Go Back   HeliFreak > R/C Helicopter Support > SAB Goblin 630/700/770
SAB Goblin 630/700/770 SAB Heli Division 630/700/770 - Goblin Helicopters Factory Support
Like Tree469Likes
Old 03-29-2021, 11:35 AM   #641 (permalink)
I just bend a piece of metal into a 'Z' shape and wire tie it to the main shaft. It has proven to be universal so I can use the same one from model to model of the same size. They can also be made shallow enough so you don't need to remove the head. I suppose a bracket ( [ ) shape would work too.
With that said, I don't fully install the head on a new build until the swash is level.
blkdout is offline        Reply With Quote Quick reply to this message
Old 03-29-2021, 04:01 PM   #642 (permalink)
Originally Posted by Weule View Post
Its great for setting zero and the center point without removing the head (it sits on top of the transmission instead of resting on the main shaft).
Setting high also works well, but low cannot be set from underneath (I use a caliper to set low, but levelers that work from above should work)
I have this swash tool, issue I noted that if you use that as your level and your zero geometrically the arms are actually (low). If you go by manual as to the servos to swash lengths the arms are in fact 90, so that to me is "odd"
Old 03-29-2021, 04:16 PM   #643 (permalink)
Probably due to differences in servos. Stock lengths have been perfect for me over 2 Krakens and a Raw using XPert servos.
Roadkinghd likes this.
Weule is offline        Reply With Quote Quick reply to this message
Old 03-29-2021, 04:28 PM   #644 (permalink)
I run MKS X8s.
What I am saying though, servos aside, length aside the SAB swash level device with the swash resting on it, the follower arms are actually (low), not 90. I was speaking to that.
Old 03-29-2021, 04:44 PM   #645 (permalink)
I run MKS X8s.
Just checked and both my Kraken and Raw have perfectly level followers using the SAB leveler.
It doesn't surprise me you are running X8's. They are slightly non-standard so you might have to adjust the servo to swash links.
Old 03-29-2021, 05:02 PM   #646 (permalink)
That would imply the X8 output shaft is higher than a standard servo. I can't find my calipers or dimensions online at the moment - I'm going to have to check this because I have X8's on another model. Hmmm.
Old 03-29-2021, 11:57 PM   #647 (permalink)
Hmm I will re look at this, now curious I could have sworn the follower arms were actually on the low side of being geometrically correct.
Old 03-30-2021, 06:35 AM   #648 (permalink)
I have Xpert servos and use the swash level tool for mid stick, I have zero deg on blade grips, but I am getting two deg more positive that negative.
jonners likes this.
Karim
MIkado VControl Vinyl Wrap
KBaksh is offline        Reply With Quote Quick reply to this message
Old 03-30-2021, 09:49 AM   #649 (permalink)
Fairly typical problem. Get it the best you can, then adjust the pitch range in your FBL controller.
jakeg1999 and jrman83 like this.
Old 03-30-2021, 11:12 AM   #650 (permalink)
Thatís what I do, I thought you had even travel on both negative and positive.
Sent from my iPhone using Tapatalk Pro
Old 03-30-2021, 11:33 AM   #651 (permalink)
All things being equal: same length linkage, servo arms at perfect 90deg without any digital adjustments, you would get equal collective movement.
However this isn't the case, and we always have to adjust the servos a little which affects equal collective. It's simple to just make the adjustment digitally which with a good clean setup, won't be much.
jakeg1999 is offline        Reply With Quote Quick reply to this message
Old 03-30-2021, 12:00 PM   #652 (permalink)
For those new to the leveler, be very careful to avoid moving the swashplate lower then center. It will jam up your servos.
A nice feature of the XPert's is they have overload protection. They seem to simply ignore the command entirely.
Old 03-31-2021, 03:02 AM   #653 (permalink)
Same issue with KST servos on my and my friends raw.
It is impossible to solve it mechanically.
I've adjusted collective travel in Vbar neo "coll throw" menu.
racer-g is offline        Reply With Quote Quick reply to this message
Old 03-31-2021, 07:47 AM   #654 (permalink)
In the 20 or so systems I have built, only once are twice has pitch been equal +/- or really close. But, this is why our FBL has features to even us out.
-Ben
Old 03-31-2021, 11:30 AM   #655 (permalink)
Any head that looks like this will have the issue:
This is because when the links are not perpendicular to the grip arms. As a result, equal movement of the swash up/down will result in a different angle at the blades. As mentioned by the others, the solution is usually to adjust the overall travel of the swash so that it’s equal in both directions.
There’s other options but it means compensating with how the swash is setup. (Not common either...)
Jeti DS12 / Ikon2 / Oxy2/4/5 / SAB Mini Comet / Fireball / G380 / Gaui X5v2 / Kraken 580
Old 03-31-2021, 01:18 PM   #656 (permalink)
^^ welp, that's every model I have except the flybarred one
I had a difference in +/- pitch on one model. I fixed it mechanically by adjusting the swash links as a team until it was solved.
Even my Protos with the included leveler, I had to re-level the old fashioned way to counter drift. I like to level the swash at high and low pitch as well so my little "Z" tool is perfect for that. Can't justify the cost or space of those fancy levelers.
Old 04-05-2021, 07:50 AM   #657 (permalink)
Goblin RAW on maiden day. 1850rpm flight.
Definite improvement over the kraken in flight characteristics.
SAB Goblin RAW 700 Maiden 1850rpm (5 min 3 sec)
OICU812 and jrman83 like this.
ChopsyWA is offline        Reply With Quote Quick reply to this message
Old 04-05-2021, 08:33 AM   #658 (permalink)
For those who are afraid of visibility the above pic from the video has made me think of something that has not been discussed, the color of the battery
fiddle likes this.
Old 04-05-2021, 08:57 AM   #659 (permalink)
If you colored the frame pieces that surround the battery, then you'd add something.
-Ben
Old 04-05-2021, 09:23 AM   #660 (permalink)
https://youtu.be/oruKdps_K7o
Interesting, what style did you end up with? 40 is lowest I ever heard of anyone messing with lol. Makes me think gotta try for giggles, lowest any heli I have really settled on was 88 actually.
Also noticed your comment on blades from UT to Azure, did not like the 700 ultimates?
Nice flying otherwise, has good grab for 1850 rpm.
