Go Back   HeliFreak > R/C Simulators Support > AccuRC Flight Sim
AccuRC Flight Sim AccuRC Flight Sim Discussion
Like Tree1Likes
  • 1 Post By Ade_Law
Old 12-06-2020, 05:19 AM   #1 (permalink)
Default [BUG] Camera position and Reset in VR
I found AccuRC makes sometimes weird things with camera and I think I tracked it down.
This is what happens if you run AccuRC in VR Oculus mode and use a 3D (Free Roam) map:
  • initially, when you go flying, you can't walk or move your head (I mean move, not rotate). I mean you can, but in the sim your head position is always same (causes motion sickness to sensitive people)
  • then you go to menu -> Settings and back (no need to change anything)
  • then you can move your head around freely (which I think is correct). You can look at the heli from different sides or walk around if you want (and have long cable and lots of space..)
  • but when you press SPACE to reset the heli, you're back to the situation when you can't move your head
If you run in "Steam VR mode", it works same way, but additionally
  • camera position is lower, when head movement tracking does not work
  • heli position is higher when it works (after going to Settings and back)
  • no idea which position is the correct one...
Notice, it is about head movement, not rotation. Rotation works fine.
So what is problematic is:
  • In Oculus it's just about motion sickness. You get it if you're moving your head but the video does not follow.
  • In Steam it's about motion sickness and additionally camera position after reset
I capture this on videos. Obviously when I try to move the head, but AccuRC doesn't react, you don't see anything in the video. So I added subtitles explaining things - be sure to enable them.
Steam version:
AccuRC Camera Reset Problem - Steam (0 min 28 sec)
Oculus version:
AccuRC Camera Reset Problem - Oculus (0 min 33 sec)
My site with software for Helis: http://rc.a-soft.org
Software for OpenTX. Software for Windows coming soon.
Arek is offline        Reply With Quote Quick reply to this message
Old 06-30-2021, 02:10 PM   #2 (permalink)
Could this problem be addressed? Is it easy or hard to fix?
I've spent last 500h in the sim on Olympic Stadium and it works, but I'm always 5 m above the ground, which makes for unrealistic learning
Old 06-30-2021, 02:20 PM   #3 (permalink)
arek please report bugs either directly to us or on our discord
Ade
Johnny31297 likes this.
[email protected] Direct Email
[email protected] AccuRC Support
https://discord.gg/ftCKT8U AccuRC Discord Server
Ade_Law is offline        Reply With Quote Quick reply to this message
Old 07-02-2021, 12:44 AM   #4 (permalink)
So where to report this on Discord? It seems there is only section for v3-alpha?
Old 07-02-2021, 10:05 PM   #5 (permalink)
we arent fixing bugs on v2 now, you might want to check out v3 alpha and see if the bug still exists for you, if it does report it there.
Old 07-03-2021, 01:13 AM   #6 (permalink)
Wouldn't it make sense to bug fix v2, and just not add new features, considering that v3 is in alpha stage?
Old 07-03-2021, 01:47 AM   #7 (permalink)
Simply put... no. bug fixes get released with every release the next release will be v3
Old 07-03-2021, 06:17 AM   #8 (permalink)
Ok, downloaded 10 GB of v3 alpha. But it doesn't seem to start in VR mode at all, how does one get in VR?
Old 07-03-2021, 09:47 AM   #9 (permalink)
Ade
Old 07-04-2021, 02:02 AM   #10 (permalink)
Ade
Hey Ade, we discussed this in the past. I'm sorry, but spending 1h trying to reproduce a random bug, find a pattern when it happens, make screensots, record videos and make descriptions just to put it on Discord chat and see it being scrolled up and fade away in 5 minutes isn't fun at all...
Can you just say - is VR just not there yet in v3, or is there an issue on my PC?
Old 07-04-2021, 05:26 AM   #11 (permalink)
I tried what you said on that gymnasium scene you are using. I never fly that. I really don't like it or most of the 3D scenes.
Yes when I start in the scene, I am not able to move around the heli. I don't mind that but I think being able actually step left, step right and pivot while flying would be more realistic.
However, after I go to settings and then return to fly. I appear to be 3 feet taller and I am standing much closer to the heli. The heli has also shrunk in size somewhat.
I can however move around the heli as you describe.
I would say that is a bug and not just your system.
Hope that helps.
wab223 is offline        Reply With Quote Quick reply to this message
Old 07-04-2021, 07:30 AM   #12 (permalink)
Hope that helps.
Thanks for trying!
Ok, the bug from the first post is there - I know. Great that it is same on your PC too, at least it is consistent.
The "problem with my system" I mentioned in recent posts wasn't about the bug, but about VR not running at all in AccuRc V3 Alpha. Did you test it maybe?
As for 3D scenes - sure, tons of reasons to hate them. They look like crap, use more CPU/GPU and are buggy in AccuRc. But I highly recommend you to try it. TBH Olympic Stadium is the only one which is usable. If you fly it for a week, you will never go back to photo fields. They will just feel wrong.
Why is that - I don't know... maybe it's lack of proper 3D on photo maps, or maybe they are poorly mapped into 3D world (I think this is actually not trivial) and VR exaggerates that, I don't know. But 3D maps add another level of realism and a huge one
Old 07-04-2021, 07:55 AM   #13 (permalink)
Yes, I tried the Alpha. I only tried it in VR.
It was not useable and I quickly reverted to the normal version.
Perhaps its not meant to be used in VR?
There was a bug in nvidea drivers (I use an RTX 2080) at the time I tried it. I received a driver update a day or so after. I cannot recall the details of the bug, but I assumed it could have been related and so I did not mention it.
I spent a lot of time in the distant past testing AccuRC and to be honest I am a little tired of that process. I prefer to use the sim as released.
But for you, I will try to make time to give the Alpha another go and report back Sir!
Old 07-04-2021, 11:25 AM   #14 (permalink)
Arek,
the Alpha works in 2D from what I tried.
The sounds I think are RC plane sounds. I think planes are perhaps the focus of the alpha.
The alpha does not work on my Reverb G2. I ended up rolling back and its all good on the standard release.
I am not really prepared to try more without knowing if the alpha is intended to work with VR.
Of course if requested, I would make an effort to help.
This information may already be known to the team. (I mean G2 not working in VR)
Thanks for posting. You are helping to make software better.
Old 07-04-2021, 10:40 PM   #15 (permalink)
the v3 bug reports channel on discord is watched by our lead dev and we will contact if we need more information.
everything is being worked on we are aware there are issues with VR but without people trying it with various bits of hardware sometimes its hard to spot an issue. We cant go out and buy every VR headset.
V3 has some massive changes under the bonnet that improves load times etc.
Old 07-05-2021, 01:08 AM   #16 (permalink)
Yeah I reverted to v2 as well. Could test on Reverb G2 anytime if needed..
