Go Back   HeliFreak > R/C Electronics Support > FrSky
FrSky FrSky product discussion.
Like Tree12Likes
Old 12-06-2020, 12:13 PM   #1 (permalink)
Default Thinking of Switching to Frsky
I currently use Futaba with S-FHSS protocol. Thinking of switching to Frsky Horus x10. I love the value with telemetry and integration with Sprit FBL. However, I'm concerned about the relatively high latency. Looks like Frsky latency with sbus averages 20-40ms. Seems high, but will the user really notice the difference? There are plenty of transmitter latency numbers reported on the internet, but numbers don't mean much without the real world experience. Does anyone have direct experience they can share?
Grewrob is offline        Reply With Quote Quick reply to this message
Old 12-07-2020, 06:14 AM   #2 (permalink)
I switched from the Spektrum DX9 to the Taranis X9D+ Pro (and a Horus X10S) and notice far more flexibility with Taranis / Horus radios (especially using the OpenTX firmware) over the Spektrum. Then you have the expansion bay housing a multi-mode module and now the Taranis can control nearly every receiver available.
Actually, I found it easier to use / program for me. Plus the PC based Companion software that allows one to program the radio and test the programing results on screen, before flying, is what sealed the deal for me.
As far as latency goes, I found no noticeable difference / problems. But then again, I am not a hardcore 3D flyer.
The cost of ownership issue is also a no-brainer.
Just my humble opinion
04fxdwgi is offline        Reply With Quote Quick reply to this message
Old 12-07-2020, 08:17 AM   #3 (permalink)
I have no latency issues, but I've been flying FrSky for years. There are a couple of things that you can use to reduce latency with it.
1 - Use only 8 channels or less. I fly Brain and you can use up to about a dozen channels with the tuning parameters. You'll notice when you add more channels that the transmitter will indicate that the latency will go up.
2 - ACCESS has lower latency that ACCST. Since you're buying a new radio, just buy and use ACCESS receivers. Just use an Archer R4 or R-XSR as a receiver. Don't let the tiny size and price fool you. They are rock solid RXs.
P Max v2, XL520, P380, XK K110, Open-TX
JWeber is offline        Reply With Quote Quick reply to this message
Old 12-08-2020, 05:55 AM   #4 (permalink)
Thanks for the replies. Very helpful
I bought a used Horus with ACCSS. Are ACCESS receivers compatible with ACCSS?
Old 12-08-2020, 07:55 AM   #5 (permalink)
ACCST and ACCESS are two different protocols.
Do not use the Archer receivers as they do not support ACCST.
The RX series of receivers can do both protocols, so if you do decide to upgrade your TX at some point, you are forward comparable. Stick with the RXSR or RX4R, RX6R etc.
Old 12-08-2020, 08:42 AM   #6 (permalink)
I've been flying FrSky for like 3 years. I have never noticed any significant latency. Maybe it's there, maybe it's "worse" than Futaba S-FHSS, maybe a super top end professional pilot would notice. But I don't.
AtTheCross likes this.
Keith - XLPower | KST | Egodrift | KC3D
Protos 800X Evoluzione | Protos Nitro | Specter V2 | Protos 380 Evoluzione V2
Number is online now        Reply With Quote Quick reply to this message
Old 12-08-2020, 09:57 AM   #7 (permalink)
Because you aren't superhuman in your piloting skills already? I have seen you fly. I ain't buying it! If anyone could discern 5ms difference in latency, it'd be you.
beltfedbrowning and Grewrob like this.
Ivan is offline        Reply With Quote Quick reply to this message
Old 12-17-2020, 10:36 PM   #8 (permalink)
Default Question about the Horus X12S
I'm considering swapping from my DX8 G2 to the Horus X12S. I currently fly spektrum dsmx satellites on all my models. Would this frsky sat be all that I need to convert my fbl? And what cable would I need to connect the frsky sat to my fbl? 1-Brain2, 2-spirits, 1-omp v2.
Thanks for any input
frsky sat - https://www.amainhobbies.com/frsky-r...022441/p696002
BELL SKY is offline        Reply With Quote Quick reply to this message
Old 12-17-2020, 11:10 PM   #9 (permalink)
Bell, the R-XSR is a great, small receiver. It comes with a 5-pin cable that plugs into the header, but you'll probably find that you'll need to crimp your own connectors to the other end.
You will need two separate connections from the R-XSR to the FBLs. One is for telemetry (S.Port) and one is for the channel data (S.BUS). On both Brain & Spirit you will need an inverter cables on one of those connections. For the Spirit, the inverter cable is needed for telemetry/integration between S.Port and SYS. For Brain, it's needed between the S.BUS and SAT1 or something like that. That’s from memory, check the manual to be sure.
The inverter cables are made by their respective manufacturers. Open up the manuals for each FBL and you'll see where you need them. The Brain is of course in the software itself. Here's the Spirit info: http://manual.spirit-system.com/inde...TX_Integration
BELL SKY likes this.
xoexoe is online now        Reply With Quote Quick reply to this message
Old 12-17-2020, 11:27 PM   #10 (permalink)
I have a few Spirit inverter cables I am not using. They have the standard servo connectors (0.1", 2.54 mm pitch) connectors on both ends rather than the Spektrum 1.5 mm pitch on one end. I preferred it even on the µSpirit because I could easily disconnect it to gain access to the SYS port, which S.Port telemetry also uses.
You can have two if you decide to pull the trigger on FrSky + Spirit. Let me know.
Oh yeah, one last thing that comes in handy with FrSky stuff is the ability to crimp your own connectors.
Old 12-18-2020, 12:46 AM   #11 (permalink)
Appreciate the replies Xoe, do you happen to have a picture of the cables I can see for reference or does a mfg make them? I'm not gonna bs, wire crimping is not my specialty. I appreciate the offer as well, if it's something I can not source I will let you know.
Old 12-18-2020, 12:50 AM   #12 (permalink)
Links:
https://store.spirit-system.com/en/a...ion-cable.html
https://www.amainhobbies.com/msheli-...h51645/p893695
I recommend you look at the products and videos made by Hansen Hobbies. http://www.hansenhobbies.com/products/connectors/
60 Second Servo Connector (1 min 21 sec)
— XLP Specter V1, XLP 550, Oxy 4 Max, Oxy 2, OMP M1 —
— Spirit GT — Egodrift & XNova, YGE & Scorpion, FrSky Horus OpenTX —
— WTB XLP Wraith for cheap —
Old 12-18-2020, 09:52 AM   #13 (permalink)
10-4, I appreciate the info. I see spirit does not have any of the cables in stock. Is there a place I can source them locally? I checked out the store link on the bottom for custom leads but I’m not sure what I was looking for. I’m just used to spektrum sats so frsky is all new to me. Thanks again
Old 12-18-2020, 11:08 AM   #14 (permalink)
You might ask Tomas directly when he’ll get more in stock. Do it soon since it’s evening in Czech already. Never seen another place that sells them to the US other than the Worldwide eshop on Spirit’s website.
Old 12-20-2020, 08:23 AM   #15 (permalink)
Thanks for all the info. It's very helpful.
Do you know if the FrSky integration cable is the same as the SBus inverter cable? Hopefully the answer is yes because I have an inverter cable for sbus but not FrSky
Old 12-20-2020, 12:00 PM   #16 (permalink)
you don't need cables if you solder to the inverted pads on the r-xsr
BELL SKY and xoexoe like this.
XLPower 520 - Brain
OMP M2 Explore - HeliFlight-3d
TX: Fr-Sky X9 Lite S
P.I.Engineer is offline        Reply With Quote Quick reply to this message
Old 12-20-2020, 12:02 PM   #17 (permalink)
I think the only difference might be what voltage it runs on. It's kind of confusing, but I think S.Bus runs on 3.3V and S.Port runs on 5. However most 5V inverters will work just fine with 3.3V.
I use F.Port by hooking into the inverted port on the X4R-SB ala Oscarliang.com so I haven't used an inverter...yet.
I bought all the stuff to convert my X12S to ACCESS and a couple Archer R4s. The problem is that they still need the inverted signal and the inverted signal is only on a leg of the microchip, so it's extremely difficult to solder into.
Hence, I bought all the stuff to make this:
https://hackaday.io/project/27894-fr...tport-inverter
I bought enough to make 10, but 60 boards. So if the first 10 work, I can order more resistors and MOSFETs. So far I have about $15 in stuff. I think if I make all 60, the price comes to about $0.20 each.
Here's to hoping!
Old 01-02-2021, 01:44 PM   #18 (permalink)
Do you have an example of this? I'm not really interested in the telemetry at the moment. I'm only focused on getting them in the air. The only thing stopping me from switching to open tx is that there are no inverter cables available from spirit atm. If I could bypass these cables and "solder to the inverter pads" it would make the decision to switch a lot easier.
Old 01-02-2021, 01:50 PM   #19 (permalink)
If you don't need telemetry (so no S.Port or F.Port), you can just use a regular female to female servo lead directly between the S.Bus ports.
Old 01-02-2021, 03:04 PM   #20 (permalink)
Thanks for the reply, I'm trying to wrap my head around this.
To use the R-XSR S.Bus rx what cable would I need? Furthermore the sbus port would obviously plug into the rx but what ch. does the lead plug into on the spirit? I cant seem to find an sbus-sbus cable.
