Go Back   HeliFreak > R/C Helicopter Support > 150 Class Electric Helicopters
150 Class Electric Helicopters 150 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Like Tree6Likes
  • 1 Post By Smoggie
  • 3 Post By Number
  • 2 Post By Number
Old 11-13-2020, 01:56 PM   #1 (permalink)
Question Align trex 150 or omp hobby m2
Hey I just wanted to know everyoneís opinions Iím looking for a new smaller scale heli Because honelsty i donít really like how the blade mcpx bl2 flips. I just donít but thatís for a later discussion. Wich is better ik the packs are bigger for the omp hobby.
Thanks in advance and have a great weekend
Happy Veterans Day
Stay safe
God bless
Helienthusiasted is offline        Reply With Quote Quick reply to this message
Old 11-27-2020, 10:39 PM   #2 (permalink)
Which heli's have you flown, just to understand what you like?
What don't you like about the BL2? I think it's be best heli in its class.
azn_ace is offline        Reply With Quote Quick reply to this message
Old 11-27-2020, 11:54 PM   #3 (permalink)
The OMPHobby M1 is far better than the mCPX BL2, being much more durable and reliable. Placed next to it, the mCPX Bl2 looks like a cheap toy. It is a bit harder to fly though mainly because of its power. It flies more like a Trex 150X but is also much better in terms of durability and reliabilty.
zadaw is offline        Reply With Quote Quick reply to this message
Old 11-28-2020, 12:51 AM   #4 (permalink)
I can't speak to durability because I haven't crashed the M1/M2.
I've flown the M2, and I've heard the M1 flies similarly.
Frankly, I like the way the BL2 flies better than the M2. It's much lighter and hence doesn't need the crazy head speed to do maneuvers.
I saw a post from another expert flyer (Jeffhelico) that he prefers a K110 over an M2 due to this aspect.
So unless you're doing some violent high speed maneuvers that a BL2 can't achieve (which most of us aren't at the skill level anyway), I prefer a lighter heli.
BTW, is the comment on "looks like a cheap toy" related to the use of light plastic? Some folks like "upgrades" to metal swash, metal head, etc. All those things are unnecessary in a small heli and only makes something else break in a crash.
Old 11-28-2020, 02:37 AM   #5 (permalink)
Sure the XK K110 is a great small Heli, I used it 4/5 months before using regularly my M2s
The eachine 160 is not bad also, as a bigger and not too heavy one, but I don’t use it very often, no so fun than the others.
Waiting for the M1 though... I fly most of the time with the M2 these days , I like it a lot, as a beginner (8 months) and I hope that the M1 will be a good fit for my backyard.
XK K110 - e160 - OMP M1
OMP M2 V1 & EXP
ALZRC 380
AccuRC
Hebus is offline        Reply With Quote Quick reply to this message
Old 11-28-2020, 03:40 AM   #6 (permalink)
I have owned both the Trex 150 and the M2. The Trex 150 was easily the worst heli I've ever owned, a complete waste of money. Tricky and frenetic to fly, fragile and a nightmare to work on. The M2 I liked so much I so much that I decided to sell them!
To be fair the M2 is a much bigger heli than the Trex 150, so not really a fair comparison. The M1 would be the closer heli to compare.
MeekaMoMo likes this.
Gob Kraken |Gob 700 BT 'T' | Gob 770 Comp | SoXos Strike 7 | Henseleit TDR, TDSF & TDR2 | Kasama Dune | OMP M1&M2 | UK stockist for OMPHobby M1/M2 ScotiaRC.co.uk
Smoggie is online now        Reply With Quote Quick reply to this message
Old 11-28-2020, 09:28 AM   #7 (permalink)
The M2 and T-REX 150 aren't really comparable. They are totally different sizes. The original T-REX 150 was a piece of garbage to put it nicely, but the 150X was/is a much nicer heli and I'd own one again. Frankly it was probably the best micro heli available in its day in my opinion and still one of the best flying micros in its size class (110 to 120ish mm) I've owned. I'd take one over the mCPX BL/BL2 any day of the week.
T-REX 150X | Monster Micro (2 min 50 sec)
That said, with the OMP M1 right around the corner, it might be worth waiting to see how that one turns out. I have one on preorder and will definitely be doing plenty of videos with it. With how good the M2 is I have a feeling the M1 is going to be the new standard for high performance micro helis.
Keith - XLPower | KST | Egodrift
Protos 800X Evoluzione | Protos Nitro | Specter V2 | Protos 380 Evoluzione V2
KC3D - 3D Printed Heli Upgrades, Charge Cases and More, RC Electronics Repair Services
Number is offline        Reply With Quote Quick reply to this message
Old 11-28-2020, 11:38 AM   #8 (permalink)
It was the original 150DFC I had, and it was indeed 'garbage'. I was under the impression that the later 'X' version was virtually the same but with a different flight controller?
Old 11-28-2020, 11:47 AM   #9 (permalink)
Yes, and that's what made the difference. The GRS flight controller on the 150X was galaxies better than the MRS on the original. There were some other small changes such as a steel main shaft on the X instead of aluminum on the DFC (which bent with the tiniest impact) and other things made metal instead of plastic (swash I think). They also changed the tail motor wiring so there was a connector in back so changing the motor was easily. And I believe on the X the frame was beefed up a little bit. I never broke one but the DFC was kind of known for breaking them so they definitely changed something, if not the design then the material.
When I had mine, most crashes nothing broke. I did the servo saver mod which is a 100% necessity. Basically you cut a slit in the servo horn so that when you crash the horn slips rather than stripping your gears. In a good crash you might have bent a feathering shaft but main shafts were rare. Most of the time it just ejected the skids and canopy as you can see in some of my other T-REX 150 videos. Honestly never really had any issues with my 150X. It's still a really nice heli IMO. I've thought about picking one up again, just to compare it to the M1 when I get it.
sportbikerr and CrashyCrashy like this.
