Old 10-24-2020, 12:50 AM   #1 (permalink)
Default Weird power on and charging behavior
Had my DS-16 for years and it's been trouble-free. Was purchased back in 2013.
Today it got a little sprinkled on. It was outside when it started raining. I caught it within a half hour or so. I opened it up, blew it out with a compressor, and ran my home's ventilation along with a blower fan at it.
Came back the next day and the following happened:
- "Switches changed" message
- Unit would not come on under battery power
- Under battery power, screen gave some horizontal lines
- Battery voltage fluctuating about 8% or so
Now that I have unplugged the battery and blew it out more, I charged it to full charge. My red charging LED is really dim.
I'm concerned I killed my radio.
Help? Reassure me or give me some tests to ensure this is OK.
Gaui X7 Tribunus 200A, Xnova XTS 4525-530, Xpert R2/T, iKon2 BT
Gaui X5 HW 100A V3,Gaui 4020-910,KST, iKon[/FONT]
lucidchaos is offline        Reply With Quote Quick reply to this message
Old 10-24-2020, 02:26 PM   #2 (permalink)
30 mins in the rain? I'm not sure what effect that would have but with the symptoms you are describing I'd be seeing if it can be sent in for checking/repair. Certainly wouldn't fly with it.
Oxy 2 215- RIP / Oxy 2 215 sport / Oxy 3 Tareq 2018 / Trioxy 3 (aka Qube) / Oxy 4 / Goblin fireball / G380 / P380 Evo / G570 / G-stay tuned / eXo 500 / Jeti DS-12
blarks is online now        Reply With Quote Quick reply to this message
Old 10-24-2020, 05:32 PM   #3 (permalink)
For sure, send it in for repair.
On the other hand, you have had it for 7 years, so maybe it is a good time for a new DS-16 G2.
Whiplash Turbine - Synergy N7 Gasser - Synergy E5SS - Goblin 500 - T-Rex 450L (x2) - Oxy 2 - Spirit FBL - Jeti DS-16
AccuRC to train my brain
FrankFuss is offline        Reply With Quote Quick reply to this message
Old 10-24-2020, 08:18 PM   #4 (permalink)
That's a phone call to Jeti support, doesn't sound good.
Sent from my SM-G970F using Tapatalk
myxiplx is online now        Reply With Quote Quick reply to this message
Old 10-29-2020, 07:50 PM   #5 (permalink)
I'm starting to think it's the battery itself causing the issues. Wiggling the cable yields weird results.
I'll reach out to Jeti and see what they say, but nearly certainly will replace the pack. Everything else is working fine now, but if I fly with it, I will get it tested.
Old 10-30-2020, 12:25 AM   #6 (permalink)
Not sure if this would make any difference at all! However, I can tell you,. ANY time I have an issue with any electronic device getting wet,.... I remove batteries(unplug),.. and throw it into a ziplock bag with a good amount of rice. Then let it sit in there for a couple of days.
By theory,. the rice absorbs all moisture. Not sure exactly if/how it works, but I can confirm that this method has saved many of my electronic devices!!!
- VultAge -
470LT, G420, G570, Chronos, T-Rex 600N and 700N
vultage is offline        Reply With Quote Quick reply to this message
Old 10-30-2020, 05:56 AM   #7 (permalink)
I’ve done this also. Instead of rice you can buy bulk desiccant at the local craft shop (Micheals/Hobby Lobby). Saved a GPS that went for a swim before they put them in everything, including Fido’s collar.
Trick is to do it ASAP, pulling any power right away. You’re trying to keep the water from shorting any circuits and prevent corrosion.
Most things have a conformal coating nowadays, it’s the connectors that are most vulnerable. (Hence the switch warnings)
Jeti DS12 / Ikon2 / Oxy2/4/5 / SAB Mini Comet / Fireball / G380 / Gaui X5v2
Old 10-30-2020, 10:12 AM   #8 (permalink)
if there is no extreme air pollution, rain water is not that dangerous... otherwise electronics should be cleaned with alcohol (i.e. isopropanol) to prevent later oxidation and help it to dry quickly then (rice, better: desiccant).
the real problem i guess was the compressor - if not used with enormous care it is not only able to damage parts on the pcbs or ribbon cables or connectors or even displays etc etc... but air pressure is helping water to get into places it would not have reached without (into switches, connectors, display, etc) - and where you cannot clean as easily anymore. that's the real killer sometimes...
the best receipe is to remove power, then clean & dry asap... i've 'landed' a 550 into a pond 10 yrs ago... after some liters of isopropanol and quick help to dry the complete electronics survived (!). bearings and shaft of course all gone (oxidation).
helis: Logo 444SEXX/555SEX/600SX, HeliBaby NT, Diabolo 700, YGE LVT/HVT, Egodrift, Spirit 2/RS, Jeti DS-12/Spirit Ed.
Rabid121 is online now        Reply With Quote Quick reply to this message
