Like Tree1Likes
  • 1 Post By Puttputt maru
Old 09-21-2020, 10:01 AM   #1 (permalink)
Default NEW Jeti Studio 1.1.3 and DS/DC Firmware 5.04
Hi,
Jeti Studio 1.1.3 and DS/DC Firmware 5.04 are ready for download... 5.04 for DS-12 and DC-16 II only as it seems.
=> same Spirit integration now as DS-12 Spirit Edition... for supported radios
Ciao
Michael
NB: ... as Tomas informed update with the full Spirit integration should be available for all Jeti radios... 14/24 just being a bit late.
helis: Logo 444SEXX/555SEX/600SX, HeliBaby NT, Diabolo 700, YGE LVT/HVT, Egodrift, Spirit 2/RS, Jeti DS-12/Spirit Ed.
Rabid121 is online now        Reply With Quote Quick reply to this message
Old 09-22-2020, 09:50 AM   #2 (permalink)
Does the update just add the new features found in the DS-12 Spirit Edition? Are there any other updates to be aware of?
(I couldn’t find a change log)
JimJW is offline        Reply With Quote Quick reply to this message
Old 09-22-2020, 10:21 AM   #3 (permalink)
... i've just seen 900Mhz NG upgrade and Spirit Ed. features... rest seems to be more/less minor corrections.
Old 09-23-2020, 11:12 AM   #4 (permalink)
Anyone find a change log?
Goblin Kraken / Protos Nitro / Logo 690 / Logo 480 / Logo 480 Nightship / Protos 380 / Oxy 215
Jeti DS-12 Carbon / Brain2 / Hobbywing v4
DIY Night Blade Tutorial
BuildFlyCrashRepeat is offline        Reply With Quote Quick reply to this message
Old 09-24-2020, 07:37 AM   #5 (permalink)
You will see it in the right side window when you are about to do the update in Jeti Studio. No need to actually do the change to see it.
TDSF, TDR-II, Triabolo, 2 X TDR, Logo 700,Protos evoluzione, T-Rex 700Dominator, Goblin700, SpiritRS, Jeti DC-24,HW,Kosmik,Jive Pro
Old 10-02-2020, 01:10 PM   #6 (permalink)
For reference:
JETI DC/DS Transmitter Update V5.04
New Features:
  1. Updated device definitions and configuration files (REX-RS).
  2. DS-12, DC-16II: the 900MHz NG (Next Generation) backup module can be enabled after the appropriate module activation via the JETI SW shop https://swshop.jetimodel.com.
  3. New wizard for helicopters equipped with the Spirit FBL stabilization unit. In the Main Menu – Heli Tuning it is possible to enter directly the configuration menu of the FBL unit.
Modifications:
  1. Updated Spanish translations.
  2. Fixed behavior on deletion of flight mode.
  3. Fixed MP3 playback if the file contains ID3 tags.
  4. Non-identified devices are shown in the Device Explorer with the "N/A" text description and it is not possible to enter the device configuration.
  5. DC16-II: Fixed trainer mode over the PPM Jack connector.
  6. Lua: Fixed possible memory leak during creation of the Selectbox widget.
  7. Lua: It is possible to redirect the audio playback via the setProperty function. Audio is redirected to the internal GPIO connector on the I2S pins (see the Lua API documentation).
    • system.setProperty ("AudioRedir","Output") – redirects only audio output.
    • system.setProperty ("AudioRedir","Both") – both audio output and input are redirected.
    • system.setProperty ("AudioRedir","Off") – disables audio redirection function.
  8. Telemetry reception is now forbidden if an unregistered (non-assigned) receiver has been detected after powering up the transmitter.
  9. The "New" and "Delete" buttons in various forms have been replaced by the equivalent icons ("+" and "").
The switch conversion dialog (see Model – Functions assignment, F1 button) now displays the assigned controls correctly.
Old 10-10-2020, 02:50 PM   #7 (permalink)
Darn it does not seem to be available for my DC-24. What gives, I am already a second rate user with my DC-24???
Old 10-11-2020, 03:22 AM   #8 (permalink)
i do not remember if it was Spirit forum or German jetiforum i saw the information... but the post explained Jeti is a bit late with the other TXs and the update is supposed to be available by end of october for all Jetis.
Old 10-11-2020, 07:09 AM   #9 (permalink)
.Ok thanks.
Old 10-11-2020, 09:52 AM   #10 (permalink)
I'm hoping it will have full function on my ancient DS16....
Jeti DS-16, Oxy 3, Goblin 380, 500, 630, and 700 competition, Airwolf 600 scale heli, Brain/Ikon 2, Spartan VX1e, Sk 720, YGE and Hobbywing.
Shogun71 is offline        Reply With Quote Quick reply to this message
Old 11-15-2020, 07:37 AM   #11 (permalink)
version v 5.05 is now available on Jeti Studio even for DC-24
Old 11-15-2020, 10:00 AM   #12 (permalink)
Mirco
gelatmi1 is offline        Reply With Quote Quick reply to this message
Old 11-15-2020, 10:17 AM   #13 (permalink)
I just checked and no update yet for my DS-16. I am now feeling left out.
Whiplash Turbine - Synergy N7 Gasser - Synergy E5SS - Goblin 500 - T-Rex 450L (x2) - Oxy 2 - Spirit FBL - Jeti DS-16
AccuRC to train my brain
FrankFuss is offline        Reply With Quote Quick reply to this message
Old 11-15-2020, 11:41 AM   #14 (permalink)
Default Update Log:
JETI DC/DS Transmitter Update V5.05
New Features:
  1. Support for US DS-12.
  2. Support for DS-16 II.
Modifications:
  1. Fixed modules activation in "Assist" receivers.
  2. Changed message "Signal Loss" to "Telemetry Loss".
