Go Back   HeliFreak > R/C Helicopter Support > Gasser Helicopters
Gasser Helicopters Gasser Specific Discussion
Old 11-08-2020, 03:05 PM   #1 (permalink)
Default Eagle 2 GS Tanaka rebuild
I just took the engine out of my Eagle 2 GS. Last time I flew it was getting a weird engine buzz, so I decided to take a look. When I first got the heli ( used ), there was some light scoring on the piston on the exhaust port side. Didn't worry about it much and it seemed to run fine.
I didn't find anything to explain the buzz, maybe too lean as I was hunting for the sweet spot on a new carb.
I did decide to replace the cylinder and piston and think they are the same as the Tanaka THB-2510. It's near impossible to find info on this engine, but I think I got the parts right. Once I get the parts and confirm, I will post the part number here in case it helps someone else.
ID:	889573   Click image for larger version
HeliJoel is offline        Reply With Quote Quick reply to this message
Old 11-08-2020, 09:14 PM   #2 (permalink)
Form the picture, the piston is very scored from running too lean, it's good you are replacing it. Running lean and/or the damaged piston could be the cause of the buzz.
Tom
TRM Power
CAUTION - my posts are based on my experiences, yours may be different.
fastflyer20 is offline        Reply With Quote Quick reply to this message
Old 11-18-2020, 09:27 AM   #3 (permalink)
I got my piston and cylinder, they look to be correct. The only difference I saw was on the cylinder where this is a mounting boss. On the original it is filled, on the new one it's drilled to be tapped. Does not seem to matter
The Tanaka/Hitachi parts are,
Cylinder 6685446
Piston 6685889
The cylinder had a stippled finish in it, need to find out if I should hone it or not.
Edit; I decide I am going to hone it, just seems wrong not to.
Now that I have taken a closer look, I see the crank bearings are open. I did flush things out, but given the open bearings, I want to split the case and make sure no metal bits are in there. Things turn smooth for now but... I had ordered a case gasket from another supplier when I ordered the cylinder and piston. It has not shown up yet. For now I wait.
Old 11-18-2020, 09:43 PM   #4 (permalink)
Does the cylinder have a cast iron liner or is it hard-coated? If it is cast iron lined, you can hone it. If it is hard-coated, they are not usually honed, the cylinder is replaced.
Tom
TRM Power
Old 11-19-2020, 07:36 PM   #5 (permalink)
It is hard coated which is what made me think otherwise. I suppose the stippling will help the rings seat.
Old 11-23-2020, 12:21 PM   #6 (permalink)
So I flip flopped and did not hone the cylinder. Engine is back in the heli and I got a first run on it today. Started without issue and runs well, I'm running with the needles a 1/2 turn more open that before. When I put the engine back in, I also swapped carbs, but even previous carb swaps I've always been 1 1/8 turns on L and H needles ( 5000 feet ), any more open than that, the engine Would not run. Now I am about 11/2 turns out running fine.
Few more runs to fine tune.
Old 11-23-2020, 12:49 PM   #7 (permalink)
Default Carb
Is it the same carb or a different numbered version? Often different versions require a different needle setting to achieve the same mixture to the engine.
What carb number do you have?
-=>Raja.
MA 1005, Hanson 270, 4717 flts, Spectra-g, Hanson 270, 3672 flts
Whiplash-g V1-2, Hanson 300, 2235 flts, Whiplash-g V2, Hanson 300, 1552 flts
Whiplash Turbine, TS 45i WSE, 296 flts
Jewel on-board Generators, Miniature Aircraft Team Manager
rbort is offline        Reply With Quote Quick reply to this message
Old 11-24-2020, 12:03 AM   #8 (permalink)
I did change carb types, went from a wt-990 to a wt-643.
Old 11-24-2020, 08:23 AM   #9 (permalink)
Default Well then as I suspected...
They have different needle settings.
For a 643 use 1 1/4 on L and 1 5/8 on H in general for us here at sea level. You'll have to adjust for your altitude.
Best regards,
-=>Raja.
