Go Back   HeliFreak > R/C Helicopter Support > OXY HELI > Oxy 5
Like Tree9Likes
  • 1 Post By JimJW
  • 4 Post By rdlohr
  • 1 Post By slogoat
  • 1 Post By rdlohr
  • 2 Post By jrman83
Old 11-23-2020, 08:19 PM   #1 (permalink)
Default OXY 5 rotation arms don't line up (fixed, something not seated fully)
OXY 5 rotation arms don't line up perfectly and cause it to bind. Is this a thing or did I do something stupid? I could shim it but I figured I should ask first. Sorry if this has been covered elsewhere.
Rick
Name:	Rotation Arm not lining up.jpg
Helifreak, the place to be!
rdlohr is offline        Reply With Quote Quick reply to this message
Old 11-23-2020, 10:16 PM   #2 (permalink)
Hi Rick, are you repairing after a crash or just building it up?
I think it’s possible that something might be upside down or inside out. In general you can see the OXY logo or print from the top and outside face of the links.
The other thing is there are a collection of washers in the assembly. Any chance you are missing one or two?
Jeti DS12 / Ikon2 / Oxy2/4/5 / SAB Mini Comet / Fireball / G380 / Gaui X5v2 / Kraken 580
Old 11-23-2020, 11:13 PM   #3 (permalink)
I think itís possible that something might be upside down or inside out. In general you can see the OXY logo or print from the top and outside face of the links.
It's the initial build. The arms were factory built and I just did the loctited screws. All the washers are as they did them which seemed to match the manual. It's pretty simplistic. It's the Flange bearings sandwiching a bushing and one washer outside of each.
Rick
Name:	Rotation Arm not lining up 2.jpg
Old 11-24-2020, 05:25 AM   #4 (permalink)
Look at your following arms,make sure there in the rite spot on the head and faceing the correct way.
Also,The linkage rod should should be in line with the center of the head block going to the swash..
Iam adding a few pics of what it should look like..hope it helps..
(The linkage arm from the blade grip should NOT be near the bolt that holds the follow arm on)
ID:	891643   Click image for larger version
hawkeye690 is offline        Reply With Quote Quick reply to this message
Old 11-24-2020, 07:05 AM   #5 (permalink)
Thanks for the nice clear pictures. Mine are exactly like yours.
If you pop one link off, does the other side line up perfectly?
Rick
Old 11-24-2020, 07:38 AM   #6 (permalink)
Not really sure what your asking but,,In the pics you will see how the arms should line up..
Also notice how the solid plastic likes are and where they attach to the swash..
Look over the manual again and also use the pics ..
Note,,you can also just put the linkage arms from the blade grips to the swash and you should see how the follow arms should go..
I would like to see a pic of yours looking straight on and from the side if you still have problums...
Old 11-24-2020, 08:08 AM   #7 (permalink)
Rick, it sounds like you are saying that something might be bent or otherwise out of kilter. I’ll say mine went straight on. From your picture it looks like you’re about half the diameter of the ball off...
Try a couple things:
1) take the head off and put it down on a piece of graph paper or something that gives a fair reference. Even regular lined paper could work. Rest it on the bottom of the head and align the long edge with one of the lines on the paper. Spread the swash drivers out and look to see if they are in line. What you’re looking for is that one or both sides a straight.
2) loosen up the 4 bolts that attach the swash driver to the head and the make up the intermediate pivot. Is there a lot of play in the bearings? (Was it kitty-wumpus when it was tightened down)
If it’s not an assembly issue, then maybe a part is warped or bent?
Old 11-24-2020, 08:30 AM   #8 (permalink)
I'm pretty sure it is exactly per manual. Nothing looks warped or bent. It relies on the flexibility of the arms to allow it to go on. It may have seemed OK if you were not looking for it. I request that someone pop one off for me just to try it please.
Rick
Old 11-24-2020, 08:36 AM   #9 (permalink)
I popped mine off. As expected, the plastic part falls right onto the ball:
In the photo the link is off and the ball is centered in the hole without any force pushing it one direction or the other.
rdlohr likes this.
Old 11-24-2020, 09:57 AM   #10 (permalink)
Scratch all that. All I had to do was take them apart and put them back together again. Something was not aligned properly. All is OK now. Thanks for the help.
Rick
jrman83, cyclo, xoexoe and 1 others like this.
Old 11-24-2020, 12:32 PM   #11 (permalink)
Rick
Great to hear! I wonder if a bearing wasn’t seated all the way into the plastic or something? Either way, glad to hear you got it figured out!
(Is this the same build that you had issues with the tail assembly?)
Old 11-24-2020, 02:34 PM   #12 (permalink)
Yep,good to hear!..Sometimes ya just need to step back,take a breath and start over,,youll love the OXY 5
Old 11-24-2020, 04:26 PM   #13 (permalink)
Great to hear! I wonder if a bearing wasnít seated all the way into the plastic or something? Either way, glad to hear you got it figured out!
Yep, with the Covid thing and starting a different job at work, I kind of wasn't feeling it and had not continued the build. I'm happy to say I am now of a right mind to enjoy building this beast.
I'm guessing a bearing was not seated as well. Glad I was not in a hurry and took the time to make it right.
Having built the head now I have to say I'm impressed with how rock solid it is. I can see how it will make this baby fly like it's on rails. The links were stiff as hell. Looking forward to seeing how they work out when I go to fine tune them.
Rick
Old 11-24-2020, 04:28 PM   #14 (permalink)
Glad you got this sorted. I had been following, and even checked out the manual to make sure everything looked right in your pics! lol
I knew mine went together smooth, and it was driving me crazy you ran into this. Let us know how it flies when you get done!
rdlohr likes this.
www.cajunaircraft.com <-
SAB\OXY\SYNERGY\MSH\XLPOWER\GAUI Fanboy
slogoat is offline        Reply With Quote Quick reply to this message
Old 11-24-2020, 05:26 PM   #15 (permalink)
Thanks slogoat. I appreciate that you did that. I'll let everyone know for sure!
Rick
slogoat likes this.
Old 11-24-2020, 07:19 PM   #16 (permalink)
I think your arms may have warped slightly from sitting in the box so long
Sent from my SM-G988U using Tapatalk
KiwiBlair and xoexoe like this.
jrman83 is online now        Reply With Quote Quick reply to this message
Old 11-24-2020, 08:34 PM   #17 (permalink)
lol, well played.
Rick
Old 12-01-2020, 01:36 PM   #18 (permalink)
I was wondering what happened to this build. Thought you tried it and didn't like the heli perhaps and just let the thread die.
Thickfog is offline        Reply With Quote Quick reply to this message
Old 12-04-2020, 05:27 PM   #19 (permalink)
