Scorpion ESC and Motor Support Scorpion Power Systems ESC and Motor Factory Support Forum |
11-20-2020, 06:47 AM | #1 (permalink) |
Tribunus 80 Telemetry Issue
My Tribunus 80 is reading my battery voltages incorrectly. Using a Vcontrol touch I set the pack useage % I want on my pack, never had a problem with this before, but if I fly down to 30% remaining the pack is severely discharged when I check it on the ground. I had to set the use capacity to around 50% to get the packs to come down with about 25% actually left in them. Never had an issue like this before, and setting it like I did seems to work, but is weird. Any ideas?
11-20-2020, 11:20 AM | #2 (permalink) |
Instead of 'faking' the pack capacity, I think it's better to calibrate the internal current sensor in the ESC using the Current sensitivity gain, setting 5E in the manual
http://www.scorpionsystem.com/files/...bunus06-80.pdf I think this parameter may also be available directly in the Scorpion app on the VBC.
Logo 480, 550 SX (YGE/Xnova), 690 SX (Tribunus/Scorpion), Savox/MKS, NEO, VBC |
11-20-2020, 01:16 PM | #3 (permalink) |
so would you go up or down with the numbers in 5E?
a bunch of helis... now all vcontrol and neo..finally :lol |
11-20-2020, 07:43 PM | #4 (permalink) |
What do you call "severely discharged"? How do you measure it?
Henseleit TDR, TDR2, TDF, TDS, TDSF Kontronik, Scorpion ESC, iChargers, VBar, VControl Old hand at Planks Peter |
11-20-2020, 08:02 PM | #5 (permalink) |
I’m guessing that in his case he should increase it, but the direction is not exactly intuitive so I may have it backwards. A bit of trial and error is required to get it adjusted until it matches fairly closely the amount of mAh your charger puts back in.
12-07-2020, 09:17 PM | #6 (permalink) |
On my 6-80A I had to go around +40 on the current sensitivity. Only problem is this isn’t to go this high with the VBCt. You have to use the Sproto software to be able to get it high enough.
Specter 700 V2 NME, Nimbus 550, Protos 380 EVO, Logo 200 Vbar Control Touch, Neo's, Scorpion ESCs, Ego Motors |
