the correct one manually. Make sure your radio is off, then plug it in.
I've used ImpulseRC driver fixer, but others report zadig also works. ImpulseRC is what I used the first time I had to install the driver, and it's what I've been using since.
Old 11-12-2020, 04:41 PM   #7 (permalink)
When I connect the USB data cable into the back of the (turned off) Horus, my PC (which is a powerful gaming computer that normally does everything well) does not "bing" and show another device connected to it.
Old 11-13-2020, 02:51 AM   #8 (permalink)
Location: Perth, Western Australia (the most isolated (AND COVID FREE!) capital city on earth!)
For my TARANIS, I have the radio switched on via the two front trim to put it into bootloader mode. USB then works fine. I'm not home to confirm if it will work with the TARANIS switched off.
YMMVWFM,
Paolo
XLPower 700, ALIGN 550L (beater), Prôtos MAX V2 Leggero 700 & Evoluzione 800 (RCHN #803 - joined just before they shut up shop!)
PaoloFCantoni is offline        Reply With Quote Quick reply to this message
Old 11-16-2020, 08:47 PM   #9 (permalink)
My USB connection doesn't work with the Horus in bootloader mode. I've tried to use ImpulseRC Driver Fixer as Keith has, but it cannot find my device either. Maybe I'll try Zadig.
Old 11-18-2020, 12:46 PM   #10 (permalink)
Zadig doesn't do it either. I think I probably did what Zadig's creator warned against doing.
